Question about Cyberhome CH-DVD 300 DVD Player
Random no audio
It seems to be random, but occasionally I'll put in a dvd and it will play the video fine, but give no audio output - and its not consistent - a dvd that one day wont play sound wil play perfectly normally the next day, or even later the same day, and one that plays normally will later give no sound, then later play sound fine again.
I have had this happen with this particular brand frequently. I have it plugged in to a power "strip" or surge protector. I find that if I turn the strip off then on again, it resets and fixes the problem.
Posted on Feb 19, 2007
This has happened to me, i just unplug the machine and replug it and it works fine!
Posted on Nov 09, 2007
Put in an audio CD and listen for about 5-6 seconds, then put the DVD back in.
Posted on Sep 09, 2007
SOURCE:
HDMI Video droputs.
Have you tried a different HDMI cable?
Dec 08, 2013 | Yamaha RX-V663 Receiver
How I can take off Random play from bus blaupunkt dvd-player. It shows (Random) on left side on screen when I put DVD in and movie jumps every few minutes. Very bad to watch movies, cause have to find...
There should be a DVD Repeat modes or "Repeat/Repeat Modes" button on your remote. Press that until it's back to "ALL" and it should play things properly again for you.
Aug 27, 2011 | Blaupunkt DVD-ME1 DVD/CD/MP3 PLAYER Car...
I have an Amoisonic 9100 DVD player. The problem is it works fine with some DVDs but other DVDs will not play, I get the message "wrong disc". There is no pattern to this that I can think of, all...
Don't worry your DVD player is fine .DVDS disc burners have different formats of recording . Not all DVD players can read all formats .
peace Iam out .
Jan 10, 2018 | Televison & Video
Xbox 360 is not giving video or audio output, ring is flashing green but seems random and noise from fan seems louder. tried unplugging to no avail and the console is hardly ever used so have no clue. any...
the switch on the hdmi cable may have been switched to hd (if your on a non-hd tv) or onto tv (if you are on a hdtv) try switching it back, that might be it...
Nov 05, 2009 | Microsoft Xbox 360 Console
I can't seem to get the menu button to display any menu. I only use the player for CD/s in a church sound system (connected to a Kenwood Audio Video Reveiver). Also, I can't get the disc player to play...
You will need to the remote to perform these functions. if you have it that's great, if not you willneed to contac Toshiba for a replacement. I ahve a manual for you to print out and keep with the unit. It shows you how to access the menu and to activate random mode..
http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/DVD/sd2705.pdf
Sep 16, 2009 | Toshiba SD-2705 Multi-disc DVD Player
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Denon AVR 4802 Receiver w/ Denon DVM 4800 DVD player - video fail
no the problem is at the plasma you will have to change the setting back to the scale range that will accept the signals from the Denon, see Plasma's manual for instructions
Jan 27, 2009 | Denon AVR-4802 Receiver
Random play for all cds in player
You might have to push each Cd button first so that it initiallizs all 5 disks and then press random
Nov 22, 2007 | Panasonic DVD-F87 Multi-disc DVD Player
Video image problem- Blue screen?
If your unit is fairly new,your VCR part might be the problem.Take it back!
If you have this unit for awhile,two things:
1. You need a professional A/V repair guy to clean up and check your VCR head.
2. The rental VHS tape is dirty.
Jul 28, 2007 | RCA DRC8335
Cyberhome CH-DVD 300 DVD Player Logo
117 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
