Question about Meritline KE1020 IP Phone
My KE1020A phone is notworking.giving me the waitlogin message all the time. it was ok till service provide stopped the dsl service forpayment. now dsl line is back, iam able to connect to the enternet but my ipphone is dead... ps. it happened samelast year and i had to run an upgrade through a certain link. can you help.
How do i get line in use to stop
Robert, make sure all phone are hung up correctly, unplug each connected phone one at a time till line in use disappears. When message disappears you have found faulty phone. If message does not disappear call your service provider.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 18, 2016 | Lands Phones
Tip
How To Enter Unlock Code Into Motorola Mobile Phones Step By Step Instruction...
Model: All Motorola; check below for exception
1. Insert an unauthorized Sim Card and turn ON your phone
2. "Enter Subsidy Code" box appear
3. Enter Unlock Code
WARNING: If one of these messages appears:
- "Contact Service Provider"
- "Tamper Alter"
- "Wait before enter special Code"
- "Contact Service"
It's because you or somebody already enter too many wrong codes, you just have to let the phone ON at these errors message (do not close the phone if V3) and after 40 minutes to 12 hours, the message " Enter Subsidy Code" will appear again.
Model: A1000 and other A series model
1. Click on the Phone icon
2. Enter **057*
3. "Locking Enter Personalization" box appear
4. Enter Unlock Code
5. Press Ok
Model: L6i & L7i (NOT L6 and L7)
1. Press and hold * key and enter 787090
2. "Menu Network" box will appear
3. Select Yes
4. Press OK
5. Will ask for code
6. Enter Unlock Code
Model: All Motorola 3G network model
1. Enter **057*
2. Enter Unlock Code
Motorola CDMA & TDMA
1. Enter 74663# [Menu] [Menu] and you will be asked for a Subsidy Code
Unlock Motorola CLIQ (SIM Unlock) 1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Motorola MPX
2. If the phone is asking for NETWORK PIN
3. Enter the NETWORK PIN
4. If the phone is asking for SERVICE PROVIDER PIN
5. Enter the SERVICE PROVIDER PIN
6. Your phone is now unlocked
Network PUK
If the phone is asking for NETWORK PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see an Engineering Menu:
1. Select Options
2. Select GSM Test
3. Select Send AT command
4. Now you will see a new window Saying "Send AT Command"
5. Enter AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN]"
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. Turn your phone off, take battery out. Put battery back in. Power on the phone and leave it for 40 minutes to 12 hours until the message "Enter NETWORK PUK" is gone. Now enter the Unlock Code and 00000000 (eight zero's) as a new password
Service Provider PUK
If the phone is asking for SERVICE PROVIDER PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see a Engineering Menu: 1. Select Options
2. Select GSM Test
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. If you do not have the original Sim Card or if the original Sim Card is not accepted because you flashed the phone with other firmware, then we cannot help you
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
on Apr 07, 2011 | Cell Phones
Voice mail answer
Call you service provider voice mail quicker by holding the 1 key wait till your messages stop then the automated voice will give you options to choose
Apr 16, 2014 | net10.com
Sir sigmatel t33 keypad notwork power on ok
you can contact the service provider.........
Aug 31, 2011 | Cell Phones
Pls stop message Mozook.com to my number 971556143596
Reply back to their text message with the following: STOP
Do not include anything else in the message. This should make the messages stop. After that, you can contact your cellular service provider and ask them to block Premium Messaging or Premium SMS on your line. This will prevent providers like Mozook.com from billing services to your account and sending you these type of messages. If at any time you want to sign up for a premium service, you can just call your provider again and have them remove the block.
If this solution helped you, please accept it, and give me a few thumbs up, thank you!
Mar 02, 2011 | Motorola Mobility W220 Cellular Phone
I had an unwanted wap message and I cant get rid of the wap logo from my screen can you help, also how can I stop these messages coming through. Ruth.
Hi, these messages can be a nightmare and without having the number to text them back and ask them to stop sending them all you can do is call your service provider and tell them the messages you want to stop, they then can stop them from being sent to your phone.
when you started getting these message they should have told you to stop getting these messages txt stop to this number but usually they leave it out so they can keep sending you these messages.
contact your service provider and they can stop them being sent to your phone.
its the only way you can get them to stop without having the number you need to send them the stop message so just give your service provider a call and they will then put a stop to them, they wont charge for doing this.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 30, 2010 | Sharp Cell Phones
My sim card is PUKed need puk code
Hi the only place you can get your puk code form is buy phoning your service provider this code is free and they will give it you over the phone some providers website give links to puk code but not all of them but contacting you service provider will give you the puk code this is the only way you can get the code let me know if you need further assistance ok
Feb 14, 2008 | Nokia 6102 Cellular Phone
I DO NOT KNOW HOW TO ULOCK THE PUK CODE
if your phone is asking for puk code then ring your operator and they will give you the code for free over the phone thats the only way of getting puk code as its different for every service provider but they will provide code for free so give them a call you can also get it off their website sometimes so have a look call them they give you code
Jan 02, 2008 | Samsung SGH-A800 Cellular Phone
Meritline KE1020 IP Phone Logo
201 people viewed this question
Top Meritline Computers & Internet Experts
David Payne
David Payne
Are you a Meritline Computer and Internet Expert? Answer questions, earn points and help others
