Samsung SyncMaster 931BF LCD Monitor Logo
A
Anonymous Posted on Jul 01, 2012
Factory default settings for Samsun SyncMaster 931BF
Reset
5 Related Answers
Anonymous
  • 85 Answers
  • Posted on Apr 01, 2008
SOURCE: samsung syncmaster 713bm hoe can i reset it to factory settings?
Im not so sure but i downloaded the pdf and it should be in the menu open from the monitor
http://downloadcenter.samsung.com/content/UM/200506/20050602113228171_BN59-00420Y-02Eng.pdf
Anonymous
  • 233 Answers
  • Posted on Dec 21, 2009
SOURCE: I can't get my SAmsung SyncMaster 931BF to come of
I already post solution for this problem, click here to see the solution.
Anonymous
  • 45 Answers
  • Posted on Feb 23, 2010
SOURCE: Hooked Samsung SyncMaster 931BF monitor to laptop
This looks like a driver/resolution problem. Which laptop are you using? New laptops shouldn't give you any hassles, but older models don't always have the graphics cards to support all monitor sizes.
Make sure your monitor driver is installed on the laptop and that you have the latest graphics drivers installed for your laptop.
You can download the screen driver here: http://driverzone.com/device.php?id=55741
Then check that the resolution for your monitor is set correctly on your laptop under display properties. The native resolution for the screen is 1280x1024.
Hope this helps,
-LL
santosh.m santosh.m
  • 75 Answers
  • Posted on Jan 30, 2011
SOURCE: want samsung 17"syncmaster 794mg default
press menu button and hold it above 6sec
Anonymous
  • Posted on Mar 27, 2011
want samsung 17"syncmaster 794mg default display settings
Samsung FX2490HD 24" HDTV LED Backlit Widescreen Monitor. Can I factory reset my Syncmaster FX2490HD
It sounds like you are in the Store Demo Mode. Turn it off and see if that fixes it.
https://www.manualslib.com/manual/145519/Samsung-Syncmaster-Fx2490hd.html?page=27
Reset
Reset Samsung FX2490HD LS24F9DSM to factory state
monitorsfaq.com https://www.monitorsfaq.com > Factory reset > Samsung
How to restore or reset Samsung FX2490HD LS24F9DSM. Reset to its factory state Samsung FX2490HD . How to hard reset monitor. Clear all settings or format.
2helpful
2answers
Samsung SyncMaster BX2450. What are the default settings for Brightness, Contrast & Sharpness?
Hi Peter, you can do a factory reset to get the TV back to factory settings however I doubt that will fix anything, generally a washed out picture is a bad tcon board, main board or the panel itself, if the set has a tcon I'd try replacing that as it's the lowest cost board and generally causes the issues you're seeing.
How to unlock Samsung SyncMaster 320px?
This video will give you the instructions!
https://www.youtube.com/watch?v=JfzGO8KfKJE
How to open case/shell of Samsung SynMaster 931BF???
You remove all the screws, stand, then useing the thin flat blade screw driver to crack open the case, starting at the bottom edge and work your way around, it is hard to tell you in words. Try Youtube also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
2answers
How do you reset colors
Try going into on screen menu and and look for factory reset on screen menu. You may have VGA cable problem or it can also be the video card. Please try this monitor on anther PC to see if the problem goes away.
Hooked Samsung SyncMaster 931BF monitor to laptop and the letters on the screen are choppy. I can play with the settings on the monitor but can't get the letters to line up straight.
Hope this helps,
-LL
I can't get my Samsung SyncMaster 931BF to come of of sleep mode?
My monitor's color is mixed with the color yellow
There is an option on the monitor to reset colour to factory default. Just bring up the on screen menu by pressing the left most button at the botton. Use the button next to this to highlight the colour settings which I think is the 5th or next to last option down. You will then see the option to reset colour and various other factory default settings. Happy computing
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
