Question about Goodman GMS90703BXA Heater
Furnace with cold air only
Hi-- my furnace heater only blows cold air. From the therostat, if I keep the fan on auto, no air at all. When I turn the fan to on, air blows but it is cold. I can hear the motor/fan running. In looking at the furnace in the crawlspace, I pulled the front panel and had my wife turn the system on with the fan in the on position. The motor turns on, but there is not any flame.
From doing some research, I think I have a bad ignition switch or a bad circuit board or fuse burned out? Any ideas?
I have a TEMPSTAR 5000 (?) which is 15 years old.
  • averysandjor Jan 15, 2009
    carrier weathermaker sx furnace blowing cold air
  • Nicko_2 Jan 27, 2009
    I have the same problem. for voltage at the ignitor when I cycled the unit on. The fan that pushes air up the gas exhaust starts up the the blower motor starts running, but no voltage at the ignitor. It is a RHEEM Criterion II. A couple of LEDs on the circuit panel are green and a yellow one starts blinking.
    Habit-Forming:
    New Friend:
  • 33 Answers
I believe you are referring to the blower IN the furnace that distributes heat, not a power ventor which is used to expell flue gases when there is no chimney. I seems the answers given where in that direction. That being said, my answer addresses the blower for heat distribution IN the house.
I think what you are referring to is the fan limit. This senses the temp in the heat exchanger typically via a bi-metal coil that will expand and close a contact, sending power the blower when the preset high temperature in the exchanger is reached. This switch will also turn off burner if temp in exchange reaches max or "high limit", leaving the blower to run until it reaches a "low limit". One possiblility is the bi-metal coil is worn out, thus not responding to temp fluxuation.
A quality technician should never diagnose unless they are in front of the appliance. Hope this helps.
Posted on Feb 21, 2013
    Problem Solver:
PROBLEM SOLVED:
I work at a private school and we have three Tempstar furnaces that are going on ten years old. The problem, nine times out of ten, is the schedule on the Honeywell thermostat.
First, make sure the time and day are set correctly.
Second, set temperature and press 'Hold temp.'
Third, press 'Schedule,' it will display monday through friday and display 'wake,' set the time to wake at 5 pm; press 'schedule' and set time to leave at 11 am. set the same times for 'return' for 5 pm and 'sleep' for 11 am.
Do not set scedule for two PMs or two AMs. For example I set the schedule to wake at 5 pm and wake at 3 pm. It did not work at all and only blew cold air. It has to wake in the PM and sleep in the AM.
Then set 'schedule' for Sat through Sun. When saturday and sunday actually roll around the schedule will probably have to be reset again. So set schedule to wake at 5 pm and sleep at 11 am.
Fourth, press 'Run Program' then put thermostat under lock and key and hire an armed guard to stand watch and make sure nobody touches it or looks at it wrong. If somebody comes along later and hits 'hold temp,' it shuts everything down and starts blowing cold air again.
If that does not work, your next step is to make sure everything is clean, change filters, etc. Around the burners are two or three manual reset sensors. Shut down the power, remove the front panel, locate the sensors. They are round black gidgets that are attached by two red wires and two red terminals. Unscrew them and make sure they are clean.
If none of this works, then you need to get professional help for both yourself and your furnace. I did.
Posted on Jan 31, 2010
  • 1,420 Answers
Sequence of operation, Gas Furnace.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the ignitor. The ignitor will glow and you will be able to see it if viewed thru the small inspection port. Once the ignitor gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the ignitor does not energize (bad control, bad ignitor), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not lite (dirty pilot), the burner does not lite (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Most newer furnaces will have a diagnostic center or control built into the control module. You may be able to view it as it is running thru a small viewing port. Some models will require the removal of an access panel prior to finding it. On the reverse of the access panel, there will be a diagnostic chart that will aide you in understanding any error code recorded (usually a blinking light).
This is why we technicians earn the big bucks!
Posted on Dec 08, 2008
Atwood rv furnace My rv atwood furnace won't light.It just blows cold air.
check gas if ok see if unit fan on auto if ok see if ignitor has voltage when starting
Dec 27, 2017 | Water Heaters
Took off back to see filters put back together now wont start. spark,nozzle and fan work it just wont start
My Furnace Won't Start. Any Tips Before I Call for Service?
www.airmasterheatingandair.com/my-furnace-wont-start.-any-tips-befor...
Jan 30, 2013 - When your furnace will not start, you might feel a sense of panic and ... GA furnace repair specialists, our team at Air Master Heating and Air has ...
Furnace Won't Turn On? Furnace Troubleshooting
asm-air.com/heating/furnace-wont-turn-on-furnace-troubleshooting/
Jan 7, 2015 - It can be frustrating when your furnace won't turn on, not to mention ...but when you start moving up north it can be downright dangerous when a ... If your furnace is turning on, but blowing cold air, try: Heater Blowing Cold Air.
How To Fix a Furnace that Won't Start - Bonfe's - YouTube
? 1:52
https://www.youtube.com/watch?v=g5alqU4OvqA
Jun 15, 2012 - Uploaded by bonfesplumbingHVAC
Will your furnace not start? Before you call a professional heatingcontractor, check the following step-by-step ...
Furnace wont start. What to do before calling the repa
Jan 16, 2016 | Heating & Cooling
Amana Air Command 80 with fan mode is on, the furnace is running and blowing heat. Why the furnace did not do any thing when I set it on auto mode? Then I replaced a new thermostat, but nothing change
Try setting the temperature higher. It could be that the room temperature is not getting cold enough for the automatic controls to activate the heater.
Nov 02, 2014 | Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
My heater blows cold air why? I have a REAB 1010s need manual
Check your thermostat to see what your fan switch is set on. There should be two settings - auto and on. If it is set on auto, the fan only comes on when furnace runs. If the switch is set on on, the fan on your furnace is running all the time. Which means when temperature in the house reach what you have set on your thermostat, the furnace kicks off, but the fan keeps running and blows cool air. Some people run their fan all the time, especially if they have allergies, because that's a good way to clean the air.
Jan 02, 2011 | Heating & Cooling
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
Furnace blows cold air
Sometimes the fans kicks in by time ---or by heat...even if the heat cycles dont starts . Is this gas or electric,, name brand,.... model # ect...ect..
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
I have air coming from the vents but no heat. The furnace is 23 years old and I've never replaced anything in the unit. Best guess? GE Intertherm. thanks
If the thermostat is set on Fan and not Auto the fan will continue to run. If the fan control is bad or is set at too low of a setting, it will blow cold air after the furnace has shut off. From what I guess of your explanation, your furnace is not producing any heat and the room air blower runs blowing cold air. You may have two issues happening. Make sure your thermostat is calling for heat by setting it to a high setting. Inspect the thermostat to see if it is set at Auto. Go to the heating system and inspect it to see if it is heating. If you can't view any flames carefully touch the exhaust pipe and see if it is hot. If not, you have a no-heat condition. A 23 year old furnace may need some TLC so call a technician you trust. He/she may need to replace the ignitor or thermocouple to get it going. They will also check out why your fan is running when it should not.
Nov 02, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
1,282 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
