Question about Hotpoint Washing Machines
Hot point washing machine has a symbolF-08)
It has stopped working any programmes.it is flashing a symbol(F-08)i donot wish to pay for any service, i have an extented warranty.
  • Hotpoint Master
  • 3,463 Answers
F08 means heater relay cannot be activated..
Usual cause is faulty heater.
If you are able check the heater for continuity or an earth fault, then you will need a meter to do so.
If the heater and thermistor check out o/k, then you are probably going to have to call an engineer..
Please leave feedback.
Posted on Dec 07, 2008
My washer dryer stops in mid washing cycle and pause button flashes. Will not move on until I reset it
you could call a repairman of course . noone can assist you with no make/model listed .
Oct 16, 2015 | Washing Machines
What may be causing my washing not to finish the washing cycle
If you think your washing machine may be faulty, check the following points before calling a Service Engineer. These checks could prevent a charge being made for the Service man's visit if the machine is found to be in perfect working order.
Initially check the filter on your washing machine and clean if necessary, your manual should detail this procedure.
If your machine will not start or complete the programme, check:
  • The plug, the socket and the switch, if necessary, with another appliance.
  • The fuse in the plug.
  • That the door is closed.
  • That a programme is accurately selected.
If water will not enter, check:
  • The hot and cold hoses are correctly connected to the relevant caps and that these are turned on.
  • That a suitable programme has been selected.
If water will not drain, check:
  • That the outlet hose is not kinked or raised more than 40
Oct 22, 2014 | Zanussi FS1455W Front Load Washer
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
E20 fault, motor works intermittently
If you think your washing machine may be faulty, check the following points before calling a Service Engineer. These checks could prevent a charge being made for the Service man's visit if the machine is found to be in perfect working order.Initially check the filter on your washing machine and clean if necessary, your manual should detail this procedure.
  • That the outlet hose is not kinked or raised more than 40° from the floor.
  • If you wish to remove articles when the water will not pump out, place the end of the drain hose into a bucket on the floor and allow water to drain out by gravity, noting that more than one bucketful may be present. Hook the hose into the sink again and try the spinner before removing the articles - if this fails most of the water can be baled out with a cup.
  • If the above method fails to remove the water then the pump is probably blocked - do not open the door, but contact your nearest Service Engineer.
Apr 29, 2011 | AEG L16820 Front Load Washer
Machine cycle has nearly fininshed and door has started flashing. What do I do. Mandy
Aug 21, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
189 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
