Question about Krups Orchestro Dialog FNF2 Espresso Machine
No coffee is coming out of the machine...
I have the Krups Orchestro Dialog and by the look of the display it seems to work just fine. I can press the buttons for coffee and it also starts to make noise - but nothing comes out of the machine. It seems it grinds the coffee beans but it does not take in water - and after a while it asks me to push the hot water button. When I do that it makes noise - stops after a minute - and says machine ready. But still no cofee. Hope you can help me!
  • 2 more comments
  • RachelleK Jan 24, 2008
    Hi, my machine seems to be blocked on one side where the coffee comes out. It flows really well from one of the silver 'things' but the other side only drip out. I have tried cleaning and descaling but it didn't help. ANY assistance would be greatly appreciated. Thanks
  • GolfBrad Feb 17, 2008
    I have the same problem - tried cleaning the machine but that doesn't do it.  Either the pump is cavitating or there is a blockage somewhere. Could be a scale problem?  Please help.
  • pjelect Jun 19, 2008
  • Anonymous Mar 15, 2014
    Been making coffee with no problem. Than asked to fill water container, what been done and afterward massage "Push the water container in as far it will go" appears non stop
Althogh this issue was posted in 2007. We just had a similar problem with ours. We live in Utah where the water is very hard.
Our machine started to not pull hot water out of the hot water nozzle ,it would sputter but just wasn't functioning like it should and then day by day the coffee started to drip out until we had no coffee at all coming out.
In the end it was all about the descaling process. The machine was so compacted with hard water deposit that it would not function. It couldn't even descale itself. I tried but it could not pull water through it to even run through the descale process.
You could hear that the pump trying to pull water, but it couldn't it ended up sucking air.
I opened up the right side of the machine where - the side where the nozzle for hot water is. Pulled the rubber hose off the right side of the pump. I used a medicine syringe from a pharmacy. I put a small amount of CLR and water in a coffee cup and started injecting this mixture into the pump. I turned the machine on, hit hot water, inject the solution and turned it off when the syringe emptied, and repeated the process until I saw a decent, but not perfect flow of water flowing out of the hot water nozzle.
When I saw the flow ok - I reconnected the hose - filled the water tank to the .5ml mark put in two capfuls of CLR. I took the filter out of the tank. Filled the syringe up with the CLR mixture and held it over the intake in the tank. Hit the hot water button and injected straight into the intake to get water into the tube so that the pump could get the water into it. It eventually did and am not sure if injecting in into the intake was necessary.
Once water was being sucked up by the tank. I ran the sytem through a descale process - Not Once - but FOUR times. There was a ton of mineral deposit and hard water crystals sputtering out the water nozzle and also into the coffee tray.
After I didn't see any more hard water crystals. I ran two full containers of water through the sytem, To clear out the CLR. (CLR in America is a product for hard water and lime)
I did this over two days, because I didn't want to kill the motor too. Not that I know that this would have happened, but I had just gone through a lot of work to get it working again.
And it is... and we have great coffee again.
Our machine leaks and I do want a proper technician to look at it, but I am so glad it is making us coffee again.
Lesson Learned - DESCALE your machines. I thought cleaning it was good enough - but clearly it isn't.
Opening the machine was painful, but not hard. There is a phillips head screw in the coffee bean holder - and two tamper resistant screws in the back. They are a pain. Patience and they will come out with pliers or a small wrench.
It worked for us.. hopefully it can work for others.
Posted on Apr 27, 2009
    Problem Solver:
  • 14 Answers
If you still have it. I can repair this machinr for you. You can try descaling but if that does not work you need to send it in for repair. Got to www.hotncold.com and click on Jura Repair. Jura and Krups are made by the same company. We can repair within 24hrs.
Posted on Aug 03, 2008
I suggest to throw the machine where it belongs : the rubbish bin. In fact, it IS making coffe, but the lower seal is not working properly and your coffee runs into the lower tray. You should change the seal, or do the first thing (like I did), and buy a Saeco.
Posted on May 06, 2007
  • Krups Master
  • 1,336 Answers
There may be a blockage in the electrovalve but more information needed 1st. Can you get any water out of the frother spout? If you can it will not be the electrovalve.
Posted on Jun 20, 2007
How do I fix my coffe machine?
Contact the authorized service center.
Jan 07, 2016 | Krups Orchestro Dialog FNF2 Espresso...
The hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Dec 30, 2009 | Krups Orchestro Dialog FNF2 Espresso...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Mar 26, 2009 | Krups Orchestro Dialog FNF2 Espresso...
My Krups iron only heats up slightly. HOw do I repair?
Your question is listed under espresso machines. Are you talking about a Krups Espresso Machine? Please clareify. Does it make Coffee and Steam?
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
My krups coffee machine comes up with service 8, what does this mean
The Brew Unit needs to be repaired or replaced. We repair Krups
Go to www.hotncold.com Click on Jura Repair. Krups and Jura are made by the same company.
May 26, 2008 | Krups Orchestro Dialog FNF2 Espresso...
I have a Krup Orchestro Dialog Autocapuccino fully automatic espresso machine. When I try to use the machine, it warms up properly, rinces correctly, grinds the coffee, makes the usual noises, few drops...
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours). Of course doing a hard reset erases all glitches.
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Krups Orchestro Dialog coffee machine
that mean no coffee go through us if you dont use the machine often you might have coffee residue on the grinder teet remove the coffee bean in the hole were the coffee bean goes use a brush and clean the grinder teet very good with the residue of coffee gonna grind and gonna go through thanks for usig fixya pierre
Feb 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Krups Orchestro Dialog FNF2 Espresso Machine Logo
914 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Ross Keen
Steve Allison
Steve Allison
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
