Question about Edimax BR-6104KP Router (BR6104KP)
Adapter to connect to electricity
Lately I disconnect the router, bud I forgot to put the adapter in de box, together with the router. Now, I want to connect the router again to my pc and Xbox 360 Live, but I can only find an adapter with an output of 9,75 or an output of 15 . At the back of my router is a message that says the router needs an adapter with an output of 12. Witch one can I use to feed my router with electricity?
    Guru:
  • 480 Answers
All you need to get it working is an adapter with :
12V DC, 0.5A Linear
For some device the "A" does not matter you can use one of 1.0 or 2..0
ok
Try to use one adapter that correspond to your router
And be sure the input is AC 240 volt
Posted on Feb 03, 2010
  • 468 Answers
It is also important not only Voltage of the adapter but also Current in mA
Posted on Aug 13, 2009
I forgot my password and username of my wifi
If your laptop is Still connected to Internet you can use the below ways:
  • Windows 7/8: Right click on Wifi connection name>> Select Properties and then check the Show Characters box. Doing this will display the password.
  • Windows Vista: Right click on Wifi connection name>>Select either Connect or Disconnect. Then, select Properties, check the box next to Show Characters and retrieve your password.
  • Windows XP: You will need to download WirelessKeyView, which is explained in the next section. If your laptop is not connected to Internet:
  • You need to reset the Wifi Adapter.
Dec 05, 2013 | Buffalo Technology WHR-G54S Wireless...
I'm having an issue with my DI-514 wireless router. I can connect fine when the router first boots up. My laptop will stay connected to the router all day. The problem happens when I disconnect from the...
Open Device Manager. In the Device Manager window, click the plus (+ ) sign next to Network adapters to expand the selection. Under Network adapters , click to select the appropriate wireless LAN adapter. On the menu bar, click Action and then click Properties . In the Properties window, click the Power Management tab. On the Power Management tab, click to uncheck the box next to Allow the computer to turn off this device to save power . Some WLAN adapters have another power saving setting in addition to the one on the Power Management tab. Click the Advanced tab and try to locate a power saving setting. If it exists, disabled it. Click the OK button.
Aug 06, 2010 | D-Link DI 514 Wireless Router (DI-514)
My wireless adaptor can't connect to my router lately
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 13, 2010 | Microsoft Wireless Network Adapter Xbox...
The router seems to disconnect me at random times - also lately I have noticed a fluctuation in speeds and strength of connectivity even though i am sitting in the same place.
This could not be a router issue. Please call your Internet Service Provider regarding this and let us see that it can do from their end to correct this.
Nov 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Not connecting to internet
Did you try going into your network connections and deleting all the connections and putting the new one in manually?
That fix works for me all the time.
Oct 20, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
I have the same problem too
Try this procedure:
To Spoof a MAC Address
  1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records.
  2. Disconnect other computers from the router.
  3. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.)
  4. In an Internet browser type the address 192.168.0.1.
  5. Type admin for the username, password for the password, and click OK.
  6. Go to the Basic Settings > Router Mac Address.
  7. Select Use Computer MAC Address.
  8. Click Apply. This automatically gives the router the computer's MAC address.
  9. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Jun 06, 2009 | NetGear DG834G Router
Netgear wireless adapter disconnects from router randomly
check for firmware update for your adapter...since it usb..u need to put it in open..i believed the USB extension is included when u purchased that.
do not connect the USB adapter to a USB hub unless the HUB is powered so that it can performed better. Connect it directly to your PC slot
Mar 13, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Need to connect router to deck top.comp.
This might work for you. Now to go in and configure the router thats something totally different.
To physically install the router
Step 1: Connect the power adapter Connect the power adapter to the router and plug it into an electrical outlet not controlled by a wall switch.
Step 2: Connect the router to the computer Disconnect the ethernet cable that is connecting the broadband modem to the network adapter in the computer. Connect the ethernet adapter in the computer to one of the LAN ports on the router.
Step 3: Connect the router to the modem Connect the ethernet port on your broadband modem to the WAN port on the router.
Step 4: Check link lights and connections
Check the front of the router to make sure the Power, WAN and LAN1 lights are on.
Jun 29, 2008 | Computers & Internet
How do i connect up my router
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
Edimax BR-6104KP Router (BR6104KP) Logo
101 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
