Question about Mamiya Photography
Lackk of mamiya n645 users guide.
How do you open the back of the Mamiya 645 camera body to put in a fressh roll of film???
  • holtonfb Dec 08, 2008
    Agreed on finding a user's manual for the 645 ..it's a *****.. I had to pay nearly 50 dollars for a user's manual for a used car that I bought recently. Taking into account the cost of even a used 645, it would be almost worth to pay that much for a complete and in good condition manual!!
    Top Expert:
  • Mamiya Master
  • 77,499 Answers
MAMIYA 645 owners manual in PDF form use this link
http://www.cameramanuals.org/mamiya_pdf/mamiya_m645-1.pdf
Posted on Dec 08, 2008
  • yadayada
    yadayada Dec 08, 2008
    GO TO PAGE 25 FOR LOADING INSTRUCTIONS
    Sergeant:
    Champion:
  • 435 Answers
Hi, you can push the buttons which has arrows and pull the rear chamber to open and load the film.
    Genius:
  • 1,550 Answers
You can find information from the link below
MAmiya 645
Check the page 12 and 13 for information about placing the roll
    Sergeant:
  • 399 Answers
Its a small plastic latch in black colour.u just have to scroll that down and it will open then insert the roll.
How do you remove the left strap post on a Mamiya 645 Pro?
Not something you can do your self as it involves removing the case. Would be useful to have it serviced cleaned and calibrated. Nice camera, I have a Bronica ETR 645.
company now run from this website
http://www.mamiyaleaf.com/
Looks like these people may be able to help and they carry spares.
Mamiya and MAC Camera repair Parts
Sep 14, 2015 | Mamiya Photography
Just got a 645= shutter "release jammed:, I put in new battery and also missing the crank arm, must have had a motor handle before. its like new, meter in prism works new battery,have old 645 J to...
if the shutter is jammed just off the device,and slightly pull the shutter door with your hand 3-4 times.apply a drop of oil on both the sides.and then on the device.and check it will work.
and for the replacement off the handle you will have to check on the old device that where are locks in the back you just have to remove that locks,also check for the hidden screws in the centre or back of the handle.which may be blocking it to be removed easily.
thanks.
Oct 11, 2008 | Mamiya Cameras
I bought a second hand Mamiya 645 Af but as soon as I load a film it shows a error message ERR 01 .... what is that ?
From the manual:
"If the error display is not canceled when the shutter release button is pressed again, insert the Dark slide, half-press the shutter release button while pressing the roll film holder's manual film advance button to wind up the film, then contact your nearest Mamiya agent or service center."
If you need a manual, you can download one from
http://butkus.org/chinon/mamiya/mamiya_645af/mamiya_645af.htm
Aug 04, 2011 | Mamiya 645AF Medium Format Camera
Mamiya 645 pro shutter doesn't fire
First thing that comes to mind on this camera is that it's a modular camera. This means the film back can be changed mid roll so there is what is called a Dark Slide between the film back and the body.
The dark slide needs to be removed before the camera will function. Also depending on how "new" the film back is there may be a dark slide holder/sleeve on the back side of the film back.
So you remove the dark slide and slide is into the holder so first you don't loose it and also it doesn't get bent.
Diagram
Jan 09, 2011 | Mamiya 645 Pro TL Medium Format Camera
Mamiya 645 AF back won't advance film.
The battery in the film back is only used to supply power when the back is off the camera, when it is on the body power is supplied by the six batteries in the body so try them and also make sure the film insert is properly seated.
Feb 07, 2010 | Mamiya 645AF Medium Format Camera
I have a mamiya 645 pro camera I can't remove the old film spool from the camera ? JoAnn
Squeeze the two handles on either side of the "120" or "220" label on the film holder to pull it out, then the spool is easily removed.
Jun 15, 2009 | Mamiya 645 Pro 80mm F2.8 N/L Lens
Mamiya M645j film counter not advancing to start when roll loaded
It's a common problem in the 645 - if you want to do it yourself, without a permanent fix, put a DROP ( not a lot ) of lighter fluid, or rubbing alcohol on the tip of a fine screwdriver and apply it to the gear you use to rewind the camera, and turn back and forth a few times. If that doesn't loosen it, it'll have to be disassembled.
Jan 07, 2009 | Mamiya 645 Medium Format Camera
Shutter stays open on mamiya 645 M
Get any crud from the battery out of the works with pH-neutral stuff and q-tips or lint-free towels, and see if it works (without film; might as well check current drain with a bench supply instead of a battery, too) once you've done a satisfactory job of that.  Then visit a shop so they can see if the shutter timing is tolerable...and perhaps sometime you can load film in again.
Jul 31, 2008 | Mamiya 645 Medium Format Camera
Open Questions:
Photography Logo
53 people viewed this question
Top Mamiya Photography Experts
Tony
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
