Question about Canon EOS-5D Digital Camera
I opened the lens and the plastic piece fell out. This is not my camera and i need to return it's owner today for a shoot. What should I do?
You shouldn't mess with it.
Go buy new one for him if you want to keep your relationship
Posted on Dec 07, 2008
Nikon d3000
did you try a different lens if you did send your camera in for repair . the lens gets damaged easy
Feb 07, 2013 | Nikon D3000 Digital Camera
Partly open lens
the mechanical part that is trying to open the lens cover is having a problem
Possibly
1. a lodged piece of foreign material
2. A broken piece within the camera is interfering
3. A piece in the camera that helps control the lens or another piece by the lens is out of place
Please check this out if you are comfortable doing so and let me know what comes of it
Thank you
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Fuzzy Pictures w/ Nikon D3000
If this is a new camera, it should still be under warranty. I suggest you contact Nikon before doing anything else to determine if the repair would be covered under warranty. Nikon also would be in a position to advise you as to what the problem might be so that in the event that the repair is not covered under warranty, you don't replace the wrong thing.
My sumsung diggital camera fell in water. The battery and the memory card work alright. But when i switch it on a bright orange light comes on the front of the camera and the lens wont open does anyone kow...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Did you dry the camera completely? If not here is the procedure to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 21, 2010 | Samsung L700 Digital Camera
I have an old 35mm Canon Sure Shot 70 Zoom. There is film in the camera, but the battery is dead. I can't find the owner's manual and want to know if I'll expose the film if I open the camera to change the...
You don't need to open the camera to change the film. The battery door is on the other end. You open the door by inserting the protrusion on the plastic end piece of the strap into the slot of the battery door. It takes a small 3 volt battery.
Sep 04, 2009 | Canon Sure Shot 70 Zoom Date 35mm Point...
Plastic lens part inside 5d fell out what should I do?
Since you weren't really clear about what the part is or looks like it's hard to tell. Most lens repairs of any kind that would require opening the lens in any manner are best handled by professionals. Too much of a risk of ruining a lens.
Dec 07, 2008 | Canon EOS-5D Digital Camera
Lens cap stuck
I was messing around with this today, ended up where it seemed in was working.
Power up, let lens out, then take out batteries. Pry off silver band patiently using fingernails. Then pry off overlying black plastic piece. There are four units underneath, pay attention to how these are put on, mine popped off, but it wasn't too hard to figure out how to put back together. There are pins and holes and kind of fits like a jigsaw. Once off clean with alcohol where you can.
Put batteries back in and open and close a few times. This will help understand movement where pins of lens cover pieces go. When putting these back on make sure camera is in off position.
The lens cover pieces need to be put on so that the pin portion has some resistance. Move one so that it drops in then push up to get other in place. Let them come together and hold these in place.
The two smaller pieces will close the cover. Put the hole of the closer piece over the pin. Then move slightly so you can retract spring with a small instrument and subsequently engages pin on closer. Place top black piece back on, then silver.
This worked for me, hope it does you also! Good luck.
Dec 03, 2008 | Canon PowerShot A510 Digital Camera
Printer fell...extra part?
hmm..well..that may not be your only issue..if the printer fell to the floor.
Oct 13, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
A black shadow half way down the frame
http://www.lotek.nu/misc/EOS_300D_sub-mirror_repair/
2 cent plastic pin holding AF sub-mirror broke. See above. Unfortunately Canon charges a bit above 2 cents to fix it. Saving pennies on plastic instead of metal will make Canon a boatload of money because they will all break eventually. Of course if everyone changes manufacturer on their next camera this might backfire.
Feb 17, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS-5D Digital Camera Logo
27 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
