Question about Polaroid FLM-3225 32 in. LCD Television
Polaroid 32" LCD
How do i switch from hdtv back to reg. cable, no channels show up.
Whats the answer how do u switch to hdtv
Posted on Dec 30, 2007
No Power
Posted on May 12, 2007
SOURCE:
How do I get hd channels to show on sceptre 32 inch classic hdtv?
Silly question, but are you subscribed to the HD channels? Most cable companies include HD channels o higher tier subscriptions, and then require a different decoder box to get them.
Aug 06, 2014 | Sceptre X322BV HD 32 inch Class Television...
Hi, I can not see the analog or digital channels on my tv polaroid model tda03211c need help.
Hi wilij63,
Make sure that your cable wire is hook up properly, check for bad connections.
Let me know If symptom persist.
Jdvillanueva
Mar 04, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Vizio 32/DirecTV - slow to change channels
Some TVs switch faster than others, plain and simple. I went from a Sony LED to a Sanyo LCD TV and there's a world of difference between the two in terms of how quickly each powers on and how fast one channel goes to the next after inputting the channel number on the respective remotes. The Sony is lightening fast compared to the Sanyo. I have a Phillips LCD in a bedroom that takes a long time as well, like the Sanyo. Personally I think you get speed with either the LED (over the LCD) and/or it's related to the quality and associated price you've paid.
Dec 09, 2009 | Vizio L32 32 in. LCD HDTV
I have a TDA-03211C 32 in. HDTV LCD TV TV/DVD Combo that will play video games and will play DVD's but will not get any channels. It looked as if the picture tube was going out when it would show Tv...
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Nov 08, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Cable input is not working
Sounds like you mabe be on the wrong source. Try hitting the input button on the side of the set to change inputs. Input channel up or down find tv hit input again. If on the wrong input you will only get a blue screen and message no signal that will apear for a few seconds.
Sep 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Setting Polaroid 32" HDTV for 1080i
You must hook up into the hdmi in on tv or use the red blue green video hook ups and it will work switch itself dont forget the red blue audio cables!
Dec 11, 2008 | Polaroid FLM-3225 32 in. LCD Television
Olevia 32"lcd
All I did was switch out televisions and found that the DirecTV receiver was the problem.
Sep 13, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Red distortion
it sounds like your IR board is going out, its easy to replace and is inexpensive usually about 10.00 plus tax and shipping, and very easy to install, its one of the few parts you can buy for these models outside of the 479.00 dollar control box.
Dec 11, 2007 | Polaroid FLM-3225 32 in. LCD Television
Polaroid FLM-3225 32 in. LCD Television Logo
46 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
