Question about Electronics - Others
How to replace cone paper to 5cm tweeter - Electronics - Others
  • Electronics ... Master
  • 5,259 Answers
I doubt if you can! I would think it better to replace the tweeter. If you can't get an excat one replace it with a different one and buy two one for the other channel, the sound will then match up.
If you try to do it the problem will be getting the coil to slot in the magnet without scraping. Your probably need special equipment and that's why it will be hopeless.
Posted on Jan 30, 2009
My Ashdown amps tweeter cone plastic screw on surround has broken and the amp is old now. It's a ABE 400 combo and I think the part is probably not in production anymore.......any ideas? Cheers
Either you can get a sutiable tweeter to be fitted which matches the size and fits correctly.
If the amplifier is good order it can be restored , if not as mostly the older generation has moved off it will be difficult to replace the board or components. You can fit in a newer version of a power amp board.
Jun 26, 2012 | Ashdown Audio Players & Recorders
JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
Mar 05, 2012 | JBL Northridge Package System
My jamo d115 speaker tweeter distorts or rattels when any serious bass kicks in, how do you stop this?w
Possible this is a distortion from the Amplifier if the speakers are not damaged. however it is important to switch the speakers to confirm if the fault is relative to the particular channel in which case the amplifier is faulty. If not the speaker can be the culprit. All what is needed is to reduce the BASS level a bit lower when the volume is increased so as to allow the cross over to work. Also if teh cross- over network is faulty within the speaker the bass can vibrate on the tweeter.
Dec 01, 2011 | Jamo Audio Players & Recorders
I have Behinger Europort EPA900, One speaker crackles, tried swopping cables etc, but nothing helps, the problem seems to be definitely with the speaker.
Open the speaker and look for loose connections. Carefully move cone with fingers. If there is noise when doing so...rubbing type noise, speaker needs reconing or replacing. If the crackling comes from teh tweeter section, then the tweeter may need replacing.
Jan 31, 2011 | Behringer Europort EPA900 Ultra compact...
Tweeter is cutting in and out
need to open up speaker and check connections on tweeter. Check closely on tiny wires from magnet(voice coil) to paper cone
Jan 04, 2011 | Samson Resolv 65a Main / Stereo Speaker
Back speakers can't handle bass
you need to replace all the speakers in the truck except the front tweeters if you have them. I replaced all four with new infinitys from futureshop. Installed it was near 500 dollars. You need to get 2 ohm to match the infinity deck if yours is infinity. Most other systems are 4 ohm, these are 2 x 2 ohms for 2 and 4 ohm use. the factory's are garbage and use paper cones. The rears have plastic caps holding the tweeters in. On all four the paper was ripped away from the magnet and it caused them to vibrate and shake, once replaced with 180 watt infinitys...great sound.
Jul 06, 2010 | 1997 Jeep Grand Cherokee
Pioneer 4 way ts a6970 what are their wattage
  • 330W MAX.
  • 6" x 9" (16 x 24cm) woofer / 66mm cone midrange / 18mm dome tweeter
  • IMPP composite cone woofer
  • Butyl rubber sound for smoother response
  • Glass-imide voice coil bobbin for higher power handling capabilities
Oct 06, 2009 | Pioneer TS-A6970E Car Speaker
Is there anyway to fix a blown Bose Speaker (201)?
The only 2 solutions are: 1. Just find an equivalent driver to replace. Re-wire new driver speakers into the enclosures. The old 201s may have had decent drivers (although probably paper cone) for back then, but now just about anything will sound as good in those particular cabinets.
2. Call Bose and exchange them for current 201 speakers (higher clarity more powerful). Bose will give you about 30-40% off I believe on a series 5 model. They now pay for inbound and outbound shipping as well.
Aug 12, 2009 | Bose Wave Radio II
Need to replace 11L tweeter
the best solution I've found is this:
1. Remove all the tweeter screws.
2. Take a thing metal rod (a coat hanger should work) and lightly tap the tweeter through the top port in the rear until it is loosened and comes out. The tweeter is totally sealed so you probably won't damage it if you need to do this to a working tweeter.
This method also works for the woofer but you need to be very careful to tap the frame or magnet of the woofer and not the cone.
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
Electronics - Others Logo
41 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
