Question about Philips 32PF9966 32 in. HD-Ready LCD Television
Total Factory default of Philips 37pfl9703
I would like to know how I can reset my Philips LCD to factory default, as if it is out of the box. So, I will get the first initial setup when I power up the TV.
Thanks in advance,
Ereck
    Problem Solver:
  • 11 Answers
Hold down menu button on set until it does a factory reset
Posted on Mar 05, 2009
Hi, I found the solution, and tested myself on a 3000 series LED tv from PHILIPS.
press 062596 and then press i or info button.
you will enter service mode.
go to the function number 0043(if i remember well)
this function will have the option to press ok to reset.
press ok and for a second the "press ok" message will stop from blinking, then will keep blinking.
go to the final function from the list, which is exit menu
press ok
turn off tv
when you turn it on again, the tv will be as turned on for the first time and ask you country and lenguage, etc...
good luck!
Posted on Aug 08, 2010
All that did was make the screen turn green? still no picture tho
Posted on Jul 21, 2009
    New Friend:
I am used LCD 32hf7443 LCD used option communication later on not working LCD remote control pl z if any factory setting pl z any solution that my working remote controal
Posted on May 18, 2013
  • syed ather ali May 18, 2013
    plz any factory rest code
How to resert colour on philips tv model 37PFL5522D/05
there will be an option on your controls that allows you to reset.
go to colour
select factory default
Aug 12, 2013 | Philips Silver Tilt/Tilting Wall Mount...
How to return philips 40pfl7705d to factory settings
I don't think it has a factory reset but Philips would know if they or a authorized service center will talk to you----both are generally not very helpful.
Dec 03, 2012 | Philips 40PFL7705D 40 in LCD TV
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
I have new Philips LCD 47"tv and on the bottom
HI:
You may of turned on the Philips Easylink which is for connecting Easylink-compliant devices that are connected through HDMI connectors can be controlled by a single remote.
You can restore the default picture and sound settings of your TV.
1. Press MENU
2. Select SETUP> Installation>Then Factory settings.
3. Select Reset to start resetting
5. Press OK.
6. Press MENU to exit.
Jan 24, 2011 | Philips 42PFL5332D 42 in. LCD Television
Do not know know password for wireless internet
Hi
Go here and download the manual http://static.highspeedbackbone.net/pdf/Netgear-WNR2000-manual.pdf
You will need to reset the router or change the password in the router 1. To change the password, goto Internet Explorer 2. In the address bar type 192.168.1.1 3. Press enter key 4. YOu should see a box with username and password fields. 5. username is admin 6.password is password 7. These are not the wireless passwords but the access password to get in the router. 8. Once in the router interface on Internet Explorer; goto the wireless sections and change the password there.
To reset the router WARNING: This will reset all the settings to what it was like when it came fresh out of the box. You may need to know some other settings. Restoring the Default Password and Configuration Settings You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 5). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Failing this, please refer to the manual, page 29 onwards
All the best now
Phil
Dec 17, 2010 | NetGear WNR2000 Wireless Router
Philips Model ID 20pf5120/28
Recently, cable has gone digital. You might not be able to get a signal anymore with rabbit ears. They suggest buying a converter box. You can always try restoring factory settings...
Jun 15, 2009 | Televison & Video
I need to know how to reset my monitor to factory defaults
Factory Setting & EEPROM Initialization Method
Factory Setting Method
- Connect the signal cable and power cable to the LCD monitor.
- Press Power switch with pressed MENU key.(Menu key + Power key).
- Then, a User can change the factory setting value in OSD menu.
- Save changed value and Turn off the power s/w.
- Turn on the power, adjust the screen.
Apr 15, 2009 | Hyundai ImageQuest 19 L19T LCD TFT 19" LCD...
Philips DVD622 Factory reset
Go to http://www.philips.com and search for your modal then look in Q/A's or just look in the manual for the factory reset....Usually found in the on-screen menu!
Jan 10, 2008 | Philips DVD622 DVD Player
Hardware reset
Double-clicking the System icon in the Control Panel opens the System Info dialog box.You can use this dialog box to allocate thin client memory and reset the thin client to factory defaults.
The General tab contains a check box that allows you to reset the thin client to factory defaults (the check box is active for administrators only).
You can reset the thin client to factory default settings by selecting the *Reset the terminal to factory-default property settings* check box (the System Settings Change message displays and you can confirm and follow the instructions provided to reset the thin client).
Mar 01, 2007 | WYSE Winterm S30 Network Terminal
Philips 32PF9966 32 in. HD-Ready LCD Television Logo
6,755 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
