Question about LG WM1812C Front Load Washer
Leaks from front door 2 loads AFTER too much suds
We've had our washer for 2 years with no problems. When my husband recently did a load of wash and I noticed suds leaking out of the door. I figured it would resolve itself on next load with less detergent, but I notice some water is still leaking through -- no suds, just water. I checked the door seal and noticed a slight knick the size of a clipped topnail along the side of the door where the leak seems to occur, which may have been there all along but I wondered if this could be causing the leak. Seems rather sudden and I can't figure out how in the world this knick could possibly have occurred. Is replacing this seal a costly repair? Thank you in advance for your assistance.
    Scholar:
  • 146 Answers
No. It is not a costly affair. Order a new door boot seal from your local agent and fit it yourself. If you lift the outer lip of the seal on the front of the machine you will see a wire that runs all the way around the seal and attatches to a spring. Remove this wire and pull the seal free. On the other side you will find a strap holding the back of the seal in place. Loosen the strap and the seal comes away. Fit the new seal in reverse order ensuring that the drain hole/s are at the bottom of the seal.
Posted on Nov 01, 2007
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
Water and suds leaking
if you have any suds your either using too much soap or the wrong kind. does the washer drain all the water out each time? is this a new machine where you're washing your clothes in it for the first time? I've seen clothes with resisual soap in them causing over sudsing.
May 20, 2010 | LG WM2487H Front Load Washer
DETERGENT
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount. Nearly all brands of "HE" detergent have incorrect instructions. The correct amount is as follows:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Sensors
7) Reduced Spin Speeds (laundry not spin-dried effectively)
These washers MUST have the right amount of the right stuff or they simply will give you lots of grief. The program can sense suds. It cannot pronounce your wash clean if it thinks their are suds. So it try's to fix the problem and ends up overworking itself.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Soap coming out of washer
wrong soap check your use care guide for proper soap. check door gasket for anything on it. the smallest peice of debri can make it leak. over loading can make it leak
Dec 25, 2009 | LG WM2487H Front Load Washer
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Sep 27, 2009 | GE WBVH6240F Front Load Washer
Leaking from bottom of front door
hi..
Try checking the rubber boot from the door opening to the drum for signs of hole or cracking..
thank u
rate me!!!
Aug 19, 2009 | LG WM2688H Front Load Washer
Torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
Suds leaking from back of washer near top
Suds are not supposed to leak from the top; means you are not using the right detergent. Use front loading powders. You can open up the top during next wash to locate where the leak is coming from (after changing powder). I understand suds appear in the window during spin....but leak? Caution when machine works with top open!
rate if helped pl........
Dec 29, 2007 | LG WM1814CW Front Load Washer
Suds get stuck in the rubber rim of the washer
You are not supposed to use suds, use 'washing powder' for 'front-loading washing machines' which is available in any supermarket.
Sep 29, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Waaaayyyyy too many suds collecting in drain box after 2 back to back loads!
very much doubt problem is with washer - after all it just takes water in and turns. points the finger at the detergent or over-dosing
Apr 05, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
LG WM1812C Front Load Washer Logo
216 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
