Question about Photography
How to open and clean inside viewfinder and prism in Nikon F100
I didn't use my f100 for about 3 years.
i have humidity or moisture on the inner side of the viewfinder and pentaprism of my nikon f100 .it is visible from the viewfinder and from the body - where the focus screens can be changed. i already screwed off the first lens of the viewfinder but it seems to be on the inner side.
please tell me how to open it .e.g. what are the screws i need to take off, what part to pull ..
  • Bart Pulverman May 11, 2010
    What brand of camera?
    Your question as posted is not complete. Where is the moisture? Your positing reads, "i didn't use my f100 for about 3 years. i have humidity or moisture on the inner side of the..."
5 Suggested Answers
cammedic
  • 667 Answers
SOURCE: F100 rubber grip peeling
double stick tape is what I would use. mosts glues are to thick and not compatible with the body materials
Posted on Jan 29, 2008
SOURCE: Nikon F100: Multiple exposures, delayed exposures
Thanks for your email. In the meantime I learned my problems were not uncommon with early production F100s; the culprit is the switching circuitry under the film advance mode dial, which has to be replaced. Essex Camera of Carlstadt, NJ, will do the repair, including general service, at a cost of $ 150. Sincerely,
Tom
Posted on Sep 09, 2008
SOURCE: Nikon D80 Autofocus problem
Try re-setting the camera? On the D40 it is 'Menu' scroll down one to Custom Setting Menu (a pencil) and click reset 'ok' yes 'ok' this worked for me.
mistersony
  • 320 Answers
SOURCE: Loose Manual Focusing Lens Device
There is a bulletin (E31529192) that describes your exact problem and recommends replacing the screws with new different screws to prevent this from happening again. The front section around the lens assembly is only held by 3 screws so access isn't a big deal, just be careful if you try this because there is a cable connected to the microphone that is easy to damage. The new screws are part number 3-056-559-01. Be sure to rate this solution. Thanks!
Posted on Nov 01, 2008
SOURCE: Nikon D40X stopped auto-focusing yesterday
I had the same problem. My issue was with all my lenses. I solved it by going to the menu and selecting the custom setting menu (pencil icon). Then from the right menu select the AE-L/AF-L and press OK. Then make sure it is set on AE/AF Lock. Presto...all my lenses worked on auto-focus.
Posted on Feb 20, 2009
I have a very noisy fridgidare upright freezer causing snow on contents inside it?
Hi Lisa, thank you for your post! New freezers retain colder temperatures. Especially on hot humid days, moisture entering the freezer (when the door is opened) can form frost inside the appliance and moisture collection inside the unit. Reducing energy use to meet government requirements, defrost heaters have shorter run times. Light loads in the freezer also contribute to the problem.
Here are some tips to keep moisture low in the freezer:
Use your air conditioner to reduce humidity.
Arrange shelving and food items so air circulates.
Don't "overload" or leave the freezer empty. It should be at least half full.
Set the controls as recommended in the use and care guide. Manufacturers may suggest different settings for summer and winter.
Properly seal liquids and high moisture foods stored in the unit.
Open the freezer doors as few times as possible.
Clean condenser coils at least twice a year. Check your use and care manual for specific procedures. You'll save energy, too.
Cover pots and pans and use the range hood fan when cooking to reduce moisture in the kitchen.
Check and maintain door gaskets. A good door seal keeps warm moist air out of the freezer.
These tips will help control frost and moisture in your freezer, but won't always eliminate the problem, especially when humidity is excessive. If you have taken all necessary steps to prevent moisture and humidity, you may need to reach out to a professional for further diagnosis.
Hope this information helps resolve this issue.
Aug 22, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Looking through viewfinder i see dirt & black specks
It depends where the dirt is. Following the light path, look at the rear surface of the lens. A dirty rear lens surface will have the most affect on picture quality or what you see in the viewfinder of any position in the light path. Like all optical cleaning procedures, hold the lens with the rear lens surface facing the ground so gravity will work with you. Start by blowing clean air on it using canned air or a blower such as a Rocket blower or ear syringe. If that is sufficient, do not continue the sequence. This holds true at the conclusion of each step because the more aggressive your cleaning becomes, the more risk there is of damage. If it is still dirty, gently brush it with a sable or camel hair brush. If that is not sufficient, gently wipe it with a dry lens photograph lens tissue (do not use coated tissues) or a microfiber cloth. Finally, as a last resort, dampen a corner of a lens tissue or microfiber cloth (do not put the wet solution directly on the lens) and gently wipe with a circular motion. Finish by wiping with a dry section of the tissue or cloth. Although the front surface of the lens is not as important, repeat the process for the front surface.
If you still see the dirt in the viewfinder, are two possible remaining locations; the bottom surface of the prism located above the mirror or the mirror.
Clean the prism first and avoid cleaning the mirror if possible, or any contact with the mirror. The prism can be cleaned following the sequence outlined above. If that doesn't work, the problem is the mirror.
CAUTION! The mirror is front surfaced and is very susceptible to scratches and other damage unlike a conventional mirror which is rear surfaced with the glass protecting the coating. Aggressive cleaning should be avoided.
Carefully follow step 1 of the lens cleaning procedure (air) and step 2 (brushing) if necessary. As far as the third and fourth steps, I would not use them myself because of the risk of mirror coating damage. It would be better to take your camera to a qualified repairman.
remove the lens and look above the mirror at the bottom of the viewfinder prism. If it is dirty, clean it as you would clean a lens surface. The next place to look is the mirror.
CAUTION! The mirror, unlike the mirror over your bathroom sink, is front surfaced and there is no glass between you and the delicate and easily damaged coating. Hold the camera with the mirror facing down so that gravity will work in your favor. If that does not work, I would stop and take it to a camera repairman because you do not want to risk scratching the surface by using lens tissue or cleaner.
Feb 05, 2013 | Nikon F100 35mm SLR Camera
The screen of the viewfinder has a black dot.. i tried to clean it but it cant be removed,..how can i removed it?
Remove the lens of your camera, do it in a clean room, look at the mirror insie the lens to see if the dot is not there rather that on the outside of your viewfinder.
If it is not there it might be on the inside part of the focusing screen. Still inside the camera look at the upper part of the body, the focusing screen looks opaque.
If you still cant find the dot it might be on the inner side of the focusing screen.
Here is a tutorial on how to remove it on a d70 it is essentially the same thing on your camera.
Otherwise it can also be on the inner part of the viewfinder. In this case I recommend to send the camera to a repair shop as the removing of the viewfinder seems to be more difficult on the d3000 than on other camera.
Hope this helps.
May 30, 2011 | Nikon D3000 10.2 Megapixels SLR Digital...
When I looking through camera you see almost a prism affect. Ideas?
If you're looking at it through the front then you will as there is a pentaprism inside feeding the lens view through to the viewfinder so that it displays the right way up and right way around. Almost all SLR's have them which is why they have a hump on top.
As long as the image in the viewfinder is correct then there's no problem. If the prism effect is visible, then the prism has become dislodged and on an N65/F65 it's not really worth repairing. The camera is very definitely a consumer grade model which was never intended to be dismantled for major repair and as there are millions of perfectly good free ones available (late, consumer grade, 35mm AF bodies from most manufacturers are seen as worthless liabilities) there's really little point in attempting a repair except to gain knowledge of how your camera comes apart. If you manage to dismantle, repair and reassemble without breaking anything or finding other broken and unobtainable parts inside then it's a bonus.
If you want to find a free SLR then check out FreeCycle: you may need to check often and be patient but they do come up. Be flexible: you may have to accept any make or model but if they come with lenses then it's no problem. Most of the freebies are Nikon or Canon anyway so if you need to stay with Nikon then it's not a major problem. I recently got a boxed and barely used F75 kit with a 28-100 lens and all it needed was new batteries and film.
Aug 30, 2010 | Nikon N65 35mm SLR Camera
Nikon F100 suddenly went dead
Which battery holder are you using? The small one or the grip MB-15? If it is the MB-15 make sure it is screwed in tight. If it is the small one then make sure your batteries are in the correct direction. If that does not work call Nikon Film 1-800-645-6687.
May 16, 2010 | Nikon F100 35mm SLR Camera
How to brighten the viewfind on a Nikon F 100
If you think the screen is dirty then you can remove the view finder screen inside the camera from the lens opening. Also, there are other view finder screens that you can purchase. Read page 65 of the F100 manual to see how to change focus screens.
Nov 04, 2009 | Nikon F100 35mm SLR Camera
I have condensation/moisture in one of the two lenses of my Nikon Action 7x15x35 binoculars
Nikon Action binoculars are not meant to be 'waterproof'. They give the specification to the Chinese factories to construct the bincular to the retail price point. The higher the cost the more features. Water can damage the inside of a binocular as the contaminants in water can cause fungus to grow. Once that happens the glass lenses or prisms are damaged.
You can try to dry them near a warm air source such as blow heater on warm not hot over a period of time. This will help evaporate the moisture. It will not help if fungal bacteria has started to form.
Depending on the use that caused the influx of moisture you may have a warranty claim.
Aug 21, 2009 | Optics
A dirt on a A200 viewfinder from inside (not the mirror)
Never touch the mirror... it will leave a mark. Is it underneath the viewfinder ? If it's not in the viewfinder, how do you know you have dirt. If there is dirt on the sensor, that's a decent pro job. Special ways to get to the sensor and cleaning is a very tricky job.
Jun 30, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Tom
Sep 08, 2008 | Nikon F100 35mm SLR Camera
Moisture
You have to open each side ( nikon travelite covers just unclip ) to get to the 4 prisms. Once opened to clean make sure you do not break the glue that holds down the prisms ( move the prisms in their seats and your alignment is out ). Clean with window cleaner and isopropanol to finish.
Aug 22, 2007 | Nikon Travelite V Binocular
Photography Logo
488 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
