Question about Hitachi 42PD8700 42 in. Plasma Television
HITACHI 42PD8700 not powering up
this morning i tried to turn on the plasma and it didnt turn on,i have checked the fuse and its ok,i was wondering if there is an internal fuse and how hard it is to get to it,i am very good at technical things so this would not be a problem for me to fix if i knew what the problem was.
thanks,
alan
SOURCE: hitachi pd7200 42" plasma
Its a know fault with these sets - PDU's fail all time, look at avforums.co.uk
Posted on Mar 13, 2008
SOURCE: ESA 42" plasma tv not turning on
I have a 42 inch plasma and I was watching tv last night on it and suddenly it turned off on it's own. I tried turning it off and on and nothing happened. Then I tried to unplug it and replug it and nothing. My remote does not work either. Anyone know what exactly happened? Did my screen blow or what? I hardly ever use the tv and I only had it on from 8:30 p.m. - 10:20 p.m. and it turned off. All the other tv's in my house worked fine - I checked them. Also, my dvd player and cable box is on the same power cord and both of them work. Any solutions or help would be most appreciated!!! Does it just need to cool down or did I burn something out? Help!!!
Posted on Nov 13, 2008
  • 1153 Answers
SOURCE: Hitachi Plasma TV _ AV300E
Depending on the way you hook up the media or cable box, this is what you look for, if you are in the video area then look for V1, V2, V3 or the right one if you are on the RF connection then it also has an A and B side. Try each
Posted on Feb 27, 2009
jhinsincity
  • 616 Answers
SOURCE: Hitachi Plasma P50S601 no picture sound OK
probably needs new scan drive board along with upper and lower buffer boards. it wont be cheap and its best to have a tv shop do it.
Posted on Aug 30, 2009
sethdileswar
  • 253 Answers
SOURCE: Hitachi 42PD7200 Plasma TV gone dead
this problem is from smps power supply of your tv circuit, may be power capacitor may be short , power transister may be short pls check some spair of power supply
Posted on Apr 06, 2010
TV Power Problem
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 26, 2016 | Hitachi 42PD8700 42 in. Plasma Television
My hitachi plasma 42 PD7800TA does not turn on ,not even the standby ,the fuse is fine ,dont know what else to do? thanks Tony.
Hello
The power regulator board in your Hitachi is not switching. It is an SMPS [Switched Mode Power Supply]. Normally for plasma TVs the power supply repair will be almost impossibele due to lack of component availability. If the fuse is OK, definitley the switching process has failed it it. There is an IC which oscillates at high frequency, whic its oscillation signals are given to MOSFET transistors to chop the incoming AC, converted DC voltage. These switched voltage is passed through SMPS transofrmers which it turn generates secondary voltages that goes to different circuit boards of your TV. The power board is the most important section in a Plasma TV. it must be perfect in every respect in terms of secondary voltages. If any one of this voltage goes over than specified, the main boar will get damaged. So it is adviced to replace it as card basis, rather than making "sugery" to it. The power supply board can be had from Authorised Hitachi Service centers. You just give the the exact model number of your Hitachi TV. They will give you the orginal power supply board. Never play experiments with Plasma TV. OK.
Jul 15, 2011 | Hitachi PlasmaSync CMP4202U 42 in. HDTV...
The tv wont turn on. tried unpugging it. didnt know if there was a internal fuse of relay switch i could trip.
a fuse you can replace also, if it has lights on, then it's not the fuse. Main fuse kills everything.
Jan 16, 2011 | Hitachi P42H401 42 in. Plasma HDTV
37" hitachi plasma tv doesnt turn on
If you have a light on ( standby light ), then I would say power supply fault, tv could be shut down because of faulty capacitors in power supply. if you dont have any lights at all , check fuse in plug,
( there will almost certainly be a fuse in the tv) but, that is for a tv guy to fix.
pete
Nov 10, 2010 | Hitachi 32HDX60 32 in. Plasma Television
Apr 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
I have a hitachi 42pd7000ma tv and i need a new ac power cable. where can i get 1 at in melbourne australia?
(03) 8361-5894
Call the above phone number from 9am to 4pm .. There you can get the required part.
The name of the shop is victoria television repair service.. They are authorised dealer for hitachi
Feb 02, 2010 | Hitachi 42PD8700 42 in. Plasma Television
No power
First off I did not see make or model. When plasmas die you have failure in either the power supply of the sustain boards. Do you have any voltage readings from va or vs ?
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
HITACHI 37PD5200 E Plasma dead.
The fuse is either open or it will have continuity do you have any standby voltages
May 14, 2008 | Televison & Video
Hitachi pd7200 42" plasma
unplug. leave off for a few minutes. small chance it will reset.
also, it might have lost its input setting and is no longer looking at the input you send the source signal to.
good luck
mark
Dec 02, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42PD8700 U
switch on the dvd player so it's playing, then do a new master tune. press the dtt/tv button so you are watching the internal freeview system, then press menu, then go to installation, and re-install all channels. the tv will then detect your dvd player in the intial set up/tune mode.
hope this helps..
Oct 17, 2007 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Hitachi 42PD8700 42 in. Plasma Television Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
