Question about IBM ThinkPad T41 Notebook
Anytime I moved my laptop, the screen would switch off. I left it with PC repair shop. They said it worked fine for them. I took it home. Now I just have to touch the laptop (usually lefthand corner beside mouse pad!) and the screen switches off. Sometimes it reboots as well without me doing it. When the screen switches off, if it doesn't reboot, I have to press power button to switch it off and then back on.
  • chrisdclarke Dec 30, 2008
    i have the exact same problem.. and i had it with a previous thinkpad...
    anytime you move the system... it freexes.. and the onlyway to restart it .
    is to unplug it.. and then sometimes it wont start up again... but if i press down in
    certain areas,, it will... now sometimes when i get it working again it says
    there was a problem with the display driver for ati mobility radon....
    so im thinking like the gentleman said,, its either a loose soder.. or a bad connection w the display driver..
    its wierd bc sometimes it doesnt do it for a day or two.. sometimes every 5 mins.... have u had any luck fixing the prob?
  • Chris Hingee
    Chris Hingee May 11, 2010
    Take it back to the PC repair shop, if they can't fix it then get your money back.
    It could be a faulty LCD screen or loose connectors.
  • 44 Answers
I believe the problem is with the HDD connector. What a poor choice IBM made when they chose that connector design. It is actually two separate pieces. It is not screwed together. You can't tighten it down. My guess is that they did this as some sort of shock absorbency prevention. In trying to prevent one problem they have created a different problem. I think this can easily be fixed you just need to figure out a way to keep the connector pressed down. I saw one person suggest drilling holes in the motherboard and zip tying it down. I think this is a very bad idea. With boards now being multi-layered you really can't be sure you aren't drilling through a trace. I am inclined to think that super glue may be the answer. It may not last forever, but you can always glue it again when you need to. What's the point of having shock absorbency if the computer is already messed up? IBM's engineers just didn't have the foresight on this matter. I'm willing to bet they know all about it now!
Posted on Jan 18, 2009
    Sergeant:
  • 324 Answers
Sounds like you have a video chip with loose solder connections. Next time this happens, try firmly lifting straight up on the front left corner of the keyboard. If the display comes back, or tries to come back, then you have probably pretty much confirmed that this is the problem. You could hook up an external monitor. If this problem doesn't show up on the external,you may have an LCD, or LCD cable problem. But from what you are describing, I would suggest that you will see the same problem with the external.
Please get back to me with what you find out.
Ron
Posted on Dec 09, 2008
2 Suggested Answers
  • 144 Answers
SOURCE: Anytime I moved my laptop, the screen would switch off
If thats the case then its probably the cable from your screen to the motherboard. This cable is called the screen ribbon cable. these cables are not meant to be pulled out and in more than 2 times and after that they become unpredictable. Ask the shop if they can replace it.
Posted on Dec 07, 2008
I have a nikon d60 i tripped and banged it off the ground(i was still holding and it did not drop)but since then when taking pictures when i focus and after the picture is taken i have noticed the screen...
i think you might find you knocked the VR switch on i thort i had proken my camera to but hten i took it to the camera shop and they guy didnt knwo what he was tralkign about hten i realised what i had done on my way home and if that is the case if u swich it off ( the VR switch on the lens) it will stop the view finder shaking when u take a photo
May 13, 2010 | Nikon D60 Digital Camera
I have Dell Inspiron B130 and the screen is cracked all the way down making using it very difficult. The other parts of the screen work fine though.
do you have accidentally cover on your home insurance, if so get your local repair shop to write a letter with the cost of a new screen and labour you might be able to get it fixed or even get a new one. i work in a pc repair shop and have done this before for people. hope this helps
Mar 16, 2010 | Dell Inspiron 1521 Laptop
HP dv9000 display works fine on battery but not AC
It's either the motherboard or the power supply.
I'd start with testing the power supply. If you've got a multi-meter great. Just measure the voltage and see if it fluctuates.
If not, check with a local repair shop to see if they have a power adapter they could use to test with.
Jun 17, 2009 | HP Pavilion dv9000z Notebook
Hp dv4000 screen turned pink now black
If its not the backlight inverter or cable. It will be the LCD screen itself. It seems the shop you took it to isn't really up on laptop repair, as this is a common issue I see often. Get on Ebay and find a screen for your model and replace it. I asure you this will fix your problem.
May 19, 2009 | HP Pavilion dv4000 Notebook
Toshiba L25-1216 LCD Screen cuts out or has
Most likely you have a loose video connection. Reseat the ribbon cable that connects the LCD screen to the motherboard.
This connector is located under the plastic panel that holds the power and various switches near the bottom edge of the LCD screen.
Apr 04, 2009 | Toshiba 15.4-inch 1.6GHz 40GB Laptop PC...
Anytime I moved my laptop, the screen would switch off. I left it with PC repair shop. They said it worked fine for them. I took it home. Now I just have to touch the laptop (usually lefthand corner beside...
Dec 07, 2008 | IBM ThinkPad T41 Notebook
Thinkpad screen goes blank if I touch/move laptop and reboots.
Push down on the center of your computer and restart it
Nov 16, 2008 | IBM ThinkPad T41 Notebook
Screen
Your LCD screen is broken this occurs from dropping the lcd or putting too much force/pressure on it. The black discoloration is is the liquid crystal leaking. It is repairable but the question is do you want to spend the money to repair it. A new lcd will cost you around $350+. You can also check ebay they might have compatible LCDs that might work for a lot less. According to the specs you need to took for a 12.1" 1024*768 XGA TFT Standard aspect lcd screen but beware not all LCDs with those specs will work. If your interested I am experienced in replacing laptop screens.
Jason(at)JRDTech.net
May 15, 2008 | Panasonic Toughbook W2 Notebook
Screen freezes
Battlebear, The video card is overheating or something close to it is causing it to overheat. They may not of even replaced it.
Feb 18, 2008 | Acer Aspire 5630 Notebook
IBM ThinkPad T41 Notebook Logo
95 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
