Question about Miele 24 in. Touchtronic Platinum Built-in Dishwasher
Miele platinum dishwasher intake/drain light on, not draining
The cycle goes almost all the way through then the intake/drain light comes on and the machine stops with water in the bottom. We take off and clean the filter etc. press the button to clear the light, set a rinse cycle and it completes and drains. Obviously it's a pain to have to keep doing this and something must be slightly off - we just don't know what!
SOURCE: Miele Dishwasher Problem
This happened to me and I noticed there was about 4 inches of dirty water that hadn't drained from the dishwasher. I took out all of the water, cleaned the filters and then started the dishwasher again. It worked. Good Luck.
Posted on Jul 10, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
  • 37 Answers
SOURCE: F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
http://www.mieleusa.com/usa/contact/contact_miele.asp?page=1
Posted on Apr 20, 2010
  • 177 Answers
SOURCE: my miele dishwasher shows intake/drain light
hi, firstly check the filter in the waterproof system where the tap is to make sure it is not blocked. turn off the water and remove the connection with the white box attached this is the waterproof system. remove the black seal and you will see the filter. pull it out with a pair of pliers and clean it.
if this is ok check to see if you have a restrictor on the tap or inside the tap and also make sure water is flowing from the tap prior to reconnecting the waterproof system.
run the unit again and when it is time for the machine to call for water you can manually fill it and see if it works using a saucepan or bucket. if this works ok you may have a stuck waterproof system and probably need to replace this.
Hope this helps
Posted on Jun 26, 2010
  • 251 Answers
SOURCE: Miele G892 SC Touctronic dishwasher, intake/Drain
Evening to you - empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check if all clear - clean up & assemble - should be good to go...
Posted on Jul 01, 2011
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
I have a Miele Platinum Turbothermic dishwasher. The intake drain light is flashing and the bottom of the washer is full of water. How do I fix it?
I have this same dishwasher I already dumped 400 into it to fix the intake drain and no more than a few uses after it breaks again I have never had more problems with a top of the line product or so what Miele thinks it is. I absolutely hate this dishwasher I refuse to put anymore money into it it is the worst product and Miele is no help they don't care whatsoever. I will never ever purchase Miele products they are more work and headache than cheaper models which will stand the test of time. What a complete piece of you know what.
Nov 24, 2011 | Miele Dishwashers
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
Miele Platinum dishwasher: Can't get past the intake/drain step
It could be that the drain pump or the non-return valve is clogged. Refer to the manual about how to check the non-return valve. It is under the "Maintanence" section. Here is a link to it:
https://www.miele.com/pmedia/ZGA/TX2070/9953540-000-02_9953540-02.pdf
Nov 03, 2017 | Miele 24 in. Touchtronic Platinum Built-in...
Miele intake light on since new sink,disposal installed
check and see if the disposer drain port plug was removed. intake/drain light means slow drain or no drain
Feb 04, 2009 | Miele Touchtronic G892 Built-in Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Intake/Drain red light comes in and shuts down during wash cycle
You will more that likely have a faulty waterproof inlet system
May 17, 2007 | Miele 24 in. Novotronic G851SC Plus...
Miele 24 in. Touchtronic Platinum Built-in Dishwasher Logo
490 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
