Question about Dryers
I don't know how to connect the wires on the plug to the dryer
I just got a dryer, model #LDE7334ACE. I had to replace the plug so it would work at my new house but now I don't know how to connect the wires.
  • 706 Answers
Hello perfectange,
You should have a power cord that matches the 3 or 4 prong wall receptacle and it's pretty straight forward on how to connect. First off..position the dryer in a place that yuou can gain access to the back of the dryer.. Next, locate the passthru opening for where the new cord goes thru the dryer.. You should have or get the appropriate cable clamp feedthru for passing that cord thru and into the dryer. The clamp prevents you from pulling the wires free from their terminations inside the dryer so don't omit this part of it..
Next, remove the access cover over the terminal block that is inside the dryer and where the power cord is attached. You should see at least 3 terminals and maybe 4.. You should see a Red, White, Black and/or Green double row terminal strip. Attach the red tagged end of your power cord to the red terminal block screw, white to white, black to black.. If you don't have a green one.. that is earth ground and you can secure that to the nearest frame member screw that is unpainted.. If you do have a green terminal for groud, attach it to that one. Make sure all the screws are fairly tight. Make sure the cable clamp is tight and holding the cord from being moved. Then plug it into the mating wall receptacle. I would encourage you to cycle the dryer for a few minutes without clothing in it or the vent attached to verify it heats up and everything works properly. Then reposition it back into its final location, level accordingly and attach the vent duct ..
Hope this helps..
Regards,
Rick
Posted on Dec 07, 2008
I have a 20 year old electric dryer that normally works great. All at once the dryer stopped heating, but otherwise works normally. I took the dryer apart, checked continuity of the heat coil, hi limit...
The problem is the terminal block, Vibration with the cord not being fastened to the block tight enough caused overheating at the block and it failed. Replace it.
Jul 19, 2013 | Dryers
After two times my Kenmore dryer would start and then stop mysteriously it now doesn't start. I'm leaning towards the receptacle and plug are the fault as they are both very corroded/oxidized. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Kenmore Dryers
Maytag dryer model number lde7334ace wont spin a full load of clothes we put a new belt on and fan blade now it wont spin a full load
recheck the belt, Tim:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Apr 06, 2011 | Dryers
Maytag dryer quit drying, no heat Model NO. LDE7334ACE
If the rest of the dryer is operating, make sure the exhaust is not blocked any where from the lint screen to the outlet damper outside. If it's clear then you will need a meter to diagnose further.
Oct 06, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer squeaks during cycle
How do you replace the glides/slides? I have a Maytag dryer that's squeaking, took off front and it's clear it's the glides. Found where to buy them just need directions for replacing. Anyone know how?
To change the glides you have someone lift the drum--after taking off the front panel--and pull out the glides. We bought the glides locally and just ordered on line the felt pads that go under the glides, as one was missing. So I haven't actually completed the project but should easily be able to once the felt pads arrive.
Mar 23, 2009 | Maytag PYE2300AY Electric Dryer
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Kemore Dryer / Model # 63742
I'm not familiar with this specific Dryer, but in most of them you can find their wiring diagram glued under the upper panel or the rear panel. Good luck !
May 16, 2006 | Kenmore 64742 Electric Dryer
Dryers Logo
149 people viewed this question
Top Dryers Experts
