Question about Electrical Supplies
Downstairs toilet light switch needs rewiring
Just had the downstairs loo re-plastered - plaster removed the ceiling light and the wiring from the junction box - he had no idea how to reconnect the light.
So above the light I have a connector (a) with red, green and black wires going into it and coming out of it - assuming this is part of the ring.
The pull switch had a black and red wire going into it and at the moment the other end of this wire is floating next to where the light should be.
Can I run a black from connector (a) direct to the light and then run a red from connector (a) to the light via the pull switch? So in effect making a loop?
Any help would be appreciated.
  • georgec7 Dec 10, 2008
    Great - very useful - I really appreciate the fast response.
    Thanks a lot George
  • 417 Answers
Yes, run a black wire from connector (a) to one terminal of your new light fitting if you are installing a metal fitting you will need to connect an earth wire also.
If you are reusing the same pull switch and it is still connected as you describe then the floating end near the light is probably the switched live conductor, so you could connect this to the live terminal of the new light. but be careful it may be live.
Caution always disconnect the power before working on electrical wiring.
Please remember to rate this solution.
Posted on Dec 07, 2008
2 level townhome- the upstairs is heating to 68 degree-thermostat is located but the downstairs is like 58 degrees.The vents are open in ceilings downstairs. How can we do to get more heat downstairs
close ceiling vents
the hot air down stairs rises through the vents and adds to the upstairs heating
same as hot air goes up the stairs to the upper rooms
Dec 27, 2017 | Heating & Cooling
Water damage to walls and ceiling in a building built from 1920 I scraped it down to bare wall now I'm interested in ideas in fixing the damage the walls are plaster. Thank you.
You can go to Lowe's and ask them for some wall plaster,tell them what your doing and they will get you the right kind and you will also need a putty knife to spread,and some sand paper,it will get real dusty when your sanding and it will go every where,use safety glasses,and a dusk mask and cover your hair.
Nov 02, 2012 | Computers & Internet
Plaster board
Selley's make a product called Spakfilla. It is used for patching cracks and cavities in wall and ceilings.
It is easy to apply - just follw the instructions.
Mar 05, 2012 | Computers & Internet
Toilet leaks into floor and lower level ceiling, no water on bathroom floor.
Either wax ring or sewage pipe is leaking. If you cant open the ceiling from below to look for leak you may have to remove toilet inspect pipe and look to see if it was leaking from wax ring and if it could have gone downstairs without leaking out too. If leak couldn't have come from wax ring the leak must be coming from a pipe in the floor. Find the simplest way to access it to repair it.
Sep 14, 2010 | Toto Round Carusoe Two Piece Toilet, 1.6...
I have wired a new light fitting into our downstairs toilet however when I came to test it the light worked but half the other downstairs lights are now switched off when the toilet light is swithced off....
Probably put your family at risk of electricution . By connecting the live cables to earth you have effectivly made all the metal light fittings live. It is amazing that the fuse has not blown, This in itself is dangerous and you should have an electrician look at the wiring.
The correct wiring should be as follows.
Identify cables there should be 2 twin and earth (red black & copper earth) cables and 1 twin red and copper earth. (or 2 single red wires)
connect all copper earth wires suitably sheathed in green/yellow sleeving to earth lug.
Connect 2 black cables to neutral block.
Connect either single red (0r 1 of 2 reds) into live block.
connect remaining 3 reds into loop block.
Nov 11, 2009 | Kitchen Appliances - Others
Changing downlight globes
if its the gu10 bulbs that you twist round to release them well theres a small ****** that sticks on the bulb and removes it leaving the actual light fitting in the ceiling.
Sep 27, 2009 | Electrical Supplies
Electrical Supplies Logo
355 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
