Ipconfig command, pop up on the screen and then it disappears
  • DrFeelGod May 11, 2010
    That's not normal, have you ran a virus scan lately?
    Sergeant:
  • 236 Answers
Sounds you are running it directly form the RUN command window.
Go to START ~ RUN
type in cmd [enter]
this will open the dos window
now type in ipconfig and the data will be displayed in the dos window and not in a pop up
Posted on Dec 07, 2008
How d i ipconfig on computer
On your keyboard you have a button that looks like the Windows logo - We call it the start button.
1: Hold the start button down and then click the 'R' key.
2: Then you will see a box pop up, type 'cmd' and press enter.
(If your keyboard doesn't have this for some reason, go to your start menu and type 'cmd' and click enter (without ''))
(In windows XP you would have to go to the start menu, all programs, accessories, command prompt)
3: Command Prompt window is open.
(Black background and white writing)
4: Type 'ipconfig' and press enter.
5: DONE!
Nov 24, 2012 | YouTube Videos
Wireless is on but does not see any connections
Hold the Windows key and press R, then type CMD (COMMAND for W98/WME) to open a command prompt:
In the command prompt window that opens, type type the following commands one at a time, followed by the Enter key:
NOTE: For the items below surrounded with < >, see comments below for the actual information content, they are value substitutions from the previous IPCONFIG command output! Do NOT type <computer_IP_address> into the command, that won't work. Also, the < and > in the text is to identify the parameters, they are also NOT used in the actual commands.
Do NOT include the <> either, they're just to identify the values for substitution.
IPCONFIG /ALL
PING <computer_IP_address>
PING <default_gateway_address>
PING <dns_servers>
PING 8.8.8.8
PING yahoo.com
Right click in the command window and choose Select All, then hit Enter to copy the contents to the clipboard.
Paste the results in a message here.
<computer_IP_address> - The IP Address of your computer, obtained from the IPCONFIG command above. (For Vista/Win7, the IPv4 Address)
<default_gateway_address> - The IP address of the Default Gateway, obtained from the IPCONFIG command above.
<dns_servers> - The IP address of the first (or only) address for DNS Servers, obtained from the IPCONFIG command above.
If you are on a machine with no network connection, use a floppy, USB disk, or a CD-RW disk to transfer a text file with the information to allow pasting it here.
May 14, 2012 | Computers & Internet
Two computers have the same IP address
On either computer:
Get a dos prompt, by clicking start, run and type in cmd.
In the dos window type in "ipconfig /release" then "ipconfig /flushdns" and finally "ipconfig /renew". This should give the computer a new IP address.
If these steps fail due to some error popping up, reboot the computer into Safe Mode with Network, If you are still having the IP issue, run the dos window again and try the same commands. Then reboot the computer back to normal windows.
Hope this helps
Jan 30, 2012 | Computers & Internet
A computer on my network has the same IP address; this causes a conflict.
This will cause one of the pc's not be able to get online. each one of ip's is unique. First this will need little knowledge if the ip's addresses are assigned manually. If not, rebooting the pc most times resolves the issue. If this does not work you need to open you command prompt which can be done by clicking on start and clicking on run on XP, clicking on start and typing cmd in to search in the bottom whith the little magnifing glass and it will pop up towards the top of that same window(it will say ether cmd.exe or command window. Once you see the cmd.exe do a right click on it and click run as administrator. this will work for vista or windows 7 any versions. once a black box opens just type in where cursor is blinking "ipconfig/release" and press enter. once you see the blinking cursor just type in "ipconfig/renew" and give it a minute to connect. When you type in this command do not type the " sign just words. ipconfig commands are same for windows xp, vista and windows 7. Hope this helps.
Nov 04, 2010 | Computers & Internet
Hi my name is peter and i cannot get access to facebook and gmail my computer read internet explorer cannot display webpage
try refreshing your dns
open command prompt, click start then click run type cmd, click ok, black screen will appear, type "ipconfig /flushdns" hit enter
then "ipconfig /registerdns"
if still no go
go back to command prompt and type "netsh winsock reset"
Jun 05, 2010 | Acer Extensa 5630-6806 Notebook
How to release and renew the IP address in Win Xp.
Go to start
Go to run
type cmd
to renew the IP command is
ipconfig /renew
to releaed the command is
ipconfig /release
May 03, 2010 | HP Pavilion dv6000z Notebook
Security
ok , you need to set up a WEP key
so only u fam. can connect dont want pirates
ok go to ur command prompt and type in (ipconfig)
vista command prompt is on (all programs | accessories | then command prompt )
in xp go to ur start then RUN menu type (cmd) and run
should pop a black screen
type in (ipconfig) and hit enter
get the default gateway no.
enter that on ur address bar and go in ur router
go to ur wireless settings and make a WEP code
****if any pc in home is connected to wireless might be prompted for key code type the wep code u made and that should be it
,JULY
ps rate my service please
Apr 11, 2009 | Belkin (F5D7231-4) Wireless Router
How to find ip address
click on the start menu, then go to run and type in cmd and press enter.
after doing a new screen will pop up. in that screen type in ipconfig press enter and your local IP will be posted. If your looking for your router IP or the one that your ISP is giving you click on
http://whatismyipaddress.com/staticpages/index.php/lookup-results
and it will give you your external IP given to you by your ISP.
Mar 23, 2009 | Dell Dimension 1100 PC Desktop
I have no ip adress
Hit start>accessories>command prompt. Once the Dos screen appears, type in "ipconfig" and hit enter. You IP address will pop up
Aug 19, 2008 | Video Game Consoles & Games
We need a wep key please how do we get one
go into your computer, and go to run
type in
cmd
a black screen like you see in movies will pop up and it is called the command prompt
type in
ipconfig
in the command prompt
and the default gateway
write down that # it will look something like this
192.168.123.123
it wont be the exact amount of numbers or the same amount but to continue, you type that # in on your internet explorer browser and it will bring you too your router and its self explanatory from there, derek didonato
Aug 06, 2008 | Nintendo Wii Console
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
