Question about Philips Magnavox DVD/VCR Dual Player
No color Just purchased Philips vhs-dvd player when hooked up to tv, picture and sounds works, but there is no color on VHS or DVD.
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 64 Answers
Make sure your are using the correct connections.
Your deck and your TV will probably both composite and component inputs and outputs. They are easy to confuse.
You might be sending a composite output into a component input. That could result in a monochrome picture.
If you are using a S-video cable. The black and white part of the picture (luma) and the color part of the picture (chroma) are carried on different lines. If the chroma signal is not getting through, you will get a black and white picture.
Posted on Jan 19, 2015
  • 3 Answers
Yes, as stated above, try the AUTO settings. which region r u from... PAL or NTSC???? if that does not work, then try to manually change the Color Selection on your Television.
Posted on Dec 14, 2008
  • 10,594 Answers
Please set your TV on Auto Color system to get colors on VHS and DVD.
Posted on Dec 07, 2008
Ok I purchased a philips dvd/vhs combo today and I can watch dvd and hear it great... but when I put a vhs in I get picture and no sound can anyone help me on this.. please
Check sound settings . If unit is set to Dolby change it to PCM. Most likely you have already went through other settings. If this does not work let me know the models of he unit and tv and what you have tried already and I will try to help
Nov 05, 2015 | Philips Televison & Video
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I am trying to hook up my vcr and my DVD to the 60pp9202 60 in my DVD is working but my VCR is not. I am getting a black and white picture on one channel and sound on the other.
put the dvd plug scart into the spare scart socket on the vhs player,then u can only use one player at a time,ie if watching dvd put vhs player into standby or vice versa,the other scart socket on the vhs player goes to the tv. when not using either be sure to put both on standby.
Feb 28, 2010 | Philips 60PP9202 60" Rear Projection...
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
How do I connect my Magnavox DVD/VHS player to my Element Flat screen TV?
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
Have a samsumg 4600 combo dvd/vhs plays vhs with good sound and picture, dvd only has sound and no picture
need to check the video audio output connectors sounds like it hooked to and output that is only for the vhs
Jul 07, 2009 | Samsung DVD-V4600 DVD Player/VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Philips Magnavox DVD/VCR Dual Player Logo
362 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
