Question about Asrock ConRoeXFire-eSATA2 (CONROEXFIREESATA2R2) Motherboard
Hi, I have recently upgraded from XP to Vista 32bit SP1 and I am having problems using my soundblaster X-fi card. On boot, windows reports new hardware found and asks for the install disk. when I run the SB set up, it tells me it can not see any compatible device in the machine and quits! This is inconsistant though as sometimes it will appear to complete successfully, however I am still unable to get sound. I have tried updating the original (XP) drivers to vista compatible ones but still no joy..... anyway, a colleague suggested upgrading the bios. I have v1.7 on a ConRoeXfire-eSATA2 board and I found v2.00 on the web. I downloaded this and ran the installer and now my machine is stuck in a loop. It goes through boot (I can get to F2 and F8) and ends up at the page offering load these options - Safe Mode :- - with Networking - with Command Prompt - Enable boot logging - Enable low res vid - Last known good config - directory services restore mode (domain controllers only) - Debugging mode - Disable auto restart on sys failure - Disable drive sig enforcement Start Windows normally. Can anyone help me get my machine out of this loop please?
  • jazz1404 Dec 12, 2008
    Thanks Guys. I got so fed up in the end with Vista, having downloaded all updated and appropriate drivers from both Microsoft and Creative, that I reformated the drive and went back to XP! Now I have my soundcard working again and no issues with my other devices either. Vista may look pretty slick, but in reality it is far from it. Come on MS, get it sorted! You charge us enough for your products, at least make them hassle free. Thanks for your help.
  • DrFeelGod May 11, 2010
    Can you disable auto restart on sys failure and write down the error message you get?
    Vista is picky about changes in hardware so it might believe you've "transferred" it to another PC.
    Scholar:
  • 172 Answers
In many cases the hardware will not work under windows vista, although it appears to find the hardware and load the drivers etc. You may get some satisfaction by going to the website for the soundcard and looking for drivers for the card particular to vista. However it still may not work, this is a vista problem however and is one of hundreds microsoft need to sort.
Posted on Dec 09, 2008
Problem installing Vista SP1 on Asus G2s
If you tried to install Vista on the Primary drive and formatted the primary HDD your Factory Recovery Partition , most likely has been written over, it's gone. Choose one or the other , Vista or Win 7, start from the beginning, install a clean Vista load, formatting in the installation procedure, form a Vista Installation DVD, follow instructions, boot up, do ALL the Vista Updates, it will take hours of updates, rebooting, updates, rebooting. You will get to the Service Pack's 1 and 2, in 24 hours or so. Put on a pot of coffee and be patience. If you prefer Windows 7 use the same procedure.
May 09, 2013 | Computers & Internet
Having problem getting sound on recently installed ASUS A8N32 SLI. I've installed and udated Windows XP to SP3, as well as updated every driver I can. All sound devices report that their drivers are the...
It still may be that Windows doesn't use the drivers from the updates.I have a similar setup for sound and had to go to Altec to get the drivers needed for my Vista Ultimate,which you would think could "find" the driver neccessary....BUT NO.Also,,this might be dumb,but are you plugged into the right "hole" on the sound card,presuming you have a new card.I made the same mistake when I put in a SoundBlaster system and plugged in the wrong one.D'ooooh
Mar 19, 2010 | ASUS A8N32-SLI Deluxe Motherboard
Is it viata ready or what os do i need for epson tm-u220pb printer
The requirements for epson tm u series printers are.....
Windows XP, Windows 32bit: Microsoft Windows XP Professional 32bit SP3 English, Microsoft Windows XP Embedded 32bit SP2 and Microsoft Windows Vista Ultimate 32bit SP1 English
Windows 64bit: Microsoft Windows Vista Ultimate (x64) SP1, Windows Server 2008 Standard (x64)
Aug 10, 2009 | Epson TM-U220PB Matrix Printer
I'm using win2k pro sp5 can i do a vista upgrade?
How to dual boot Vista and XP (with Vista installed first) -- the step-by-step guide with screenshots
UPDATED | Got a Vista PC and want to install XP so you can dual-boot between them? Here's how to do it, in an easy, step-by-step format. Page 1 - Intro
Scenario: You want to install Vista on your PC alongside your XP installation, on the same drive. You have installed Vista already. (If you have XP installed first, check out our earlier tutorial on how to dual boot Vista and XP with XP installed first.)
Tutorial Summary: We need to shrink the Vista partition on the hard disk and create enough space for an installation of XP. This can be done in three ways - using the GPartEd Live CD, the DISKPART utility on the Vista DVD or the Vista Disk Management GUI - and we'll cover all three. We'll then install XP and install EasyBCD to reinstate the Vista bootloader which will be overwritten during the XP installation, and then use EasyBCD to configure Vista's bootloader to boot the XP partition.
Updated September 2008: This is an updated tutorial, based on our first Windows Vista/XP dual-booting workshop. The main differences are that we are now using Windows Vista SP1 and Windows XP SP3. EasyBCD has also been updated and this makes some of the steps in our first tutorial redundant - the whole process is now easier.
This tutorial has been tested on a VMWare 6 Workstation.
VISIT THIS FOR THE COMPLETE TUTORIAL :
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
Mar 16, 2009 | Microsoft Windows Vista Ultimate Edition
ECS 761GX-M754(V3.0A) Motherboard, No Graphics Acceleration in Xp
Were the correct drivers installed into XP.
It seems to me no video drivers are in XP and you are running on the windows ones
Nov 12, 2008 | EliteGroup ECS 761GX-M754(3.0A) Socket...
Extigy problem in vista
download the drivers for vista from soundblaster site.
Oct 28, 2008 | Creative Labs Extigy External Sound System
Soundblaster Audigy not recogized
if you have a legal copy of windows xp, you should use windows update and it should automatically list your hardware drivers also.
Aug 22, 2008 | Creative Labs CT4870 / CT4780 Sound Card
KWorld ATSC 310U on Windows Vista 32bit Problems
Hi, the real problem here is VISTA, despite Microsofts hoopla this program is not as good as faithful old XP. The driver base is almost empty and a whole host of software and hardware just will not work with it. I reccomend you go back to XP until Microsoft releases a service pack with driver updates and then upgrade to VISTA. Regards mistyman
Oct 01, 2007 | Pinnacle Breakout Box & Drivers for...
Asrock ConRoeXFire-eSATA2 (CONROEXFIREESATA2R2) Motherboard Logo
112 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
