Question about Sony Electronics - Others
How to open and replace tweeter (5cm, cone type) for Sony HIFI
I have pinched and crumpled tweeter on its cone, see pics..
is there anyone who can provide me procedure how to remove its tweeter and how to replace its cone paper (i bought spare cone paper)..
http://s222.photobucket.com/albums/dd209/kremlinreyes/?action=view¤t=Tweeter.jpg" target="_blank">http://i222.photobucket.com/albums/dd209/kremlinreyes/Tweeter.jpg" border="0" alt="Photobucket">
http://s222.photobucket.com/albums/dd209/kremlinreyes/?action=view¤t=SS-RV8.jpg" target="_blank">http://i222.photobucket.com/albums/dd209/kremlinreyes/SS-RV8.jpg" border="0" alt="Photobucket">
2 Suggested Answers
Grubhead
  • 5309 Answers
SOURCE: how to replace cone paper
I doubt if you can! I would think it better to replace the tweeter. If you can't get an excat one replace it with a different one and buy two one for the other channel, the sound will then match up.
If you try to do it the problem will be getting the coil to slot in the magnet without scraping. Your probably need special equipment and that's why it will be hopeless.
Posted on Jan 30, 2009
My Ashdown amps tweeter cone plastic screw on surround has broken and the amp is old now. It's a ABE 400 combo and I think the part is probably not in production anymore.......any ideas? Cheers
Either you can get a sutiable tweeter to be fitted which matches the size and fits correctly.
If the amplifier is good order it can be restored , if not as mostly the older generation has moved off it will be difficult to replace the board or components. You can fit in a newer version of a power amp board.
Jun 26, 2012 | Ashdown Audio Players & Recorders
I have Behinger Europort EPA900, One speaker crackles, tried swopping cables etc, but nothing helps, the problem seems to be definitely with the speaker.
Open the speaker and look for loose connections. Carefully move cone with fingers. If there is noise when doing so...rubbing type noise, speaker needs reconing or replacing. If the crackling comes from teh tweeter section, then the tweeter may need replacing.
Jan 31, 2011 | Behringer Europort EPA900 Ultra compact...
Tweeter is cutting in and out
need to open up speaker and check connections on tweeter. Check closely on tiny wires from magnet(voice coil) to paper cone
Jan 04, 2011 | Samson Resolv 65a Main / Stereo Speaker
Printing pictures photo paper gets jammed half way?
There are many reasons why your photo paper gets jammed, but here the most common ones:
- The photo paper is crumpled, or the edges are fold. Be sure that the paper is completely straightened out before putting it in the feeder.
- Your tray lock is larger than your paper. It is recommended that you keep your tray holder lock the size of your paper. The best way is still to keep a .5cm allowance.
- There is something blocking the feeder which causes the paper to go out of track. Are you sure there isn't a crumpled paper or torn paper left with the feeder?
HTH!
Dec 12, 2009 | HP LaserJet 5200 Printer
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
How to replace cone paper to 5cm tweeter
Dec 07, 2008 | Electronics - Others
Need to replace 11L tweeter
the best solution I've found is this:
1. Remove all the tweeter screws.
2. Take a thing metal rod (a coat hanger should work) and lightly tap the tweeter through the top port in the rear until it is loosened and comes out. The tweeter is totally sealed so you probably won't damage it if you need to do this to a working tweeter.
This method also works for the woofer but you need to be very careful to tap the frame or magnet of the woofer and not the cone.
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
Electronics - Others Logo
257 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
