Question about Toshiba Satellite L15-S104 Notebook
Can I get more memory?
I have a Toshiba Laptop L15-S104, with 256 MB. How much more can I add? I had someone add another 256, giving me 512. But I wouls like to know if I can ge more? and How to go about it doing it myself?
  • twotwins87 Dec 10, 2008
    Thanks a lot!!! I found I what I needed to know.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
It is unlikly that you can put more most systems can only handle one extra card. if you need extra space then get a bigger size card and put it in this way:
turn it off
flip it over
get a screwdriver
unscrew the hatch with a computer chip symbol on it
and press the two side tabs, and the card will flip up
gently pull it out by shifting it side to side
then insert a new card at the same angle the other one was after you clicked it open
and push it in
i do not know what memory you had saved on it but i assume you will lose some
best of luck
Posted on Dec 07, 2008
Is there a way the memory in a toshiba satellite 1005-s157 be increased to more than 512MB?
Yes you can, at least to 1 Gb maybe possibly to 2 Gb.
There will be two memory slots in your laptop. To increase the RAM to 1 Gb install another 512 Mb RAM module in the empty 2nd memory slot. Make sure you use the same make and speed RAM as the one that is installed.
If you have two 256 Mb RAM modules installed in your laptop then you need to replace the two 256 Mb RAM modules with two 512 Mb RAM modules to get a total of 1 Gb RAM.
Aug 04, 2012 | Toshiba Computers & Internet
I want my laptop upgered ram saport 1 gb yes or no wich ram saported i dont no pless send me
The Toshiba Satellite L15-S104 will support a maximum of 1GB RAM, using 2 - 512 MB PC2100 DDR memory modules.
Aug 07, 2010 | Toshiba Satellite L15-S104 Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
What is the max ram for toshiba laptop model #
Hi Fhiken!
That modell comes with 256mb rab and supports up to 512mb ram.
The ramtype on it is SDRAM
I hope the info helped you
Nic
Aug 20, 2009 | Toshiba Computers & Internet
Toshiba laptop a75-s209 maximum memory capacit 2.5 mb
1.5GB total maxium, if I read the toshiba litature,correctly. So the answer is no, you may not. THe BIOS will only be able to read and use the max it was programed to read.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=835414&rpn=PSA70U&modelFilter=A70-S259&selCategory=3&selFamily=1073768663
Jun 29, 2009 | Toshiba Satellite A75-S209 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    I have a Satellite 2405-S221 and I was wondering if the max memory i can install is 512K, is there a way to update the bios, or ANYTHING to increase that amount to at least 1 gig??
    Toshiba Satellite 2405-S221 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 256 MB (removable) of Memory. You can upgrade your Toshiba Satellite 2405-S221 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 256 MB (removable) standard Memory installed.
    In short.... yeah, 512k is the max.
    Doesn't appear to a bios limitation. It is a hardware issue that is limiting the amount.
    Jan 24, 2009 | Toshiba 2405-S221 Notebook
    Hard drive and memory
    the laptop should pick up a 20gb or 60gb ide hard drive with no problem
    Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
    Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
    Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
    Maximum Ram upgrade?
    this is the link
    http://www.memorystock.com/memory/ToshibaSatellite2400103.html
    In this link u have following details
    1)Maximum capacity RAM Information Available
    2)Toshiba Laptop Memory Installation Video
    3)Laptop Memory SODIMM Installation Guide
    If you r Satisfied with information provided from my side please give me good ratings thanks
    If u require more information search in google
    Aug 09, 2008 | Toshiba Satellite 2400-S251 Notebook
    Upgrading RAM and Batteries
    For batteries, my advice would be to stick with the brand of the unit (Toshiba, in this case). Toshiba lists a 12 cell battery on their website under the "laptop accessories" section of www.toshiba.com. For the A60, the part number is listed as PA3382U-1BRS and costs $152.99. You can search google for another place to buy (perhaps where you bought the laptop) but be careful that you don't get a generic in place of the original (OEM). With memory, Kingston and PNY are the aftermarket leaders and you can't go wrong with either. Kingston's website lists a whole slew of specific A60 models. Some with 256MB on board (not removable) and some with 512MB on board. So, a 512MB chip may give you 768MB or 1024MB depending on the exact model. Max memory seems to be either 1.25GB or 1.5GB depending on how much is onboard (and not removable). Installation is usually easy on any laptop and typically requires only a small screw driver to remove the memory cover on the bottom. The owners manual for the laptop likely gives the steps to add memory.
    Sep 02, 2007 | Toshiba Satellite A60 Notebook
    Toshiba Satellite L15-S104 Notebook Logo
    251 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
