Question about Nikon COOLPIX S6 Digital Camera
When i dont use the flash on a nikon it is blured
Whenever i take a picture in any type of lighting but decide not to use the flash my picture is blurred and the shutter speed is slower. it is on my nikon and also my fathers. is there a setting that i can adjust to fix this?
    Novelist:
  • 107 Answers
When taking a picture the camera needs a certain amount of light to hit the sensor before it can record a good image. If you are outdoors in the sun and the camera still takes blurred pictures due to a long exposure time then there is a malfunction. In bright lighting situations the camera should decide on its own not to use the flash. For indoor situations the camera has to either supplament the available light with the flash, or increase the duration of exposure to collect more of the existing light. There is no way around it - the sensor needs a certain amount of light to create a quality image. On some cameras you can override the shutter speed setting and force a fast exposure but without proper lighting you will just end up with dark images. You might also be able to override the F setting to the lowest possible value which would let in the most light. However, these cameras are generally very good at deciding how much light they need to take a quality image. If the flash is set to auto and the camera decides to use it then there is simply not enough light to get an exposure with a fast shutter time. This is one of the factors that gets better the more expensive the equipment is. Higher end point and shoot units and SLR units can collect more of the available light with their larger lenses and thus get good exposures in lower light conditions while still maintaining fast shutter speeds. Additionally "image stabilized" cameras help compensate for this situation by electronically assisting the photographer in stabilizing the image - allowing longer exposure times to be shot hand-held. You could also try a tripod if that is appropriate to your needs, that would help you shoot longer exposures in low light without so much image-wide blurring. Of course anything in motion will still blur. David Millier Advance Camera Repair
Posted on Feb 24, 2007
There is dust in my nikon s9300 lens help plz
Does the dust have an impact on the image (can you see blured points on the printed image ) if so you can get a quote for the cleaning and decide on the cost as it will not be cheap If the dust has an acceptable impact on the image you decide
Feb 09, 2016 | Nikon Cameras
Why does "raise the flash" come on the screen when I turn my coolpix s5090 camera?
I do not know allot about the s5090, but I can give you general information based on how most Nikon pocket cameras are designed to work. If the Nikon is set to one of the automatic modes it is designed to prevent you from taking a picture if it senses that there is insufficient light to get a properly exposed picture. The camera may be telling you to rase the flash because it needs more light. Also, somewhere on your camera there is probably a menu that allows you to choose the flash mode. It may be in your regular menus or, if your camera has a round left-righ-up-down switch on the back, you can select the flash mode by pushing up and then using the right-left keys to choose the flash mode. The mode you select is locked in when you push the button in the center. In general, the modes are automatic (the camera decides when flash is needed), red eye reduction (the flash activates twice; once to cause your subjects eye's iris to close and the second to take the picture), flash always (flashes regardless of the ambient light) and flash off.
Jul 12, 2014 | Nikon COOLPIX Cameras
I'm trying to take pictures without the flash but
You can shoot at faster shutter speeds if you raise the ISO setting. Also, turning up the lights will help.
Jan 12, 2010 | Nikon D40x Digital Camera
Everytime I take a picture with my Nikon D40 the pictures are...
Try holding the camera steady for a couple more seconds after you snap the picture.
Aug 20, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
My Fuji s2000 always shoots picture that are blured. I have tried many settings and different exposures however I keep getting the same result. What can I do ? The worst mode on this camera is the auto...
Found the same thing and I think the answer is the opposite of previous suggestions. The s2000 is truly awful at anything above about 400ASA The degree of pixel binning it uses just makes the pictures look terrible. Force the camera to use 400 or slower (lower numbers), force flash and I think you'll see a great difference. I was on the verge of sending mine back before I discovered this.
Ian
Aug 10, 2009 | Fuji FinePix S2000hd Digital Camera
Can't reset nikon D50 default settings
Press MENU and select the pencil icon to get to the Custom Settings Menu.
First select the "Detailed" mode under Menu > Setup (wrench) Menu > CSM menu, otherwise you'll only to get the first few items!
[R] Menu Reset: This returns everything below to factory default.
Dec 24, 2008 | Nikon D50 Digital Camera
Blurry pictures
Both of these problems are caused by underexposure. There are several causes for this. If you are set in AUTO MODE check the shutter speed and lens opening in the view finder. If the speed is less than 100 and the shutter is less than 5 and you are not using flash. You will probably get blured and dark pictures.  Practice shooting with your settings outside in sunlight , inside with lamplight, inside with flash and all of the above with motion. Check the exposure after each shot and make adjustments. In a short time you will get very good at setting your camera.
Dec 09, 2008 | Nikon D70s Digital Camera
The left side of my pictures are blured.
If it's been like that since Day 1, I'd guess either an improperly assembled lens, or a misaligned CCD in the body. Hopefully it's a warranty fix. If it has recently started, it may be due to impact to lens or body. Fingers crossed for the warranty situation.
May 20, 2008 | Nikon COOLPIX S200 Digital Camera
Nikon 5000 focus probs
Depending on how long you have had the camera - Nikon may come up with a free solution. Contact Technical Support at Nikon. The auto focus is not functioning as it should. Do make sure you are not covering any 'Windows' on the front of the camera when taking, shots.
Jul 19, 2007 | Nikon Coolpix 5000 Digital Camera
Nikon COOLPIX S6 Digital Camera Logo
78 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
