Question about Samsung YP-T8 Digital Media Player
Samsung yp-txz none of th e buttons work on this except for the power/play and the hold button.. i upgraded the firmware but my only problem is the other buttons dont work at all any help would be appriciated!
  • naomi rebolo Feb 18, 2007
    its supposed tp say samsung yp-t8z
RESET IT
Posted on Feb 20, 2007
I can't find FM radio in my samsung YP-U5
Press the button with the returning arrow at the top. The use the skip forwards and back buttons until you see the FM radio function. Press the play button to activate and once in you can use the forward and back buttons to scan for stations.
If this doesn't work, you could download emodio and update the firmware.
Feb 21, 2010 | Samsung YP-U5 MP3 Player
Suddenly, my YP-K3 Samsung music player is not turning on. I've tried to do a hard reset on this. Like, keeping the reset button on hold for 30 seconds but still, it won't work. I tried to reset it for so...
You may need to upgrade the firmware to fix it so try this. To Upgrade Firmware 1 Connect to http://www.samsung.com, select [SUPPORT]  [DOWNLOAD CENTER] and then select your player. Future upgrades may be available for this player to enhance performance and compatibility. 2 When the player page appears, select [Firmware] below the model name to download the latest firmware. 3 Uncompress the downloaded file onto your Desktop.  The uncompressed files will be displayed. 4 Connect the player to your PC with the USB cable. 5 Right click on the Start button on the bottom left of your PC's screen, then choose Explore to Open Windows Explorer on your PC.  [Samsung YP-K3] is displayed in Windows explorer. Hope this helps.
Jan 02, 2010 | Samsung YP-K3 MP3 Player
Occuring the problem when turning on with the title"bulding eror"
Click here for Firmware Update from samsung.com
Here is the instruction for updating the firmware:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port(Hold down the play button while you connect the device, you should seea message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message"Initializing" on YP-U2J Updater, you can now remove your hand fromplay button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUSTdisconnect the Mp3 player and turn it on. You will see a 20% messagefor about 50 seconds and it will be restarted automatically.
Dec 13, 2008 | Samsung YP-U2X Digital Media Player
YP-U3JZW/XET frozen
First, make sure the hold switch is off
Then, Push the hold switch in the direction of
the arrow.
Press and briefly hold the user and play/power
buttons at the same time to
reset the system.
Then, upgrade the firmware - b/c plugging it into a Linux system cause the DB to become corrupt
Finally, go to the Linux forums, b/c this player was definitely NOT designed for Linux, and you will never get an answer in this section
May 20, 2008 | Samsung YP-U3 MP3 Player
YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
Here is the instruction:
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 27, 2008 | Samsung YP-U2X Digital Media Player
Cannot use my player-device manager problem/deleting files
This error is common after with Windows Media Player 11
Jan 01, 2008 | Samsung YP-U2X Digital Media Player
Connection to my computer
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Doodles1
Dec 31, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung YP-z5 won't connect to the PC!
This might help getting it connected to the computer.
Sep 29, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
How do I f/w update??????
Here's the site with the firmware upgrade download: http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=Digital+Audio+Player(YEPP)&typecode=200600&subtype=Yepp&subtypecode=200601&model=YP-U2JQB/XAA&filetype=FM&language= although I'm sure that the f/w updater is within this program here: http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=Digital+Audio+Player(YEPP)&typecode=200600&subtype=Yepp&subtypecode=200601&model=YP-U2JQB/XAA&filetype=SW&language= That should help you with your problem. First download and install the first link, then use the tools that are within that program. Once finished, update it with the firmware update and you should be alright.
Apr 01, 2007 | Samsung YP-U2X Digital Media Player
Mp3 problems
TRY THIS! Download the latest firmware and flash the MP3 player. Make sure you download the correct firmware for your MP3 player and follow the instruction carefully. Go here for the latest firmware: http://www.cczclan.com/yp-55download.asp Follow this link for older firmware and software from Samsung: http://www.cczclan.com/yp-55download.asp
Sep 05, 2006 | Samsung YP-MT6X MP3 Player
Samsung YP-T8 Digital Media Player Logo
37 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
