Question about Miele S251i Plus Bagged Canister Vacuum
Power cord broken inside s251i miele How do i open the s251i ????
  • 1 more comment
  • Anonymous Mar 25, 2014
    Power cord broken inside vacuum
  • john8668
    john8668 May 06, 2014
    Solution #1 ALMOST correct for later model s251i units. DO NOT need to remove switch panel. The third screw on later models is IN FRONT of the switch panel deep in a square indent under the back of the accessory door
  • john8668
    SO - jut 3 screws need to be removed all accessible without removing anything else.
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Posted on Dec 11, 2008
How do you open the body of a miele vacuum to get to cord reel
Good question..... I just took my S251i canister apart to clean it... For safe removal, mieles usually have 3 main body screws. (2 up under the bag compartment hood, and one under the buttons and switches, which you must remove the support screws first. Once open, I would not disconnect any wires, cuz I made that mistake!!
Jan 12, 2018 | Miele Vacuums
Miele vacuum powerhead
My power head failed due to the handle switch. It comes apart with the Phillips screw under the vacuum kill slider. Check for continuity across the switch contact solder points.
Mar 01, 2010 | Miele S251i Plus Bagged Canister Vacuum
The Miele S251i just stopped working. Is there an
How long has unit been down? There is a inline fuse by motor housing internally in unit, but sometimes these units take awhile for them to reset
Dec 03, 2009 | Miele S251i Plus Bagged Canister Vacuum
Buying spares Meile 250i
Hello Dave,
You'll want to contact Miele directly and they can direct you to your nearest shop
Miele Dealer Locator (vacuums)
(888) 785-2828
Monday-Sunday: 24 hours
Sep 05, 2009 | Miele S251i Plus Bagged Canister Vacuum
How do I open the Turbobrush attachment on my Miele vacuum?
Loosen& remove 4 screws at bottomof turbo brush After cuttingventangledthreadvthrough crosswise with sissors. Turn turbo brush over gentlyon an even surface. Carefully separate and liftvoff upper casing. Then remove stuck threads.reassemble lift upper casingto bottom plateand pressinto place.turn unit over topside down and replace screws.
Jul 04, 2009 | Miele S251i Plus Bagged Canister Vacuum
Access to the Plug in Cable of Miele White Star Vacuum Cleaner
Problem solved. A guy posted on the internet a step by step explanation including photos of how to open a Miele White Star vacuum to get to the take up reel.
May 13, 2009 | Miele S251i Plus Bagged Canister Vacuum
Meile s251i won't turn on
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Mar 26, 2009 | Miele S251i Plus Bagged Canister Vacuum
Opening Miele S28i Vacuum cleaner
If it is similiar to the white star you may find the instructions here useful: http://www.sannerud.com/house/miele.html
hope so
Jan 10, 2009 | Miele S251i Plus Bagged Canister Vacuum
How do I take my Miele S251i apart to be able to chenge the powercord?
Sep 13, 2008 | Miele S251i Plus Bagged Canister Vacuum
Miele S251i Plus Bagged Canister Vacuum Logo
1,102 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
