Question about Broadcom BCM94306MP - IEEE 802.11b/g Wireless Internal Mini-PCI Card (BCM94306MPWIRELESS)
Radio on network adaptor disabled
I had just completed a live update from MS and after restartaing my computer, my wireless capabilities have disappeared. I now get the following error message when trying enable radio "the radio on your 802.11 network adapter is still disabled. Use the hardware radio control switch to enable it." Please help
  • Anonymous Apr 02, 2009
    "use the hardware radio control switch enable it" error messages appears after I have already checked enable radio.
    President:
  • 2,961 Answers
Look on your taskbar for 2 little screens with a red ross, right click and click enable or go to start>connect to>show all connections, then right click on your wireless connection and click enable.
Posted on Feb 19, 2007
SOURCE:
Does the asus cm5571 have wireless capabilities
Hi there
According to this webpage which gives the specs for the Asus, it does not have wireless capability built in
http://www.cnet.com/uk/products/asus-essentio-cm5571-br003/specs/
It can easily be used with a wireless network connection either by adding a wireless network PCI adaptor, or a USB wireless network adaptor. Neither of these are expensive and the USB adaptor is often preferred as it only needs a spare USB port on the machine and the computer does not need to be opened up as it does for the PCI adaptor.
Hope this helps
Aug 29, 2014 | ASUS Computers & Internet
I was having problems connecting to a network, somehow I hit disable and now it seems dead, I went into the icon and it says no card found, no lights nothing, how do I bring it back re- enable it
Assuming you're in Windows, Hit the start button, right-click computer/my computer, hit manage.
This will bring you to the computer management console. Open the Device Manager from the left pane.
Expand the "Network Adapters" option listed. From here, you can enable/disable your Network Card or check for up to date drivers.
Mar 01, 2011 | ASUS WL-100G 802.11g/b Wireless Adapter
Engenius wireless lan usb2.0 adapter driver
A lan adaptor driver is fixable by downloading from the network site of the USB 2.0.
important notes
1. Lan adaptors are outdated versions incompartible with recent operating systems. Acquiring a new USB device or even wireless modems are the latest alternatives to lan computer connections of the past. Modern wireless modem connection have built in installation kits,also present is the computers capability to recognise to integrate to a network.
Dec 21, 2010 | Computers & Internet
Wireless adaptor was working fine until xbox live update, and since the update is unable to pick up our wireless netowork. Tried switching everything back on and on and re synching modem with xbox, to no...
To connect your Xbox 360 gaming console to a NETGEAR router's wireless network:
  1. Turn off your Xbox 360 and disconnect anything from the I/O port on the back of the console.
  2. Insert your Xbox 360 wireless adapter to the I/O port as instructed by the wireless adapter manual.
  3. Connect the wireless adapter cable to your Xbox 360 I/O port.
  4. Flip up the network adapter's antenna.
  5. Turn on your Xbox 360.
    • If you are using an unencrypted wireless network, your Xbox should connect to it automatically and you do not need to proceed to Step 6.
    • If you are using an encrypted wireless network click the System tab, and then click Network Settings and continue with Step 6.
  6. On the Network Settings page, select Edit Settings.
  7. On the Edit Settings page, select your wireless settings on the Basic Settings tab.
  8. On the Select Wireless Network page, select your wireless network.
  9. On the WEP Network page, type your wireless network key, and then click Done.
  10. On the Apply Settings page, click Test Xbox Live.
  11. If this is the first time you have connected your Xbox 360 to Xbox Live, you will probably be prompted to apply an update. If there are no updates, the Xbox Live Connection page shows that you're connected to Xbox Live. Press the Y button on your controller to continue.
If testing the Xbox it says DNS failed, then update your NETGEAR router firmware:
  1. From your computer, open an Internet Browser and navigate to http://kb.netgear.com to download the firmware for your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. Click Router Upgrade on the top left pane under Maintenance, browse for the firmware downloaded and click Upload.
  4. Wait for the router to reboot.
Dec 20, 2010 | NetGear MA101 802.11b Wireless Adapter
Enabling wireless capablility
Your laptop should have a switch on the front or side that switches your wireless radio on. If this has been done you must right-click on the wireless indicator and you should see en enable option. These are the only 2 places you can enable or disable the wireless radio.
Oct 16, 2009 | Computers & Internet
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
Wireless connection problem
Right click,on my computer,Click properties,click device manager (on the left),Click the Network adapter,Click on the wireless adapter and click enable.Then turn the wireless radio off and back on as you have done before or just restart the computer.
Apr 05, 2009 | HP Pavilion dv9000t Notebook
Satellite 1410 PS141A
Goto - Control Panel - System - Device Manager - Network Adaptors. It will list any network device installed. If its listed then Right click the wireless device then click properties.This will then tell you if it is working properly and if the driver needs updating. Also it will tell you if the device has been disabled or not,if so just enable it
Oct 09, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Hi, whenever I turn on my wireless reception , a MS Dos-like, blue screen pops up and my computer reboots. The error centre said it is a wireless adaptor problem. Please help.
The blue screen of death is caused by a problem associated with the drivers for the wireless adapter. It is commonly called a "STOP ERROR"
download and run everest home from this site
click on Network, click on windows network. this will ID the wireless card you are using. google the card for updated drivers.(or e-mail me at mewms_14904@verizon.net
Aug 22, 2008 | Computers & Internet
Broadcom BCM94306MP - IEEE 802.11b/g Wireless Internal Mini-PCI Card (BCM94306MPWIRELESS) Logo
287 people viewed this question
Top Broadcom Computers & Internet Experts
Hollyecho Montgomery
Prashant M
Prashant M
Are you a Broadcom Computer and Internet Expert? Answer questions, earn points and help others
