Question about HP Compaq S9500 19" CRT Monitor
Monitor display is totally moved to the left.
Help..my monitor display has turned 90 degrees to the left. Even my mouse pointer moves to the left when i try to move it forward.. and goes to the right when i turn it downward.. how can i repair this?
  • 3 Answers
Start >> Control Panel >> Display >> Settings >> Advanced >> Intel(R) Extreme Graphics 2 >> Graphics Properties >> Hot Keys >> Check mark on Enable Hot Keys >> APPLY.
Now press ALT + CTRL + up (ARROW).
Make sure after doing this uncheck on Enable Hot Keys.
Deepak
freakid@rediffmail.com
Posted on Mar 20, 2009
Rotate screen back to normal
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 23, 2013 | Gateway Computers & Internet
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
After dropping the mouse the screen turned 90 degrees counterclockwise
Probably not the monitor but a software issue. Depending on what OS/graphics driver you use you can rotate the screen. I would need to do is find the setting and rotate it back to normal. For instance if you are using XP and integrated intel graphics you can right click anywhere on the desktop area, left click on graphic options and rotate 90, 180, or 270 degrees. If you run NVIDIA you can right click on your desktop area and click on NIVIDIA control panel. From there find rotation settings and choose what you need to return your display to normal.
Mar 04, 2011 | Acer X203H bd Monitor
My computer monitor display changed from being horizontal to vertical how can I change it back?
If you have an Nvidia Graphics card then on the bottom right hand side of your task bar, next to the time, it's a green icon. A Nvidia logo is displayed. Left click on it and move your mouse over rotation settings, should be set to rotate 0 degrees.
Can also access through control panel, then Nvidia control panel, then on the left menu rotate display, set it to no rotation 0 degrees.
Please take the time to rate my expertise.
Thanks
Oct 31, 2010 | Computers & Internet
The monitor picture has moved 90 degrees
Right click on the monitor display away from icons ans on the desktop. Scroll down to either properties or if it says ATI or Nvidia control panel. If it is under properties look for the txt "Orientation", click on "Landscape" or "0" degrees whichever it states. Click apply and OK. If you bring up the control panel for display settings, then look in the left hand pane for "screen Orientation" and again choose "Landscape" or "0" degrees....whichever one it states.
Jul 01, 2010 | Dell 0Y3740 Keyboard
Image/screen shifting with mouse position
I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
Feb 21, 2008 | Apple Cinema Display 23" HD Monitor
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
HP Compaq S9500 19" CRT Monitor Logo
88 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
