Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
Oven not heating
The power went out last night and now my hotpoint sy36k oven wont heat up. i dont know if the oven caused the mains to go out or not.
all the lights,fans and controls work but the oven wont get to temperature, it gets warm but not cooking temp
  • 3 more comments
  • ray7316 Dec 07, 2008
    nop, difference, tried turning all off and on again, no difference(its 240v)doesnt even get wrm,must have been residual heat previously which showed it was working and then went off. so element? or maybe thermostat
  • ray7316 Dec 13, 2008
    swapped the element and works fine now
    thanks for helping
  • fixitmaster Dec 27, 2008
    I had the same problem my electric went off and when I reset the trip fuse my oven did not get hot
  • gnvetter Mar 15, 2009
    My Hotpoint is also getting warm, but not hot.  The light comes on - but it never fully heats.  However, we did not lose power - this just happened.
    THANKS!!
  • Anonymous Mar 12, 2014
    Electricity getting to oven but heating light went out, and since then oven won't heat up
    Sergeant:
    Champion:
  • 338 Answers
You could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Posted on Dec 07, 2008
  • Robert Artiaco Dec 08, 2008
    open the back panel and test for the element. put your meter leads one
    on one terminal one on the other if you read 240 you have a bad element
    if you read 0 you may have a bad control. take the yellow wire off and
    tet for 120 coming out if the board if no voltage coming out then
    replace the control.
OVEN IS NOT HEATING UP. JUST USED IT 3 DAYS AGO & WHEN I WENT TO WARM IT UP TO USE LAST NIGHT...NOTHING.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 12, 2010 | Ovens
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Oven not working
you would have to check the element for continuity. Also the oven sensor could be suspect and should ohm out at 1180 at room temp. if both those are ok then main control is probable. without schematic it would be hard to say for sure..there may even be a safety fuse blown.
Jun 13, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
The oven wont heat up above 50
HI, this is not a serious issue here. you will need to test the resistance of the oven temp senors. it seems to be defective. also, check the wiring harness from the oven temp sensor to the control. make sure the wiring harness is in good condition. replace the oven temp sensor if found to be defective.
May 30, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint BD52 oven very slow to heat up
You may have one leg of power that is out. First turn off the breakers, then back on. Check it to see if it is better. Then check the wiring from the receptacle, to the plug, to the back of the oven. Look inside the back of it and see if you see any fuses. They could be blown as well. If you are getting some heat (red) then it is an indication of a wiring or fuse problem. Now, one last thought here, if you turn it to high heat does it heat up faster? This one lead it to be in the control switch. Let me know how you do.
Feb 13, 2009 | Hotpoint Ovens
Hotpoint oven heating element
check stat not open circuit and check selector switch not damaged
Aug 20, 2008 | Smeg SE250XUK Stainless Steel Electric...
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
537 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
