Question about Car Audio & Video
Where could i locate the wiring diagram for a sony xplod 4ch 600w amp number xm-zr604
  • Anonymous Mar 26, 2014
    Dont know witch one to use
    Sergeant:
  • 300 Answers
This manual has the info regarding how to wire the amp.
Posted on Dec 07, 2008
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
Hey i have a sony amp (600 watt xm-zr604) with 2 10"sub(sony xplod).when i raise the volume hight enough the amp go off(red light came on) what can i try
sounds as though (at high volumes) the amp thinks it has a short circuit. This may be caused by the way you have them connected.
Speakers have a resistance and amps needs a certain amount of resistance to function right (too little resistance = short circuit)
The way it works out for the speakers is, if the two are connected to one amp output channel, the amp will see half of the resistance of a single sub. (4 Ohms/sub amp sees 2 Ohms)
If the amp instructions say that it's 4 Ohms/channel then you need to use 1 channel for each sub.
Hope this has been some help.
May 07, 2011 | Sony Xplod 800W Class AB Bridgeable...
Amp xm-ZR604 keeps going into protect mode
check the ground and the positive wires to make sure that they are getting good continuity. if your amp is too small for the speakers you are pushing this will also put the amp into protect mode
Feb 09, 2011 | Sony - XM-ZR604 4/3 channel car amplifier
I have a 04 silverado with factory bose stereo. I have installed a Xplod xm-zr604 and the sub is playing but it will not crank up. Its as if the volume is very low.I have tie in after the factory amp for...
If you dont have a line level converter with adjustable output - get one.
Your amplifier only amplifies the signal it gets - and if its a very low voltage - you wont get as much output from the ampifier.
I always recomend PAC converters. They are a little more expensive - but are #1 adjustable, and #2 they also make one with voltage sensing. You wire up a positive power source, and when it detects voltage from the speaker wires - it will send a remote turn on to your amplifier. (MTX has this technology built in to its amplifiers)
No more crawling under the dash or removing the factory radio!!!
Thanks for using FixYa - a very Helpful rating is appreciated for answering your FREE question.
Jul 23, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
My 600w power amp XM-554ZR wont turn on.Its an Xplod 4/3 channel, and it was working fine...until yesterday that i checked it. the green light was off.
open it n there is a red wire look at the end of it n u would see a black celinder with a with a white strip on it change that part if it is burn
Jul 14, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Can this amp xm-2252hxcan be use to drive a 800 watts sony xplod
yep, you'll be safe. It's capable of delivering 225W x 2 RMS and 600W x 1 RMS into 4 Ohm loads.
Jun 18, 2009 | Sony XM-2252HX Car Audio Amplifier
Xplod amp will not get off of power protection mode
if the protect light stays on the amp is blown or has flawed components and is only repairable by expirenced sony tech
May 18, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
220 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
