Beko WMA 765s washer, power works no display
Hi at the end of a washing cycle my washing machines display went blank. It had finished drain but door had not unlocked. Powered of at mains and on again display came on briefly 1-2 seconds showing the usual 1 min remaing again door not unlocked. Repeated on/off and got really quick display flash and click of door relay.
Checked water depth pressure switch tube and it is clear, tried resetting using press and hole stop 3 seconds etc no luck, oh and cleared filter etc, atleast i know it fully drained before stopping :)
So left with machine that when switched on only light is door latch light and nothing else, visually inspected motor and belt all seem fine.
Help please really cant cope with the stress this is giving my girlfriend :)
  • Daniel Marsden Dec 07, 2008
    HI barkencoa
    Door mech working fine it lights up and opens. The problem is that none of the other lights are working at all, I was hopeing that is is a safetey mech that prevents the machine from fully powering up such as the pressure switch or motor check? But i am guessing that it is going to be he either the display board or main PCB :(
    Thanks for your promt reply and trying for me
    Not the best time of year for a 2 yr old washing machine to decide to pack up but hay we just have to smile. :)
    Yep just been doing that :) no luck on loos conections and girlfiend is baking a 18th birthday cake for a friend so Im out othe kitchen for the moment think i will give taking the display completely out and put back it may just have flexed over time and poped somthing on the front loose...... nah but hay i can hope
    I found an online parts site and the display board is only £20 ish delivered may just give it a go if above doesnt work.
    Thanks agian for your promt and helpfull replies
    Danny
  • Washing Mach... Master
  • 3,463 Answers
If there is power and lights are showing, but the door will still not open, then it could be one of several things.
First and foremost the door lock could be faulty, or the door handle or latch mechanism could be faulty or broken, if the door lock is not getting power then it is probably the main cotrol unit at fault.
I feel you should get someone to look at it for you.
Posted on Dec 07, 2008
  • Barry Coates
    Barry Coates Dec 07, 2008
    Hi
    It does sound lik display module, if you can remove the top, check for loose or bad connections to control board, you never know!!!
  • Barry Coates
    Thanks Danny.
    Good luck.
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
Beko WMA 765s drum not turning. What would the possible cause be? And how do I get the door to open to retrieve my washing so I can work on it?
sounds like the motor has quit. take off rear panel and check for bad wires and to see if the belt is good or bad. it may be broken
Oct 07, 2014 | Washing Machines
Beko washer is leaking water from underneath
This video will show you in detail how to replace the door seal gasket and fit the new one properly to a Beko washer that is leaking water from underneath washing machine How to Replace Beko washing Machine Door Seal
Jan 24, 2013 | Washing Machines
MY BEKO 765s washing machine, has stopped working mid load, on the display it is flashing iL but its smaller, it has also gone onto pause, and wont go on to start, also on flashing on 1200. This was a...
Hi if your beko 765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Dec 31, 2010 | Televison & Video
Door will not open on my WM1480FHD after wash
Hi ii_goldie,What about the RINSE cycle... maybe the washer knows the "full cycle" is NOT finished.
The washer will display DONE... and make the door available to you. If not the cycle may not be finished. OR, turn it off, however, DON'T open the door if your machine has not drained all the water out, allow the system to finish.
Aug 19, 2009 | LG Washing Machines
Washing machine wont spin and only drains when it wants to
This means to just restart the wash cycle. But I say the culprit is the lid safety switch. Make sure it is not stuck. This is the main reason washers will not spin.
Jun 19, 2009 | Washing Machines
Beko WMA 765 s - water will not drain from machine
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Good Luck!!!
May 06, 2009 | Washing Machines
Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Apr 11, 2009 | Washing Machines
Beko WMA 510 stuck on cycle
Hi if your beko WMA 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Sep 05, 2008 | Indesit W 123 Front Load Washer
Beko WMA 1715s - won't respond
door lock switch could be your problem..
Aug 30, 2008 | Whirlpool LCR5232H Top Load Washer
Washing Machines Logo
284 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
