Question about Acoustic A-5640 Computer Speakers
I just bought Accent Acoustics S-3006 computer speakers with an subwoofer for my desk top computer and when I plug everything in and when we turn on the speaker and the computer the local radio station comes through the computer. We can hear all the other sounds of the the computer and the speakers work with playing music on the computer but the local radio station comes through. What can we do to stop this?
    Scholar:
  • 66 Answers
It is called interference.you have to follow the connection guide properly .you have put a wrong wire in the wrong place.please go through your connection again.you can write if you still need more info.
Posted on Sep 10, 2009
  • 103 Answers
If you have an antenna close to it move it or disconnect it. if it is just feeding through oddly then you prolly need a inline filter...
Posted on Aug 15, 2009
Can i add Cyber Acoustics 2.1 3-Piece Computer Speaker System with Subwoofer to my tv using roku3?
You can't use 2 different speaker systems connected to one device output.
You could connect the CA speakers connected to your Roku and improve your TV sound. You could also use your microlab speakers connected to your computer to augment your computer based audio.
Apr 08, 2014 | Audio Players & Recorders
Boston Acoustics BA745 2.1 Analog Speaker System. The left speaker drops out after system warms up.The D-shaped plug clicks twice when plugging the cable into the Out to PC outlet on the subwoofer (labeled...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer hope this helps
Apr 11, 2011 | Boston Acoustics BA745 Computer Speakers
How to set up
these speakers are easy to setup. The two speakers are already connected to each other, and the out cable comes from the speaker with the power and volume. The subwoofer and power also connects to that speaker. you would liked to have had the second speaker have the ability to totally disconnect from the main speaker, and you would also have liked to have had a headphone jack built into one of the speakers. Besides that, these are very easy to use, press power, turn the volume to a desired level, pretty straightforward. thanxs
Aug 09, 2010 | Cyber Acoustics Accent S-3022 Computer...
Can boston acoustics BA745 be hooked up to toshiba hdtv
Yes it can, just buy a converter adapter at a local electronics store, Just ensure that the TV has an earphone jack. Good luck
Mar 03, 2010 | Boston Acoustics BA745 Computer Speakers
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
May 17, 2009 | Boston Acoustics MicroMedia Computer...
Looking for connection instructions to PC and subwoofer
ou can download a manual under product detail on this page.
http://www.amazon.com/Boston-Acoustics-BA790-Multimedia-Computer/dp/B00005AR7N
Check power supply is plugged in correctly and switched on at the socket, then turn or push the button usually on the right speaker to turn it on,
good luck HPC
Feb 04, 2009 | Boston Acoustics BA790 Computer Speakers
Connect speakers to laptop
If the speaker you want to connect is from other devices(not a computer speaker )then you need an amplifier .Connect the speaker to the amp. then connect the laptop(output) to amplifier (input)the cable you need is "dual RCA male to 3.5mm male audio" .here is the link to view the cable that you need.
http://www.cablesnmor.com/rca-mini-stereo.html
Jan 30, 2009 | Cyber Acoustics Accent S-3006 Computer...
Boston Acoustics Digital BA735 Speakers with no Analog input.
I use one set of BA735 with two computers. Computer A sends digital out and Computer B sends analog. BA735 plays both. I listen to music using digital while the analog from the other computer alerts me to the incoming messages in Pidgin.
I did have to change bios settings on one computer to use the on-board audio.
To enable digital output in XP, click on the speaker icon > Advanced > Select Enable SPDIF. You can leave the PC Spk Mute unchecked if you want the analog output as well. That's all.
I hope you are able to enjoy the rich sound of BA735. It's beautiful. My ears thank a lot for replacing those desktop speakers. BA735 hardly takes up any space . Two small speakers are perched on the hutch and the bass module is somewhere behind the desk, completely invisible.
Dec 27, 2008 | Boston Acoustics BA735 Computer Speakers
Accent acoustics no power with transformer
I have the same problem at the moment. I cannot find my power cord either.
One thing I noticed is that the polarity of this connection is opposite of all of my other 9V power adapters. The 'pole' is negative on this speaker set. That means that the inside of the plug (the hole) has to be the negative. See if that might be your problem. Finding an adapter with the correct polarity and amperage is key. I am trying to figure out the amperage by searching the web.
Sep 29, 2008 | Acoustic A-5640 Computer Speakers
Acoustic A-5640 Computer Speakers Logo
511 people viewed this question
Top Acoustic Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Steve K
Are you an Acoustic Audio Player and Recorder Expert? Answer questions, earn points and help others
