Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine light on that says ,clean pump
  • marmejean May 11, 2010
    What is your washing machine?
My machine says clean pump what do i do
Posted on Jan 20, 2009
    Problem Solver:
  • 14 Answers
If this is a whirlpool front load washer I have a model# GHW9100LW1 which has a filter at the front bottom of washer there is three screws to be removed then remove cover this should expose the water pump which has a cap on the front take hold of the grip and turn counter clock wise be sure to have a towel handy for there will probably be some water that will come out after loosening the handle all the way the filter part should pull out remove the trash and replace back in the pump note the filter will only go in one way re-tighten the nut and replace the cover that should fix the problem.
Posted on Dec 09, 2008
A light came on to clean the washer. Is there something special I need to do?
Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
? 4:57
https://www.youtube.com/watch?v=4o9hWHQkOMM
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
Front Load Washer Pump Clean Out - YouTube
? 3:03
https://www.youtube.com/watch?v=f9uS8_0-pWY
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Nov 29, 2015 | Kenmore Washing Machines
Hi my whirlpool washing machine keeps stopping with the clean pump light on. I have cleaned the filter at the front and removed the pump underneath to clean it and to make sure there was no blockage. It...
Hello
There should be a clean mode.You need to get some E A high effic cleaner.And run the machine in Deep cleaning mode.
This will clean the machine and drain.
Apr 04, 2011 | Washing Machines
Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Mar 09, 2010 | Whirlpool Washing Machines
How do I clean my whirlpool washing machine pump? The red light of my washing machine is on and it is saying clean washing machine pump and my washing machine door won't open.
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clean Pump
The pump must be cleaned...u can call for the service technician.
Oct 13, 2009 | Washing Machines
Clean pump indication light on .how do i clean pump
dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Sep 11, 2009 | Washing Machines
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
