Question about Vision Computer GT8000-Pro PC Desktop
Gt8000 fused i have a samsung gt8000 had a short on the power supply but now the laptop wond power uk on new power supply but still works on battery cwhich has been charged on my sisters laptop. is there a fuse or something needs replacing
  • tony632 Dec 08, 2008
    no tried a different power supply but nothing. think its a blown fuse on the motherboard but not sure were or what the fuse would look like thanks
    suppose it could be. would this happen on a short.
  • 107 Answers
Sounds like you need a new power jack
Posted on Dec 08, 2008
  • Eric Mitchell
    Eric Mitchell Dec 08, 2008
    Not the power supply the jack inside the laptop(the port where the supply plugs into on the laptop), Most likely the soldering came lose.
  • Eric Mitchell
    Eric Mitchell Dec 09, 2008
    Yes and no it can happen (melts cheap soldering) but best change is external dammage
How to tell if a105-s4074 satellite battery is bad
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 28, 2012 | Toshiba Satellite A105-S4074 Notebook
Tip
The Most Important Considerations of Using Laptop Battery
1, when no external power supply situation, if the working conditions at the time slot being less than PCMCIA cards, it is recommended to remove the card first to extend battery life.
2, room temperature (20-30 degrees) for optimum battery working temperature, the temperature is too high or too low, the operating environment will reduce battery time.
3, can provide stable power supply environment, using a laptop computer, remove the battery for extended battery life is not right by. On Asus notebooks, when fully charged battery, the battery charging circuit will automatically shut down, so the phenomenon of overcharging does not occur.
4, the recommended average of three months to conduct a battery power correction action.
5, to minimize the number of NIKON en-el3e battery
The battery charge and discharge is directly related to life, one charge, the battery a step forward to retirement. Suggest that you use an external power supply,
6, the use of an external power supply when the battery removed.
Some users often plug the power several times a day, and the laptop is equipped with batteries, do more damage to the battery. Because each access to the equivalent of an external power supply to charge the battery once the battery life shortened by a natural.
7, after the exhaustion of battery charge and avoid the long charging time
Regardless of your notebook to use nickel-metal hydride or lithium electricity, to power after the exhaustion of a certain charge (charge less than 1%), which is the best way to avoid the memory effect. Lithium also have memory effect, but its memory effect smaller than nickel-metal hydride Bale.
8, the usual precautions
When used in peacetime to prevent exposure to prevent damp to prevent the erosion of chemical liquids, avoid contact with the metal battery contacts, etc. happen.
When you purchase your laptop battery
Laptop battery life - as no more than 3 to 4 years, it may be users of the most likely to replace things. Two years after the laptop, you will find the battery consumption and faster. If possible, you can replace the old batteries for new batteries to ensure the stable operation of the computer.
When the need to replace the notebook computer batteries, best to choose the same type of battery replacement. However, if the old computer using a nickel-metal hydride batteries, to make a longer battery life, of course, can also be specified by the computer user manual or manufacturers recommended models use lithium batteries. Although the nickel-metal hydride batteries for cheap, but there is memory effect, and in the same capacity than the lithium batteries under the weight of large, and lithium batteries have no memory effect, light weight, power supply for a long time, etc., has become a standard notebook computer batteries . Lithium batteries used in notebook computers at this stage because the different manufacturers in the power of time there are some gaps, and friends in the purchase process should be noted that different brands of the difference in the Sony vgp-bsp13/s Battery, the best among several brands compare.
Performance battery power supply in addition to the stated time manufacturers, but also need to pay attention to their capacity. Battery capacity is usually AH (ampere-hour, ampere-hour) calculated with the current laptop is 4000AH most about, and a battery can last for 2 hours or more. In addition to the battery power supply time by the whole power of computers and the impact of factors such as heat dissipation, the screen size (bigger and more power), screen brightness, and the implementation of the work and so will affect the power of time.
Now the price of laptop battery up and down the ocean in 1000, accounting to 10% of overall price notebook - about some of the ultra-thin models or even higher. The battery warranty period, is guaranteed 3 months, and is guaranteed six months, the longest, but also for 1 year; the reason why the warranty time is short battery laptop battery is easy because of consumables, the number of charge is constant, with a little time. Moreover, the laptop battery and other hardware different, there is no room for repairs, can only be a new one. The products of such a long warranty (replacement), intangibles to increase the burden on manufacturers, so buy laptop, be sure ask the battery warranty period and conditions.
Also in the purchase of second-hand laptop computers, they also do not forget to try it inside the battery can continue to work long. Under normal circumstances, the use of one or two years after the laptop is fully charged, the nickel-metal hydride battery can support about 1 hour or so computers at work, lithium-ion battery can support nearly 3 hours, but relative to the terms of this new battery requirements are already very low, and able to meet this target from the scrap to the battery of far away.
Causes of Damage Laptop Battery
Notebook computer CANON nb-6l battery a long time, often charge less for electricity, and even shows the battery is damaged, the specific performance of a larger resistance, the voltage across the charging up faster. So easy to charge control circuit is judged to have been filled, the capacity will naturally decline. Since the battery internal resistance is relatively large, the discharge voltage drop when a large, fast, so the system is easy to mistakenly believe that the voltage is not enough, lack of electricity. Comparison of the discovery of short battery life, should take appropriate measures.
If you need replacement laptop batteries, There are two professional battery shop
UK http://www.global-battery.co.uk/laptop-batteries.htm
US http://www.sales-battery.com/laptop-batteries.htm
on Dec 09, 2010 | Computers & Internet
Will not switch on. The light does not come on when plugged in at the mains
check the power supply, most have a little light on. might sound daft but if its a uk plug or has a fuse fitted in the plug that may have gone. try a different power supply, maybe take to a computer store and just ask them if they will try it on one of their power supply's as a test, of it works you can get multi fit power supplies quite cheap from well known auction sites. if it turns out it is not the power supply, it could be a fault on your main board, a fault with the power in socket (i have a toshiba and the pin inside the socket always breaks off, ive changed it several times) or more commonly to the older generation laptops, it ould be the battery. sometimes the battery completes the charging circuit, again knock off batteries maybe found cheap from well known auction sites, and alothough not always of great standards, they are better than paying toshiba for one and finding its a board problem.
Nov 20, 2009 | Toshiba Computers & Internet
I had a problem with a short circuit that burned my ac adaptor, since then my XR-1 Laptop does not work on battery power. It charges and recognises the battery and works fine on ac power with the new...
This condition can be caused by plugging in an adapter that has polarity reversed (that's what I did with an after-market power supply). Your battery is probably not bad (I changed to a brand-new battery, and it still had the same problem). However, the problem is deeper: I'm tracking down which component on the power board was burned out when this happened. No luck so far.
Sep 10, 2009 | General Dynamics Itronix GoBook Notebook
How to fix short circuit on Samsung X20 laptop?
sounds a lot like the power controller chip is shot. you will need a schematic and correct replacement parts..www.samsung.com might have a service manual for that.
Oct 09, 2008 | Samsung X15 Notebook
Hp power supply failiure
Ive worked on a friends G7000 series laptop, since it had the same symptoms you have with yours.
I tested it on my own(identical) working charger/PSU and still no charging.
After taking the motherboard out, i traced the fault to a short circuit FET (field effect transistor) with the PCB reference of PQ1, located right next to the connector for the DC power jack loom.(short from gate to source) The FET is made by Fairchild Semiconductors and its part number is FDS6675BZ. Being in the UK, i ordered the part from www.farnell.co.uk at a cost of 56pence. After changing this FET(which is there to control power) the laptop is working.
If you are not good with very intricate surface mount soldering, then i suggest you buy the component, take the motherboard out of the laptop(not too hard) and take them both down your local TV repair shop for them to check and change it(tell them the board reference PQ1).. shouldnt cost more than £20 or so been as they dont have to fault find.
Martin
martinkwashere at hotmail dot com
Feb 26, 2008 | HP Pavilion dv6000z Notebook
PC Will not boot
This flashing will indicate the problem to somebody who knows the flash code, the only people will probably be samsung, manufacturers are reluctant to publish these sort of things; for their own reasons. My guess is a processor or motherboard fault, but these replacements can become more expensive than a replacement notebook in some cases. It will probably be worth your while getting in touch with their support team http://www.samsung.com/uk/support/
Apr 13, 2007 | Samsung V25 XVC 2800 Notebook
Vision Computer GT8000-Pro PC Desktop Logo
66 people viewed this question
Top Vision Computer Computers & Internet Experts
David Payne
David Payne
Are you a Vision Computer Computer and Internet Expert? Answer questions, earn points and help others
