Humax lu23-td2 tv built in freeview wont work
I have a humax lu23-td2 tv and it will not pick up any channels except 1 2 3 4 and 5 it starts to scan auto and gets to 50% and just stops dead and will not pick up the dtv channels pleae help...
Hi there I have a humax lu20-td2 won't scan for channels
If it wont scan anything, you possibly have a broken tuner. On some models you can change the tuner yourself , on others you will need to send back the unit for repair.
If its build in then forget about the " diy" repair, however if you see 2 screws (each one on the left and right side of the cable input) you can take the faulty tuner out, and replace it with a new one.
Apr 07, 2015 | Humax Televison & Video
How do i unlock Humax LU23-TD2 TV
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.
Visit the associated blogsites too.
Sep 21, 2014 | Humax Televison & Video
DVD output to TV not displayed
So you have HDMI off of the PVR into the TV and AV off of the DVD Player into the PVR at the moment? Just for info what connectors do you have at the back of the tv, dvd and pvr? In's and out's...
Feb 28, 2014 | Televison & Video
Setup humax lu23 td2
have you tried plugging other any other components to the ports to see if it does the same thing
Dec 01, 2013 | Televison & Video
Humax lu23 td2 cannot retune it say menu not avaliable when i press the menu button
Is tv being used in the av modes if so tuning menu will not show. Possible cause could be external units like dvd player are taking control . Unplug all external unit and try menu again
Regards Derrick
May 13, 2012 | Televison & Video
I have a Humax LU23-TD2 Flat Screen LCD TV and I think the fuses have blown. Anytime I try to plug it in (has only been twice) i get a flash and a bang.
I have the same tv, has started to give out a few seconds of black screen on the odd occasion whilst watching-might b going the same way.. the tv repair bods might b your only solution if u dont know any electrician that could give it a test
Dec 29, 2009 | Televison & Video
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
May 12, 2009 | LG RH266 Recorder
Same problem Humax LU20/TD2 TV; Virgin remote
Apr 13, 2008 | Televison & Video
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
