Hi, Bought a formac mini disc , ( no external power source ) picks up power via eBay port ( green light on formac mini disc shows lit ) Refuses to register on my computer. Help, thanks, Peter
    Novelist:
  • 159 Answers
Peter, on the premise this is new to you and you didn't buy it with stuff you want to keep ...
It may not be mounting/showing up because it's not formatted -- the computer may be seeing it, but it's not capable of reading it, or there's a problem.
This runs off USB, not eBay, ports -- and, as you say, does not need an external power supply.
If you're on Windows XP or Windows Vista, you'll typically want to reformat to "NTFS" ... the default specifications, if you're given an option, will work fine.
Some documentation is here:
http://www.formac.com/webapp/support_enduser_faq_detail.php?faqID=72
Posted on Dec 07, 2008
  • Boogerhead01 Dec 07, 2008
    On second glance ... We may need some more details about what computer you have and what you want to do with it. If there's a possibility this is, er, "Formac", but you may be sharing between a PC and a Mac, you'll want to format to FAT32 (Mac just calls it FAT or xfat, if memory serves). If this is only for your Mac, go into Disk Utility and format the thing as the first choice in the Mac disk types ... non-case sensitive and journaled, if memory serves.
When i connect my laptop power pack/adaptor to a source of light the power light on the power pack comes on, but when i connect plug in the power pack/adaptor pin to the power inlet port at the back of the...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 17, 2011 | Computers & Internet
I connect the power source then i connect it to my computer and it don't turn on at all...no light. Whats wrong
needs to be recognized to turn the drive on via usb. if desktop, try a port on the back of the computer. Else go into control panel/system/hardware and delete and "unknown device" then right click on the computer in that applet and select scan for changes.see if it picks it up. also try cycling power to the drive while it is connected ( reverse order - connect then power)
Aug 24, 2010 | Western Digital 500GB My Book Pro-External...
The drive will not power up even though the green light is lit on the power block. Is this an enclosure failure or the drive itself? EZQuest Monsoon 120GB external drive. Firewire 400 & USB2 capable.
Most of the time, this is an enclosure failure at the interface between the drive and outside panel. Usually this interface consists of a small circuit board with the SATA connections on the inside that converts the signal to USB and power p[lug on the outside. If you can get ahold of a SATA/EIDE to USB adapter kit, you can take the drive out of the enclosure and attach it to this adapter, then plug the usb port into your computer and if the drive is good, it will be read as another HDD. These can be bought at a computer store or on Ebay for around 20 bucks.
Jul 23, 2010 | EZQuest Monsoon Hard Drive
Hi, it doesn't power up when I plug it in.
Sounds like the power supply has gone bad. If you interested in getting it repaired you can find me on ebay. Gtitubro is my screenname.
May 22, 2010 | InFocus ScreenPlay 5700 Multimedia...
First time charging up of archos 5,it has now been charging for about 14-15 hours. but the green light did'nt blink yet. it says after fully charge, the green light blinking. what can be the promlem about...
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
Mar 11, 2010 | Archos Internet Media Tablet MP3 Player
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Computer doesn't recognize the external drive
I asume the connection is via an USB?
Try another usb-port and see if that helps, if not try to connect the disc on another PC (maybe a friends pc) and see is that pc recognize the disc.
Nov 21, 2008 | SimpleTech Signature Mini 250GB External...
Computers & Internet Logo
David Payne
David Payne
