Question about HP Pavilion m8120n PC Desktop
Replacing power supply HP M8120N
How do we disassemble tower to replace power supply?. We need to know the sequence of removing hard drives, fans, disc drives, etc. to get to power supply to replace it. It appears that the entire computer needs to be taken apart to get to the motherboard to disconnect the old power supply and install the new one.
  • Anonymous Mar 17, 2014
    replace hard drive hp m8120n
  • Anonymous Mar 19, 2014
    i replaced my power supply and dont remember where all the wires plug nto the motherboard, hard drive, an disk drives
  • HP Master
  • 1,314 Answers
Here is the link for the upgrade and service guide.
This one is just as easy as 1) removing the side panel; 2) Remove the four screws that hold the power supply into position; 3) Remove the power supply cables from the motherboard (NOTE: If the media bay reader is in the way, you remove the front bezel by pressing the release tabs on the bezel and it will swing open. Remove the one screw securing the bay in position, then slide it forward so you can reach the power cable to the motherboard.); 4) Remove the power supply cables from the hard drives, cd rom drives, and other peripherals inside the PC. 5) Remove power supply...sometimes there is a button to push and it will slide out, sometimes not. 6) Replace power supply, then reverse procedures.
Thanks and please take a moment to rate as fixya.
Posted on Dec 07, 2008
  • 134 Answers
System fan error
If you have replaced the fan and you are still getting a "Fan Error" then you have replaced the wrong fan. The system fan is not fitted to the top of the processor, it is usually fitted to the case.
Sep 08, 2013 | HP Pavilion m8120n PC Desktop
My PC start the fan is Loud But it doesn't boot. D: HELP!!! please
1.Sounds as if the power supply is not working.
2.Needs replacement by qualified tech or if you know how to disassemble and replace.
3. hard drive not getting the +12/+5 volts needed to boot.
4. no power to the mother board.
Jul 23, 2011 | Sony VAIO VGC-RB60G (027242690547) PC...
My HP pavilion has stopped running, no power to tower, just a blinking green light in the back of the tower. Everything else works fine monitor, printer. Do I need another power supply. My computer is 10...
I strongly advise you to replace your old (VERY OLD!!) PC with new one. Do not worry, you will not lose any data from your old PC if you will take hard drive off your old PC and fix to new one. Anyway, if you still want to keep your old PC (NOT RECOMMENDED) you will have to buy new Power Supply and clean up your PC inside.
Oct 24, 2010 | HP Pavilion a706n PC Desktop
I cannot get power on my computer. The green light is flashing and I can hear a ticking sound.
the sops power sypply is defect a few capacitors are not working you need to replace the whole power supply of the PC. easy to find in pc store.
Feb 16, 2010 | HP Pavilion a420n PC Desktop
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Need to remove power supply from hp dc5000
hi this might help tower and discharge static by touching frame of computer ...then pull out power supply connection on the motherboard and this usually is connecting to Hard drive and disc drive pull them out also then on the outside of the back of the computer you should see screws around where the fan is usually at the top of back of pc. unscrew and then it should come out..hope this helps good luck
Nov 05, 2009 | HP Compaq dc5000 PC Desktop
My HP a420n won't start after replacing cd-rw drive
Please try to remove all the connections from your computer and also connections inside the motherboard, the power cord for your hard drives and also the power cord from the power supply to your motherboard.After that, remove the memory and clean the pin by using an eraser of the pencil. And then insert again the memory stick and connect all the connections from the power supply to motherboard and everything. Lastly reset your bios and put it back to normal again. Hope this would help. Thanks..
Oct 22, 2009 | Computers & Internet
Dell tower desktop Dimension 5100. Tower makes whistling sound.
sounds like it could be a bearing in your hard drive. is this problem constant? If so, I would open up the tower and disconnect the hard drive and then power up the tower again. if the sound goes away--you need to get a new hard drive. If not, you could have some dust bunnies in your cooling fan.
Jun 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
The fan is very noisy
The post begs for the obvious answer: Replace the fan.
Now to be more polite, first you need to identify the failing fan and replace it.
A desktop system can have several fans. Case/processor fan (you can test to see if this is the effected fan by unplugging it for a minute or two from the motherboard (a couple minutes will not hurt the system).
The video card may have a fan on it (Often on the underside if a mini tower) Some video card fans can be easily removed but finding replacement fans can be a challenge. Normally if a video card fan fails, replace the video card.
Most often, the failing fan is in the power supply unit or PSU. If you are handy with electrical components, you can remove the PSU, remove the fan and replace it. If you are not handy electrically, replace the PSU.
Higher end system may have card cage fans to help cool hard drive/expansion cards and others have fans specifically to coll hard drives.
Most manufacturers have spare parts where you can buy parts or you can use google to find specific replacement parts or fan suppliers.
Jul 14, 2008 | Packard Bell Computers & Internet
Power supply fan is makeing a lot of noise
1) Unplug the power cord and give the fan a good cleaning
with a soft paint brush and a vacuum cleaner.
i.e. Let the fans spin up by the vacuum and than bring
the brush against it.
2) If this fails, it's time to replace the fan:
a) Upgrade or replace the power supply enclosure with more
power/higher quality.
This is usually a good investment anyway.
b) Replace the fan only as described below:
Open up the computer (remove sides)
Unplug all the power supply harnesses from
the mother board, drives and chassis fans.
Unscrew and remove the complete power supply
enclosure at back of computer (ie top of the tower)
Vacuum it out as much as possible.
Disassemble the power supply enclosure by removing
more screws and removing the metal cover.
Unplug the fan from the circuit board, remove it
and take it to a computer store/ builder.
buy another fan just like it
reverse the process to put your computer back together.
1) A new power supply should cost $65 to $120
depending on power and quality. The bigger the better.
But make sure it fits mechanically into the existing chassis
and that the AT generation matches ***********-board.
2) A new fan should cost $15 to $25. Makes sure it runs on
the same voltage, and that it is physically compatible.
Apr 24, 2008 | Computers & Internet
HP Pavilion m8120n  PC Desktop Logo
867 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
