Question about Nikon N75 35mm SLR Camera
Err message on Nikon 75 after taking a picture
View finder is dark.
    Scholar:
  • 95 Answers
Here's a link to the N75 / F75 user guide. The troubleshooting section / lens compatibility area might point to the problem. If the viewfinder is dark, the mirror is likely stuck in the UP position. This is usually due to a lens compatibilty issue, or the fact that the lens is not set to its smallest aperture (ie 22). The camera needs that to control the full range of aperture openings
Posted on Dec 10, 2008
Sometimes pictures are dark even in auto mode, err message is always coming, dark image in the view finder.
Hi dear pmorala
1) check
the lens if to drive the diaphragm actuating lever that opens.
2) also check the aperture lever on the camera body may be broken or bent.
3) look at the Shutter release the mirror and shoot the camera in a low speed (M mode) note if this works correctly or some of the leaves that make up the curtain is loose or out of place.
Everything seems fine ... OK command dial to select the full aperture, shoots the camera at you and see the diaphragm (set M mode and speed sh bellow 1 / 8). Full closed? = Aperture Mechanism defective.
Regards
Mar 16, 2011 | Nikon D90 Digital Camera with 18-105mm...
Get Err CF in view finder and cannot take pictures
did you try removing the memory card and making sure its not locked?
Mar 18, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
How to take a picture using display instead of view finder
I don't believe there is. Nikon call it Live View in other models, but its not mentioned in the D40 user manual.....
here's the full manual, if you'd like it.
http://safemanuals.com/user-guide-instructions-owner-manual/NIKON/D40-_E
Feb 28, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
I have a Nikon N60. Can't take pictures outside
can you manually change your f-stop to faster shutting. When the shutter stays open longer, it will draw in to much light. If you have an option for only outside pics, then I would try that as well.
Feb 06, 2010 | Nikon N60 35mm SLR Camera
Nikon D90 ERR message after taking picture -
Is there a memory card in the camera?
Also try cleaning the contacts on the lens (light rub with a pencil eraser works).
Aug 07, 2009 | Nikon D90 Digital Camera with 18-105mm...
Flashing "Err" message with a code 999. Can't shoot pictures.
Try resetting the camera.
First a soft reset is to just replace the battery. If that doesn't work try a hard reset - on the bottom the other side to the battery flap.
May 06, 2009 | Nikon D50 Digital Camera with 18-55mm and...
ERR sign
This sound like your auto flash is not popping up allot of the time this will give you a err message and cause a slow reauction to taking pictures causing them eather to be blurry or very dark some times. is your flash working? if it is then it could be you lens try a diffrent lens if you do not have another lens then go to a camera shop allot of times they will let you try out lenses to try to get you to buy one.
Mar 04, 2009 | Nikon D70s Digital Camera
'ERR"
Could be many different issues.
What camera is it?
When you put a lens on it, is the view finder quite dark?
Oct 27, 2008 | Photography
NIKON D2H ERR FAULT
I had a D2H with a similar error. The camera started giving an 'ERR' message almost from new but from reading various posts from other users I assumed it was a 'known' idiosyncrasy of the D2H, the camera would create an underexposed first shot after turning on. A colleague has the same problem on his D2H, and there are numerous references to the same problem on the web. Your post points to a similar shutter issue. My shutter failed completely at around 65,000 actuations, well short of the advertised '150,000'. In addition, the horizontal Main Command Dial had also failed a short time before, and it had cost me £135GBP to have that repaired.
The problem is down to the shutter and unfortunately replacing the shutter costs £349GBP in the UK, quoted to me by the Nikon UK Service Department, in Kingston, in March 09.
As for Nikon repairing it under a 'goodwill' policy, you may have better luck than me if you live somewhere other than the UK. I told them to keep mine, as attempting to charge me for the repair was the last straw, it wasn’t worth me spending another £350 on a camera that hadn’t been reliable in the first place. I had been planning on getting a D3 in October/November but will now probably sell my Nikon gear and go over to Canon, as Nikon don’t seem too bothered about their professional user base, and I certainly won’t be paying £5,000 for a D3X.
Sep 25, 2008 | Nikon D2H Set Digital Camera
Will not take picture
Some digital SLR camera have a mirror lock and others have a viewfinder shutter In each case this will be a knob in the region of the viewfinder that turns. Check that this model has it and it has not be inadvertently turned. Then come back
May 21, 2007 | Nikon D70s Digital Camera
Nikon N75 35mm SLR Camera Logo
246 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
