SW1000XG breakout cable port pinouts
I think i haven't written properly what was my problem, so I'll try again.
What i need is infromation about what the pins of the miniDIN port on the card are for (which is for ground and which are for in/out signals)
I couldn't find that kind of information in any audio store nearby.
Regards, Adam K.
    New Friend:
  • 21 Answers
HI,
Did you find the info you wanted on the SW1000XG card as I have the same problem and have been going round in circles.
RegardsBarry
Posted on Mar 02, 2012
2 Suggested Answers
SOURCE: Does anyone know the emu 1616 midi pinouts for the
I found the 1616 Breakout Cables on eBay.
Posted on Jan 05, 2010
How do i connect HP Pavilion G5418uk Desktop to a tv
Hi David,
by the looks of it you only have a vga display port on your pc, and unless you are lucky enough to have the same socket on the tv, then you will need to find either a vga breakout cable or install a graphics card which has connections for your tv. Hope this helps.
Feb 17, 2013 | Computers & Internet
22 PAR I0 ERROR
Haven't seen one of these printers for a long time. I think 22 is a datacomm error and the PAR IO would suggest it is a problem with the parallel port.
Verify cable is correctly connected. Try new cable.
Can't remember if the port on this printer is a slot in module, if so turn off printer, remove model ensure contacts clean, re-insert and retest
good luck
Sep 01, 2011 | HP Refurbished LaserJet IIISi printer...
Cant change my gprs to GPRS
hi there,
in this case, I think you haven`t registered your BB to BIS (Blackberry Internet Services), you`ll need to register it so the gprs icon can changed into GPRS
thanks
Jan 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
Connecting laptop to phone KX-TA824 not reading COM 1 to connect
Save yourself the trouble and use the USB port :-)
TA's are tricky, I just order a cable for Panasonic from my supplier so I don't pay attention to the pinouts. The cable is a standard DB-9 Female to Female and it fits into my USB to serial adapter from Iogear.
You might just try a USB cable and make sure the serial port parameters are set properly. Change them, or make sure they are 9600,N,8,1 They are programmed in 1.7 of the maintenance console or via the programming phone in system option 800.
If all of that appears proper, it's probably time to look in the device manager of your laptop and make sure your serial port appears. Then, run Hypertrm to see if you can get SMDR. Once Hypertrm works, the Pana software should work.
Carl
Oct 31, 2008 | Lands Phones
NewBridge 3600 Mainstreet
Hello
The pinout is determined by the serial port you are plugged into. Are you using serial port 1 or 2. This is pinout from a standard DB9 PC serial port should get you into SP1.
Blue-8
Orange-7
Black-2
Red-3
Green-5
Yellow-4
Brown-6
White-No Connect
Write back and let me know - BAD421
Aug 01, 2008 | Alcatel Newbridge MainStreet 3600...
JVC 8 pin pinout - speaker cable
Looking at the connector, there are 3 rows of pins.
Starting with the first row closest to the alignment mark:
[Power On],[Center Speaker],[Sub Woofer]
[Surround Right],[Speaker Ground],[Surround Left]
[Right],[Left]
If you are trying to connect two JVC units, you will need an 8-pin cable that has the SAME pins connected on each side. You will need to test this using a multimeter set to ohms or 'connectivity'.
There are other 8-pin cables out there like the one for apple networking, but they use a crossover pinout where pin 1 on one end = pin 3 on the other end. This is bad. JVC needs pin 1 to = pin 1.
This is a standard connector/pinout setup that JVC uses, so connecting a TH-C3 to a TH-C50 works fine. There is a bunch of intermixing that you can get away with. The only thing to keep an eye on is the power in watts that one unit sends and the other recieves. Worst case is that the speakers are quiter than expected or that you can turn the volume up so high that it can damage the speakers. In all cases, you should get desired volume somewhere on the dial.
If you are trying to wire the speaker set custom, then you will need to take note that an '8-pin' connector is actually a 9-wire connector. Along with the above pinout, you will need to add Case Ground, which is the metal circle that surrounds the pins. To make the speakers turn on, you will need to apply 12v to the Power On pin and ground the 12v source to the Case Ground outer ring.
The system takes 3 to 4 seconds to fully turn on after this connection is made. Speakers should be wired using the center pin for speaker ground and each other pin respectful to each speaker.
Apr 01, 2008 | JVC TH-C50 System
Enhanced video/TV missing in Device configuration
After looking at the specs of the think pad T43 i think you need a new laptop. The port you need to transfer video from a computer is called S-video. Your laptop don't have it. Srry.
You could look into some sort of breakout box that you could plug into your VGA out port and from there to a TV. The VGA out port is for adding a stand alone monitor and is not compatible with most TV's.
Jan 25, 2008 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
