Question about Konica Minolta Magicolor 2450 Printer
I have a problem. I am newly employed as a sysadmin. and i was asked to change the ip address of our minolta printer. But the problem i have is that, the printer is secure with a password, the do not know the password which was set. How can i reset back this password to default seetings? please help me. Regards,
    Sergeant:
  • 236 Answers
I beleive the default password for the 2450 is KM2450
Posted on Dec 07, 2008
Minolta printer IP conflict
try to change the network settings to AUTO ip
1)utilty/counter
2)admin
3)12345678
4)network settings
5)tcp ip
6
0NEXT top bar tap
7)change to auto ip and restart
8)do the same thing again and check if it gave you a new ip address
Mar 23, 2013 | Konica Minolta bizhub Office Equipment &...
Konica Minolta 250bizhub is this compatible with bt home hub 2.0 - the ip address previously set before home hub is not being allowed. is it quicker to change ip address or to change hub settings.
if you changed the hub then you have to re assign the ip. to re assign the ip, go to administrattor mode, then in this mode, go to admin 2, in admin 2, go to basic settings, then in basic settings, change the ip of the machine. consult from user manual to know how to get in "Adminstrator Mode"
Apr 07, 2010 | Konica Minolta bizhub C250 All-In-One...
Just installed printer and drivers via a network connection for Vista 32bit. I did this per the instructions Provided by Konica at ftp://ftp.minolta-qms.com/pub/crc/out_going/manuals/misc/km_vista...
I presume that the IP Address in the instruction is just an example IP Address. I don't know if your printer is connected to a router or to a Hub or Switch, but your printer's IP Address should depend on the device that provides the IP Address and the example is router. The first 3 octet of the Printer should be the same as the router's. So the setup should be router->printer then router->computer.
Feb 03, 2010 | Konica Minolta magicolor 2430 DL Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How do I input ip address in Minolta DI1610
press the Utility/Counter -> Network Settings -> IP address
Feb 09, 2009 | Konica Minolta Di1610 Copier
Magicolor 2450 Service menu password
Are you familiar with the printer's PageScopeWeb Connection.
You can access it with your web browser and reset the printer from that page. Instructions for IE are on page 117. The password is SYSADMIN. The printer's ip address is 192.168.1.2 per the manual. unless you have it networked with a different IP.
ftp://ftp.minolta-qms.com/pub/cts/out_going/manuals/2450/rg2450e.pdf
Hope this helps,
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 29, 2008 | Minolta magicolor 2400W Laser Printer
I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Oct 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Magicolor 2450 Printer Logo
682 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
