Question about Sony FD Trinitron WEGA KD-27FS170 TV
TV won't receive remote signals
Our t.v. (which we've never had any problem with) just began acting up tonight. The remote won't work with it any more. We changed the batteries in the remote first but no success. Then I tried the remote on my daughter's identical t.v. and it worked just fine on it. (Likewise I tried my daughter's remote on our t.v. but it didn't work either). Therefore, I've proven to myself that the problem lies within the television. Does anyone have any ideas about what the problem may be? Btw, I did make sure that both the transmitter and the reciever were clean of dirt and dust. Any help will be greatly appreciated!
  • Anne Burleigh Feb 18, 2007
    I forgot to mention that the t.v. works just fine if you use the manual buttons on the front of it.
    President:
  • 1,284 Answers
The remote receiver is probably bad in the TV. It is easy to check if you understand using a meter to test it.
Posted on Feb 23, 2007
Remote control won't work 10 feet away but if two feet away it works. What gives?
the remote uses light to send a signal to the tv. make sure there isn't anything interfering with the light signal. it could be dirty or the receiver could have dirt obstructing the light.
Mar 20, 2013 | Panasonic TC L42E50 - 42" VIERA E50 Series...
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
My logik L160STB11 freeview tv recorder won't record properly
mine did that then wouldn't recognise the hard-drive
Apr 25, 2012 | Televison & Video
My remote won't work and I used to be able to change the channel on the TV but even that dosn't work. I checked the cords. Changed the batteries;
Hello
First check its battery contacts for any rust or dirt accumulated on it. If so, contacts of battery will not touch properly, and the unit will fail to work. The second reason for malfunction is due to the infrared sensor inside your tV. If it is faulty, the set won't respond to infrared signal generated by the remote control. If so, eventhough remote control works properly, the set won't work with it.
Remote sensor comes just behind the infrared window at the bottom front panel of your TV. It is a replacable part and not so costly too. It is a three terninal component will look brownish black in colour. It will looke like this.
gopakumarg43_77.jpgThe procedure to check the remote control for its perfect working is described at a tip I've given and published by Fixya on Google. Type "gopakumarg43" on google search box, and get into my profiles. There you can see 'Tips and How To's" line, click on it. You can read it there. OK.
Sep 23, 2011 | Philips Magnavox 20MT133S 20" TV
My Phillips HTS3400/37 Home Theater System came with a remote control, as usual, but it just has stoped working.. I've been trying to make it work by replacing the batteries and it still appears to be...
Try this first on the original remote. Insert the batteries backward and make sure that they make contact with the terminals in the remote control(stick a piece of metal in there to make sure all the posts make contact), then take them off and install them correctly and see if it works, it's a long shot but i've had some luck using this method. now, for the question regarding if the new remote will work, well, i couldn't find the correct code for your receiver using the RCA universal control. The receiver brand(Phillips) is not listed so it probably won't. Here's the RCA control's codes. Just copy and paste the link. http://www.remotecodelist.com/remotes/rca/rca_rcu404.html
Aug 23, 2011 | Televison & Video
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
I have a Technika 24in tv / dvd. The remote works fine except some of the buttons do not perform the desired function. i.e. the dvd menu button does not bring up the dvd main menu but a system screen. I...
Hi
The software version decides the function that coincide with remote signal. If the remotes' infrared signal frequency differ to the receiving spctrrum of the software, it won't work well. You must have the remote of the present TV itsef to work in coincide with the button actions. Just get it. There is no other way. OK.
Jul 15, 2011 | Televison & Video
Hi, I have a Yamaha rx-v450 amp that won't change sound modes (stereo, hall, jazz, rock etc) from the remote control but it works from the buttons on the unit. I've checked my remote by pointing it...
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
May 11, 2011 | Yamaha RX-V450 Receiver
The remote won;t work
If it's a "Universal" remote and you've changed the batteries, you'll need to reprogram it according to the make/model of the remote. A remote that came with your receiver....
1. Check batteries, they may be dead or dying.
2. Is something blocking the remote receiving window on the receiver?
Remotes use infrared light to transmit to their matching devices and MUST have a line-of-sight path to work properly.
Apr 13, 2011 | Audio Players & Recorders
Dish remote won,t work if Visio E550Vl is in operation.
Hey there! Becki Barned with Dish Network here! The problem that you are having is interference with your tv. You can try to move your receiver away from your tv a little, just a few feet, so that the LCD tv is not affecting the signal from the remote.
Dec 23, 2010 | DISH Network IR Remote Control
Sony FD Trinitron WEGA KD-27FS170 TV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
