Question about Whirlpool Duet GHW9150P Front Load Washer
Bleach drains from compartment as soon as it is filled
When putting bleach in the bleach compartment, it just drains straight through to the wash - before I have closed the compartment and started the wash. I cannot figure out what is happening or how to fix it.
  • 247 Answers
Could you be putting too much bleach in? These things are usually designed to be self siphoning once the dispenser is full enough. The idea is that you half-fill it with bleach. At the right point in the cycle, the machine starts adding water, filling the dispenser up to the point where it siphons out until empty. If you overfill at the outset, the thing will empty straight away. If you're sure that isn't the cause, then take the dispenser out and check that the dam that keeps the bleach in place to start with isn't damaged (you may need to take a cover off the back of the dispenser first to see this). A.
Posted on Feb 18, 2007
How do you get mold out of fresh tanks?
There should be a fresh water fill on the outside of the coach. If not then there is a valve that would need to be turned that will allow water to be put into the fresh water tank. If that is the case then it will be a bit more difficult to put bleach into the fresh water tank but not impossible. There will be a pump that draws fresh water out of the tank. You can disconnect the input and output lines. Connect the input line which comes from the fresh water tank to the output side of the pump. Then using a flexible line with a 1/2" pipe thread fitting, connect that to the input side of the pump. Put the loose end of the flexible line into a gallon of bleach and turn the pump on. It will draw the bleach out of the container and pump it into the fresh water holding tank. Now return the plumbing of the pump back to the original configuration. Using the valve system complete filling the fresh water tank with fresh water and allow to sit for a couple of days. Then open the low point drain on the fresh water tank and completely drain. When the coach is not in use make sure the tank is completely drained. There is also a fresh water treatment that you can purchase at your local rv parts department.
Jun 13, 2014 | KZ Coyote Rock Climber CRC220 RVs
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Maytag bravos washer- bleach compartment wont drain during wash cycle
The solenoid that turns on to dispense the bleach is bad, or you have a clogged tube that goes from bleach dispenser to tub.
Apr 29, 2012 | Maytag Bravos MTW6600T Top Load Washer
After each load the "fill bleach cup" is filled with water. I have to take the whole tray out and flip it up-side-down to empty the water. I cannot find where the thing can be clogged. I can't use bleach...
Bleach & fabric conditioners "syphon away" into machine... try adding 1/2 lt water to the bleach compartment, if it then syphons away your syphon is not blocked. If it does not drain you will need to find the syphon cap - genarally just a tube, most manufacturers will make the tube a different colour to the rest of the draw.
If it did drain when water added you may have issues with bleach not being a part of that particular cycle, delicates for example...
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Where does the detergent go on the ez3701cee, in compartment A or C?
Detergent Dispenser
The detergent dispenser has 3 compartments,
marked A, B, and C.
A. Pre-wash detergent
B. Wash Detergent, Bleach (e.g. Clorox®)
C. Fabric softener (e.g. Downey®)
Note: The Bleach must be filled into “B”
compartment.
Jul 07, 2009 | Equator EZ 3710 CEE / W Ventless...
We buy a use front load wacher we dont have the manuel it is a 24 inch front load we dont know if we use the same detergent ad softner and were we put it please sent me or phone me 72 581 0294 or e mail...
Any detergent that says "Automatic" should be OK.
Pretty much any softener should be OK.
You will usually find a drawer on the front panel of the machine, just under the top edge, typically on the left hand side.
If you open this drawer, you will find it is divided into a number of (typically four) compartments. There will be one or two large compartments for detergent and one or two smaller, usually partially covered, compartments for bleach and conditioner.
You need to identify which is which.
Starting with detergent: If you only have one large compartment, that's the one to use.
If there are two, you need to know which is for main wash and which is for prewash. If one is bigger than the other, use the big one for your main detergent load. If using a cycle that does a prewash, put detergent in the smaller compartment as well.
If they're both the same, you need to experiment: Select a wash cycle that doesn't do prewash. Turn the machine on, and when it starts to fill, cautiously open the drawer a little and look to see which compartment has the fill water running through it. That's the one you need to use for your main wash detergent (use the other as well on cycles that do a prewash).
Now look at the smaller compartments. Hopefully, they'll be marked with a triangle for the bleach and something looking like a flower for the conditioner. If not, put a little bit of conditioner into the bottom of each, set the machine to "final rinse" and see which compartment it takes the conditioner from. That's the one you use for conditioner in future. (Don't worry about the little bit of conditioner you've put in the bleach tray - this will rinse out the first time you run a full cycle).
When putting in bleach or conditioner, it's important not to overfill. If there's a fill level line, don't go above that. If the compartment is covered with a grating then fill no further than the grating. Overfilling will cause the product to go into the machine too early in the cycle.
(Finally, strongly advise against posting your phone number or personal email address on public internet sites - it attracts all sorts of undesirable attention)
Good luck - and enjoy your new machine.
A.
Mar 15, 2008 | Washing Machines
Bleach dispenser
This compartment works on syphon action caused by the water when filling, rmove syphon cover on dispenser bos or try pooring boiling water into compartment, this will usually resolve
Dec 09, 2007 | Maytag Neptune MAH5500B Front Load Washer
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
268 people viewed this question
Sal De
Marvin
Marvin
jimorris77
