Question about Motorola Mobility MING A1200
Blue tooth pictures can't be transfer in phone tools.
When I connect phone tools with blue tooth pictures can't be trananfer from phone to computor.
Multimedia dose not show all options.
Cable when connected all options seen.
I want to transfer picutes from my phone to PC
Welcome, Thank You for giving fixya.com the opportunity to HELP!
Your issue:
I want to transfer my pictures? from my phone to my pc.
Solution:
Your case will need the following kit witch you can purchase from HERE
If you already have the USB transfer cable all you need to do then is download the software from that website, install it on your computer, this will sync all your photos to your pc without a hassle.
We only give you the facts that you need in order to get the solution done. You will need to purchase if you have not already the transfer cable and kit from the source given.
Your ratings are important to us. Please be considerate when passing through Fixya.com to leave feedback so we know how we are assisting our askers.
Best Regards,
Rulds2008
Jul 16, 2011 | Motorola Mobility V265
I had a samsung a412 with alot of photos on it and now have a new phone but don't know how to get the pics off the old phone onto my computer
if the phone has an sd card transfer on to that then put the sd card into your new phone, or connect your old phone to your new phone with blue tooth and transfer them or transfer them to your computor via blue tooth then send them to your new phone via blue tooth
Jan 30, 2011 | Samsung Cell Phones
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | HTC Wildfire Cell Phone
Don't have USB driver, how to transfer pictures from Nokia 7210 to Personal computer?
transfer your pictures from your nokia7210 via blue tooth.attach your computer via blue tooth dongle.connect through a code0000 on both the item.now you r ready to transfer your images
Aug 15, 2010 | Nokia Handsfree For 6020, 6101, 6102...
Problem in transfering file via bluetooth
Take care.
Jun 17, 2010 | Sony Ericsson K750
Transfer the photos from the mobile to my comouter which software i have to download
hello there...that's right you can get a usb data cable, blue tooth ,or memory card reader to transfer your pictures to your
computer....
you can directly print the picture as some of the printers come with card readers built in which is very convinient
consider visiting a mobile accessory shop you will have all the options there
my best pick will be memory card reader if you already have a printer...it is very cheap...and can read multiple cards...so in
future if you change your mobile you will not have any problem
like with usb cable (different for different phone)
blue tooth and getting a new printer is a costly affair...blue tooth often have connectivity and software issues
go for memory card reader ...cheap ,reliable ,fast and best of all
Hope this helps
Cheers
May 24, 2009 | Cell Phones
Transfer data
If you old device includes a "blue-tooth" feature then it should be equipped to transfer all your contacts via blue-tooth.
Now if your device DOES NOT have any "blue-tooth" feature, then you can visit your nearest carrier store, and transfer contacts using their handy tool.
Thanks.
Mar 17, 2009 | Motorola Mobility RAZR V3
I do not have data cable I want to connect to PC via blue tooth
GAME DIDNT TRANSFER. PLEASE CHECK BLUETOOTH CONNECTION
Nov 12, 2008 | Nokia 6233 Cellular Phone
Size is not the problem
hi, sorry for my late reply,i've been doing exams.like i said before, use a memory card reader to transfer the files which can not be transfered directly to your phone. you can also use a usb blue tooth to transfer your pics from your pc to your phone, via blue tooth technology. those are alternatives that always work
May 31, 2008 | Nokia N95 Cellular Phone
Blue tooth
re-installed the driver of the blue tooth after that is not working then go for the internet and download a driver of your product it should work
Dec 30, 2007 | IOGear (GBU221) Bluetooth Wireless Adapter
Motorola Mobility MING A1200 Logo
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
