Question about StarTech.com StarView SV211K 2-port KVM Switch
Codes for digivox to cure scrambled signal
The codes i have are not fitting into the boxes they seem to be too long.
  • paulob5 Dec 19, 2008
    need code for the box .ie chorus signal scrambled.
    Genius:
  • 1,061 Answers
CONTACT STARTECH.COM OR YOUR SERVICE PROVIDER
Posted on Dec 07, 2008
My digivox has lost nearly all channels apart from freeview options nd sky sports 1-4. All movies nd espn gone. I've tried rebooting box,checked emu1004 nd changed frequencys back nd fourth but now back to...
if its a cable box then sorry there is no fix for this problem yet if it is a terrestrial box then delete the scrambled channels and rescan if you factory reset the box then you must install the latest firmware
Apr 26, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Tip
Entering codes to your box t /digivox/eurovox
right guys in the hope that you had everything right and unfortunatly your box gets scrambled and you need to input the newest codes manually step 1 on your remote press menuafter you do this you then press the appropriate no or code for the box you have ie.box t 1570 step 2 after you input the code and it opens the new menu/hidden menu remember you cannot access the hidden menu /or emu unless you had the firmware installed before they scrambled step 3 there will at this stage be only one or two lines in the list high lighted usually nagravision and key emu press nagravision that will scroll to another page step 4 it will then say service provider which means who ever your signal is been received from???step 5 you will then see no like 5a01written beside the service provider you must input the proper one for your provider if it is not allready there usuall when you find your provider this no. is there step 6 under this you will see two lines of no.and letters step 7 scroll down to the first line which is usually line 00 then if you have got the new line or codes you simply follow the no keys on your remote to input the no and the coloured keys to input the letters after you have the top line done you must save them by pressing on the ok button on your remote step 8 you then repeat this for the second line marked 01 input the new code again on this line press ok and on the very bottom of the screen you will see the save flash while you press the ok button step 9 you then simply press exit exit back to main screen and all should be working if not you just repeat the steps and make sure you saved the codes line 1 after you put in line 1 and line 2 after line 2 hope this makes things easier on you and helps
on Apr 27, 2010 | Audio Players & Recorders
Telewest codes for digivox 17/08/2009
AA B7 D1 D9 CE 8E 83 AF
8E 80 D7 EF 44 93 02 2B
Aug 17, 2009 | StarTech.com StarView SV211K 2-port KVM...
Digivox xl telewest
5a 01
00 aa b7 d1 dg ce 8e 83 af
01 8e 80 d7 ef 44 93 02 2b
Jun 14, 2009 | StarTech.com StarView SV211K 2-port KVM...
Didivox in cork area
If you box is on MMDS/Teresterial:
You should download the firmware "digivox_ter_v3300.bin" and put this on your box using downloaded10.exe (This will automatically fix your problem)
(You should be able to find the file by using Google.)
1. Connect to Internet.
2. Search for the files named above
3. Save / Download the files
4. Get the cable to connect your box to the PC.
5. Connect PC to Digivox via the serial port using an RS232
cable.
6. Turn on Digivox & then turn on PC.
7. Open loader software “DOWNLOADER 10”
8. Check settings and parameters. Defaults are usually correct.
9. Browse for bin file (digivox_ter_v3300.bin )
For all files and the downloader 10 click this link http://eko.4shared.com/ and hit digivox
and select.
10. Check “app file” (default).
11. Click “download”
12. A progress bar will appear. Wait for “download complete “ window to pop-up
13. Turn off Digivox and PC then disconnect.
Enabling Key Emulator
1. Connect Digivox to TV (usually scart), cable feed and power on.
2. Perform full auto-scan.
3. Go to “main menu”
4. Scroll down to “System Information”, press “OK” to enter System Information menu.
5. On your remote control press “ 1 0 0 4 ” (ignore what happens on the screen)
6. “Key Emu” will now be visible on the screen.
7. Change “Key Emu” to ON
8. Exit menus and return to TV mode.
9. Go to a scrambled / encrypted channel and wait for update process to complete.
10. Scrambled channels should now be unlocked.
Problems with no sound
To get back sound on e4 sky1 ect just select the channel in question press menu, select installation, select manual scan, click ok on down frequency. It'll now scan for channels when its finished exit back to normal tv viewing screen go to the end of your channel listing and the desired channel will be there with sound. This can be done on any channel with no sound by just selecting that channel following the instructions above
May 28, 2009 | Digi Televison & Video
Digivox Codes - NTL Dublin 22/2
The code for digivox ntl in dublin is
B0 B8 4F 04 E6 5F 87 80
Feb 22, 2009 | StarTech.com StarView SV211K 2-port KVM...
Digivox codes
HI,
Have you sorted your issue with the codes
Jan 03, 2009 | StarTech.com StarView SV211K 2-port KVM...
My digivox is scrambling all my channels. Was working fine for about 6 months, then all of a sudden all channels gone. tried entering 0000 again. But nothing!!!! Can anyone help
are ur fta channels still working if they are then ur cable co. has changed codes you'll need to put new codes in or download new software to fix this problem hope that helps.
Jan 02, 2009 | Computers & Internet
StarTech.com StarView SV211K 2-port KVM Switch Logo
137 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
