Question about Kitchen Ranges
Kenmore elite ranghood (series# 550) not working
I was replacing 1 of 2 bulbs, & was unaware that the old bulb was shattered while still in the hood, so when I tried to screw the new bulb in place, sparks flew, the other bulb & the fan stopped working. The only thing that still works is the 2 little green lights that comes on when you press the button to turn on the light or the fan.
    Sergeant:
    Champion:
  • 338 Answers
Unplug the unit and unscrew the bulbs. put 2 new in if they still dont work then you may have fried the control. there are usually no fuses between the control and light/fan. well i never saw a fuse between the 2.
Posted on Dec 07, 2008
My kenmore elite washer keeps giving me the LE error
Kenmore elite 700 series triple action technology glass top load 5.3 cu ft.washer glass lid is shattered..can I replace the glass only or do I have to replace the whole lid top?
Mar 16, 2017 | Kenmore Washing Machines
Why is bulb so hot on cooktop light on Kenmore Elite Microwave Hood combination
depending on the type of bulb ( sounds like a halogen? ) turn it off for cleaning
Jun 26, 2014 | Kenmore Microwave Ovens
I need help on how to change a headlight bulb on my 2000 toyota tundra
  • 1 Open the Tundra's hood and locate the back of the headlight assembly inside the engine compartment.
  • 2 Unplug the electrical connector from the assembly and remove the rubber cover from the bulb socket.
  • 3 Release the retaining spring to loosen the old bulb, and then pull it directly out of the socket. Carefully dispose of the bulb to prevent it from cracking or shattering.
  • 4 Align the tabs of the new bulb with the cutouts of the mounting hole. Then, carefully press the bulb into the socket until it's secure.
  • 5 Install the rubber cover in its original position and reattach the electrical connector to the headlight assembly. Make sure the rubber cover is fastened to the socket before continuing.
  • 6 Start your Tundra's engine and test the headlights to make sure they work before closing the hood.
Jul 30, 2011 | 2002 Toyota Tundra
How to install headlights on 2002 toyota camry
I assume you mean just the bulbs:
  1. 1 Shut off the Camry's engine and set the parking brake for added safety. Also, make sure its headlights are switched off.
  2. 2 Open the hood using the primary and auxiliary hood release latches.
  3. 3 Locate the back of the headlight assembly and determine whether the low- or high-beam bulb needs to be replaced.
  4. 4 Turn the headlight bulb socket counterclockwise to remove it from the assembly.
  5. 5 Unplug the electrical connector from the back of the bulb. Carefully dispose of the bulb to prevent it from shattering or cracking.
  6. 6 Attach the electrical connector to the new bulb and insert it into the headlight assembly. Twist it clockwise to secure its position.
  7. 7 Test the new headlight to make sure it works before closing the hood.
Thank you,
Lee
Aug 25, 2010 | 2002 Toyota Camry
Headlite replacement
Step 1 Shut the Corolla's engine off and engage the emergency brake for added safety. Also, make sure its headlights are switched off.
  • Step 2 Open the hood using the primary and auxiliary hood release latches.
  • Step 3 Use a flathead screwdriver to remove the clip from the top of the air cleaner duct and pull the duct out of the engine2_bing.gif compartment (only when changing the passenger-side headlight.)
  • Step 4 Turn the headlight bulb socket counterclockwise to remove it from the assembly.
  • Step 5 Unplug the electrical connector from the back of the bulb. Carefully dispose of the bulb to prevent it from shattering or cracking.
  • Step 6 Attach the electrical connector to the new bulb and insert it into the headlight assembly. Twist it clockwise to secure its position.
  • Step 7 Test the new headlight to make sure it works before replacing the air cleaner duct (if applicable) and closing the hood.,I hope this helps you and merry xmas
  • Dec 18, 2009 | 2001 Toyota Corolla
    Light doesn't work on Kenmore Model 55022 Range hood...
    If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
    One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
    The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
    A.
    Apr 05, 2008 | Kitchen Ranges
    If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
    If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
    Jan 27, 2008 | Kenmore 51840 Kitchen Hood
    Kitchen Ranges Logo
    289 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
