Question about Motorola Mobility RAZR V3
LOST THE END CAP
ONE OF MY END CAPS FELL OUT OF MY PHONE, IT IS THE SILVER SLIDE IN PIECE THAT HELPS HOLD THE PHONE TOGETHER. EVERY TIME I OPEN MY PHONE IT FEELS LIKE THE SCREEN PART IS GOING TO FALL OFF. IT IS THE ONE ON THE LEFT SIDE, THE ONE ON THE RIGHT HAS THE CAP THAT YOU CAN ADD A STRAP TOO. I JUST NEED THE CAP FOR THE LEFT. CAN YOU ADVISE WHERE I CAN ORDER IT FROM AND HOW MUCH IT COSTS. I DIDNT GET THE WARRANTY ON IT.
    Brigadier General:
  • 7,752 Answers
You should be able to change the housing on the phone take it to a mobile service center and have it done.
Posted on Dec 28, 2008
How do I put the car orator back together ? There's a spring middle the cable and a little v shaped piece with hooks on the top?
You mean carburetor? Hold the cap with the cable through it in your left hand. Push the spring up in the cap and hold it with your thumb, making sure the cable is extended away from the cap, Take the slide in your right hand and fish the cable end through the wide part of the hole far enough to clear the stop. Move the cable to the small part of the slot. Install the "v" shaped piece ,or "keeper",to keep the cable and needle in place. You may have to spin the keeper in the slide a little to lock the cable in place. Let the spring extend. Screw the cap to the top of the carb making sure the needle goes into the jet smoothly.
Mar 03, 2015 | Motorcycles
I recently bought an Amloid My First Mini Cycle for my son. I was only given on packet of assembly intructions for the fork and front wheel of the cycle. Once you put that together the instructions say...
You need to hammer the cap on. The tube with open ends fits over the cap and lets you hammer it on. To make it work, you need something to hold the other end, like a block of wood, or I found a hockey puck worked perfectly. Assemble the rear wheels, then turn the cycle on its side with the cap end of the axle down. Put it on the block of wood or the puck, and then hammer on the cap with the help of the tube. Now if you can help me get the handlebars on, I'd be eternally grateful. Problem is the spacers seem to be too big to allow the fork into the slot in the handlebars, and without them, there is nothing to screw into to hold the handlebars.
Apr 30, 2011 | Toys
I lost the instruction Manuel and I need to convert the crib into the toddler bed
First I unbolted the four arms that hold the metal bed support up and pushed it down as flat as I could. I had to do it a couple of times and go kind of slow, to get the loose arms tucked away as best I could. They still stick up a little above the rest of the frame.
After much wrestling with the wooden front panel (gate) of the crib (the one I need to remove), here is what I did:
1. Find the wooden piece that crosses the bed just behind the gate. This is an approximately 1.5-inch by 3/4-inch piece. On ours, it's just above and in front of the drawer under the crib.
2. Find the metal screw at one end of this cross piece. You will see that it is on the outside of the bed, on the short end of the bed, in line with the cross piece.
3. Unscrew it. Note that this screw actually threads into a threaded piece inserted into the cross piece in a little hole on the back side of the cross piece, about 3/4 inch from the end. If this little silver metal piece falls out, you will need to find it and put it back in the hole with the threads facing the screw hole. The piece is the size of a pea.
4. Anyway, use an allen wrench to remove the screw, without losing that little inserted thingy.
5. I'm not saying this is textbook, but I then forced the end of the crib away from the rest of the crib while moving the gate up and down and pulling gently toward me (to pull the gate from its track). You have to move the end of the crib to create about a 1/2-inch gap before the gate will pop free.
6. The gate has two pins on each side, so when you get it freed on the site that you removed the screw on, the other side will come off without removing the second screw on that side.
7. I then got the drawer back on its tracks properly (it jumped the tracks a bit in the process), pushed everything back together the way it was, and screwed the screw back in. (if the screw wont thread, either you lost the aforementioned little silver piece, or that little silver piece is turned in the hold the wrong way)
8. With the gate removed, the crib (now toddler bed I guess) has four little tabs where the gate was once attached. Two I had to unscrew, and the other two I grabbed with a pliers and pulled out.
It wasn't elegant, but I certainly have an intact toddler bed now.
Hope helps. Good luck.
Oct 04, 2010 | Toys
How do i install the keypad with flex cable throught the hinge on a v3?
There are small screws on the silver end pieces that hold the 2 pieces together. You have to completely take the phone apart top and bottom take the end piece out of the hinge and very carefully slide the flex cable through. Go to HowardForums and look for a tutorial there.
Aug 05, 2009 | Motorola Mobility RAZR V3
How to fork seals
First of all you'll need to get the bike up and secured. I dont have a bike jack, but after putting it up on the center stand and jacking it up under the pipes, I was able to put my two carstands under the crash bar to secure it.
1) Remove the front wheel, calipers, speedo cable, and fender.
If you want, drain the oil using the drain plug, but I just let mine pour out the top, and you wont have to worry about stripping the thread or damaging the seal.
2) You'll need to remove the caps from the top of the tube to expose the cap bolts. Loosen the cap bolts before you remove the tubes from the bike (I used a 10mm bolt and two jam nuts on the other end so that the head of the bolt fits into the hex, then you can use a ratchet on the jam nuts to loosen).
3) Loosen the pinch bolts (upper and lower). Make sure you hold onto the fork when loosening the final bolt so it doesnt hit the floor. Put your homemade hex tool back into the cap bolt and with the tube upside down and your foot on a ratchet to hold it, start turning the tube to remove the cap bolt. BE CAREFUL! The spring is behind the cap bolt, so you have to put downward pressure on the tube as you turn so that it doesnt go flying up when it's free. I put my fork in a small tub then the ratchet that I stood on, so when it came free, the nasty oil stays captured in the pan. It's probably easier to do this still on the bike, but I was a bit afraid of the spring pressure, which really turned out to not be that bad.
4) Remove the dust seal by tapping with a screwdriver very lightly. Use a screwdriver to remove the circlip from the tube.
5) Place the spring, spacer, and cap bolt to the side for cleaning. Now you'll have to get the dampener out. You can use a 13/16 spark plug socket that has the hex on one end. I took an old spark plug and put in it, then I had one of those "no foul" spark plug extenders to screw onto the plug so that I had a hex on that end too. Put a layer of elect tape on it to hold it all together and prevent scratching the tube. With a couple of long extensions you can get it down the tube and hold the dampener. Then you can unscrew the retainer bolt (8mm hex) at the bottom of the tube).
Backup method (if you cant get it to hold, take a cheap broomstick handle about 7/8" diameter and saw it off about 30" long and hammer the rounded end into the dampener and that will allow you to hold the stick with a vice and unscrew the bolt (I started off with this method and it did work! But once you get it out and can see it, you can improvise your own tool)
6) You can now remove the dampener, inner tube, seals, and spring from the outer tube. Wash all the parts in a cleaning solution. Use a scotchbrite pad to thoroughly polish the seal surfaces. Check all parts before re-assembly. Be sure to get ALL the dirt and grime from deep down in the bottom of the lower tube.
7) Re-assembly. Make sure you put the little aluminum taper spindle into the end of the inner tube before inserting back into the outer tube. Best to do upside down and slide the outer tube downward so it doesnt fall out (the big end of the spindle faces down!)
icon_cool.gif Once the tubes have completely came together, the spindle is trapped, and you can now turn rightside up. Put the washer on, then grease the inner tube and slide the new oil seal down. The smooth side goes up! Slide on another washer, then you can seat this with about a 30" piece of 1 1/2" PVC pipe that is cut squarely on one end. Tap gently with a rubber mallet till the washer is below the circlip groove. Install new circlip.
9) Install new dust seal. Use a 2" piece of PVC pipe this time to drive the dust seal down.
10) Place dampener and spring inside tube. Use your improvised tool to place the dampener back all the way down to the bottom of the tube. You'll need to clean and loc-tite the retaining bolt to screw in from the bottom. If the screw doesn't reach the threads, you put something together wrong. Stand on the allen wrench on the floor and torque the dampener to the manual's specification.
11) Put the tube back in the bike. Torque pinch bolts. Pour 13 ounces of new fork oil into the tube. Work the lower (outer tube) up and down slowly a few times to work the air out). Slide spring down into tube (tightly wound end of spring goes up!) Dont forget the little spring seat that sits on top of the spring. Place spacer into hole next.
12) Use your homemade hex tool and some downward force to get the cap bolt back screwed into the tube. Torque per the book, of course.
13) Replace caps onto cap bolts, Front wheel, calipers, speedo cable, fender, etc.
Aug 02, 2009 | 1985 Yamaha XJ 700 X Maxim
How to replace Simplicity vac brush roll strips?
The caps will come out of the end of the metal roller. They can be difficult if it's been a long time as dirt and grime can build up. Try sticking a flat head screwdriver in and gently twisting to get the caps to slide out.
Jul 16, 2009 | Riccar Vacuums
Opening door 2007 es leuxs with the key
There is a silver triangular cap on the end of the door handle with a hidden slot in the underside.
. Remove the silver glove box key from the end of your remote. Slide just the tip of the key into the slot in the cap and lift. The cap will pop off revealing a standard key slot to be used in case of power failure or dead battery in remote key.
Starting procedure in case of power failure is to hold your remote to the dash beside the ignition button for 20 seconds with a foot on the brake until the green lite comes on. Post back with results.
Jul 15, 2009 | 2007 Lexus ES 350
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Motorola Mobility RAZR V3 Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
