A black hose about a foot long fell off my m'cycle. It's the fuel drain hose, I was told. It probably was connected by a clamp. I can't afford the manual, but does anyone know exactly where this gets hooked up to without taking apart the seat and cap covers to locate?? Many thanks!
SOURCE: Yamaha Virago XV700 - 1987 Seat Removal
Most Yamaha models have 2 bolts holding the seat on, usually located between the top shock mounts and the side covers. You should be able to find them without too much trouble, but remember- they are metric. Hope this helps.
SOURCE: 2003 yamaha v-star 1100 gas cap assembly
You are probably not going to find assembly instructions. If you can't find all the parts or screws then get another cap. Google " motorcycle salvage yamaha " and you can probably find one at a much lower cost than the dealer would give. By the way, forget any loose screws in the gas tank. The stuff can not get past the fuel valve and filter and are not going to hurt anything.
Please rate this answer. Thanks!
SOURCE: 1985 Yamaha xj700 Maxim- Carb. fuel lines
yes, the breather line hooks to the petcock on the line facing the back, the fuel line hooks to the larger one. the line from the breather is actually a vacume line that turns on the fuel, without it you will not get fuel out of the petcock unless it is in the prime position.
SOURCE: How can I remove the rear seat of a Yamaha Virago
The rear seat is held in place with a single bolt near the rear of the seat. This bolt is normally a socket head type (you use an allen key to remove it), is near the centre of the rear fender and also usually holds the rear rack or grab bar in place. Once the bolt is removed you may need to shift the rear of the seat sideways one way or the other in order that the tab on the seat clears the grab bar or luggage rack. The front end of the rear seat is secured under a tab so after removing the single bolt, simply slide the seat toward the back of the bike and it will come free.
SOURCE: I have a yamaha roadstar 1700 need to know how
Your bike takes a little over 4qts of oil. The engine drain plug is located on the lower left front of the motor. The oil tank drain plug is located on the bottom of the oil tank, on the right side of the bike.
When refilling, put in about 2.5 quarts of oil in the tank and start the bike and run it for about minute and blip the throttle a few times. Then add the remainder of the oil. Run the bike to operating temperature (approximately 15 min) and allow it to idle for about 3 minutes. Then check the level after a minute or so and adjust as necessary.
