Question about Leviton Antenna splitter
How do i install a 3 way antenna splitter - Leviton Antenna splitter
  • 417 Answers
If you want to install it 'in line' you need to cut the coaxial cable,then instal a jack plug on each end, connect these to the in' and out terminals then connect your third cable to the other out terminal.
Please remember to rate this solution.
Posted on Dec 07, 2008
Can you hook two tvs into one antena
yes --
got to places like Jaycar and get an antenna splitter
antenna shops will have it as well
does not have to be expensive unless you want more than 2 extra tv sets and then the internal circuit gets a bit more complicated
check the end of your antenna as they can be screw on or push on
Dec 31, 2016 | Televison & Video
I have 3 people in my house my husband in living room grandson in his room and me on my phone how do I get it to let 3 people watch different shows at same time
put separate tv's in each location and fit an antenna splitter (available from JAYCAR )in the antenna cable and run separate cables to each tv.
Sep 05, 2015 | Watches
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    Hello,I have purchased a digital converter to connect to my tv to receive local stations,My question is,What do i need to connect all 4 tv's that I have to the converter? or Do i need a converter for...
    The converter has only one tuner, this means it can only tune one station or channel at a time. The output of the converter is usually a single coaxial cable jack. The output is generally a user selected channel - often Ch 3 or Ch 4. When you connect the output of the converter to the antenna input of the TV, you set the TV channel to match the setting on the converter (again, Ch 3 or Ch 4).
    You could install an amplified splitter to split the output of the converter and run a cable from each TV to the splitter, more on this amplified splitter, later. Set all the TV's to the same channel as the converter output (Ch 3 or Ch 4) and you would be able to watch whatever the converter is tuned to. This means ALL the TV sets must watch the same channel. What is showing on one will be shown on all. This may not be a problem if you live alone and own 4 TVs. You could simply turn one TV off when leaving a room and turn on another when entering a new room. This will be a problem if there are two or more people in the house that wish to watch different programs at the same time. To accommodate everyone, you would need as many converters as there are different programs that are to be watched on different TVs at the same time - 4 would be a good choice to provide the greatest flexibility of tuning for every TV.. You would simply install the additional converters on the other TVs just as you did with the first TV.
    If you wish to use a splitter to divide the output of the converter to several different TVs (or have a single antenna and want to send the signal from it to several TVs for that matter), an amplified splitter is highly recommended. A standard splitter only divides the signal and has no provisions to boost the signal from the antenna. The more ways a signal is split, the less signal there is to supply to the TV sets. The result is a snowy picture. An amplified splitter not only splits the signal the way a standard, non-amplified splitter does, but also boosts the signal from the antenna to each TV. This provides a much stronger signal to the TV which results in a better picture. Pick an amplified splitter that has enough output jacks (based on the number of TVs you wish to connect).
    I hope this helps and good luck!
    Sep 13, 2011 | Televison & Video
    We have an antenna and 2 vizio HDTVs. The first one will no longer receive CBS, but the one in the bedroom does connected to the same antenna line. Why would one receive a sufficient signal, but not the...
    I recommend you check the connection from the line splitter of where the second TV is connected. IF you have a bad line splitter this is a common issue for other TVs connected to the same antenna. replace the line splitter would be the recommendation.thanks
    Jan 17, 2011 | Televison & Video
    How to program with cable using remote
    Hello
    1 Find and disconnect the cable that is connected to the
    ANT IN terminal on your cable box.
    ? This terminal might be labeled "ANT IN", "VHF IN" or
    simply, "IN".
    2 Connect this cable to a two-way splitter.
    3 Connect an Antenna cable between an OUT terminal on
    the splitter and the IN terminal on the cable box.
    4 Connect an Antenna cable between the ANT OUT terminal
    on the cable box and the B-IN terminal on the RF(A/B)
    switch.
    5 Connect another cable between the other OUT terminal on
    the splitter and the A-IN terminal on the RF (A/B) switch.
    6 Connect the last Antenna cable between the OUT terminal
    on the RF (A/B) switch and the ANT IN (AIR/CABLE)
    terminal on the back of the TV.
    After you have made this connection, set the A/B switch to the
    "A" position for normal viewing. Set the A/B switch to the "B"
    position to view scrambled channels. (When you set the A/B
    switch to "B", you will need to tune your TV to the cable box's
    output channel, which is usually channel 3 or 4.)
    OK
    Jan 01, 2011 | Samsung SlimFit TX-T2782 HDTV
    Vizio l37 When I try to scan the channels automatically the TV can find all the ones that comes from the comcast cable (62) but when stars to scan the digital ones freeze make me cancel the process and...
    you cann not hook an antenna and cable to a splitter together and expect it to work
    the only way that will work , if your tv had two tunners Try doing a scan with cable
    only on the cable setting
    Nov 03, 2009 | Vizio L37 Television
    Tv will not recognise an antenna
    Try to search for the channels using the antenna directly into the TV (remove the splitter) if you can pick up all the channels, then there is a problem with the splitter, if you still can't get anything, then most likely the tuner in the TV will be at fault.
    Oct 01, 2009 | Olevia LT37HVS 37 in. LCD HDTV
    FM/AM reception problem
    It should- that splitter is generally used for factory telephone reception and also there is an antenna located in the rear window glass. It will work for radio reception but it will interfer with your phone if you have a phone installed. just make sure you have a good antenna ground. Try removing the grond and sanding the metal so that there is no paint or oxidation that causes higher resistance. This generally affects a.m. reception.
    Jul 17, 2009 | 1998 Mercedes-Benz S-Class
    360 degree outdoor antenna radio shack
    What type of antenna is this. You will need 75ohm cable for this with good 75 ohm 3 way splitter. Please be sure that TV cable is not going to work.
    May 22, 2008 | Radio Shack Audio Players & Recorders
    Leviton Antenna splitter Logo
    99 people viewed this question
    Top Leviton Computers & Internet Experts
    ashburton
    Michael Galve
    Michael Galve
    Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
