Question about Amana Heating & Cooling
I have an Amana Air Command 90 Gas Furnace. It works and the heat will kick in when I set the thermostat to temps like 74, 75, 76 degrees. However, the unit will then shut off and the temp in the house drops and I'll wake up to it being 63, 64, 65 degrees, etc. Thoughts?
  • 2 more comments
  • billpavlou Dec 07, 2008
    that wasn't meant to be posted as a solution - not sure what happened there
    Well even if I raise the t-stat all the way up to 78-80 degrees, the unit will finally kick on for varying times. sometimes 10 seconds, sometimes 60 seconds and sometimes minutes at a time. Even after it shuts and I leave it alone it will still come back on at some point. It then just shuts off and never seems to heat about 66-67 degrees.
    I know that I'm not making this easy by not adequately articulating the problem. Is there anything I can troubleshoot or something specific to look for as a way to elminate problems before having to call someone tomorrow?
    Again, I appreciate your help and patience.
  • Ken Bledsoe May 11, 2010
    Not really the button is the safety button on unit. The clicking sounds like the sparker trying to light pilot light. If it clicks repeatedly. What kinda confuses me is you move to t-stat manually and it starts, then let it go and it will not hold temp. right.
    Sounds like t-stat problem. How old it the t-stat? let me know. ken
  • 306 Answers
Ok try this. Take a small diameter wire about 6 inches long. Go down to the furnace and remove the bottom panel. locate where the thermostat wires go into your unit and with a small screw driver place the jumper wire the 6" one and place it on red and white leave the other wires in place including the white and red ones. replace the bottom panel unit should start immediately. If it does you just solved the problem t-stat is bad. Now if the clicking starts and doesn't start the pilot your problem is gas valve related. This is another thing to check. You have a flame proving device located at the last burner looks like a thick piece of wire. Take some steel wool and very gently clean the surface to remove the carbon that has built up on it. Try this first as it is easy to see if the flame proving device was dirty. let me know ken
Posted on Dec 07, 2008
I really don't know a whole heck of a lot about this kind of stuff. The thermostat is made by Honeywell and it digital, not sure of the age. I don't think it is a t-stat problem, bc as I investigated a little further, there seems to be a "clicking" noise associated at the unit. I removed the bottom panel of the unit and there is a switch on the left side that remains depressed when the panel is inserted and closed. this seems to be the source of the "clicking". Forgive my ignorance, but does that give more insight to what the issue could be?
My gas furnace and heat pump runs at the same time???
its likely the outside control unit board its supposed to only kick on gas only when the temp is at freezing..
or
the inside thermostat is not selected for heat pump, open it an look at the jumper / switch.
or just replace the thermostat , then return it saying you couldnt figure it out. :P
there are a lot more variables here after that you cant know how to check.
Nov 05, 2014 | Honeywell VisionPRO 8000 Programmable...
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
Achiever 90 plus igniting
be sure the heat anticipater setting on thermosta matches gas valve.
Jan 09, 2014 | Ruud UBHC Air Conditioner
Furnace problem
SHUT THE POWER OFF TO THE FURNACE, REMOVE THE THERMOSTAT FROM THE THERMOSTAT SUB BASE TAKE THE WIRE THAT IS ON THE R TERMINAL AND THE WIRE THAT IS ON THE W TERMINAL AND CONNECT THEM. TURN THE POWER BACK ON. IF THE FURNACE COMES ON AND WORKS FINE THEN ITS IN THE THERMOSTAT.
May 30, 2017 | Heating & Cooling
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
Amana PGD60C1152E no heat
Your thermostat Function 0170 must be set to "1" for Single Stage Heat/Cool. Function 0180 must be set for "0" for Heating Fan Control. Function 0240 must be set for "5" for the Heating Cycle Rate for your <90% Gas Furnace. If you have already done these steps or if, after doing these steps, you continue to experience a problem, you problem could be with your Gas Furnace. I'm including some links for information on your system and thermostat that include wiring diagrams.
http://johnstonesupply9.com/TechDocs/Amana/Package%20Units%20Gas-Electric/PGD%20Pkg%20Gas%20Ele/PGD%20Tech%20Info.pdf
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Mar 06, 2010 | Amana Haier AP125HD Air Conditioner
I have a TH8000 Vision Pro. It is controling a
Whats' so hard is the Honeywell thermostat has a built in 1@ differential. It is not adjustable.
You might ask your installer about a time delay relay installed in the furnace to break the thermostat heat wire (usually white wire).
Most time delay relays are 90 seconds. But that might be enough to reduce the furnace cycling.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Furnace runs but does not heat up the house to thermostat tempera
Did this problem just start? Or has it been a long term issue? Check for broken ductwork, return air pulling outside air in. Check supply air temps, should be 100-140° or more. And what is the outdoor temp? If it's 0° outside, 74° is doing good. Is the home insulated properly? And there is a small hole behind the t-stat where the control wire comes through the wall. Plug that hole, seal that hole to prevent cold air from fooling the t-stat. The furnace has 3 fan speeds and it may be in low speed. If so it should be in medium speed. I'd suggest a service tech doing this for you unless you are experienced in furnace repair.
Nov 02, 2017 | Goodman Heating & Cooling
Furnace blows cold air
Sometimes the fans kicks in by time ---or by heat...even if the heat cycles dont starts . Is this gas or electric,, name brand,.... model # ect...ect..
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
291 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
